ISY Portal shows Offline, Registered
nickp
So, all of a sudden my ISY shows offline, and I've lost Alexa communication.
I have pulled the logs, and gone through them, and they show a DNS error
However, I can PING the portal.
I have also gone (as another suggestion said) to the NTP settings.  I manually set the clock 5 minutes fast, then used NTP to update the clock back to the regular time.  It took less than a second to use NTP.
I don't think I have a DNS issue.
I don't think I have an Internet issue.
But I cannot log into the portal.
ANY ideas out there?
ERRORS attached.
Edited by nickp
  On 11/17/2017 at 6:20 PM, Michel Kohanim said:
nickp,
The best thing to do would be to look at your error log.
Sorry, I was in the process of attaching it - please see it attached.
  On 11/17/2017 at 6:23 PM, Michel Kohanim said:
Nothing attached nick. if you need help, please send to support@universal-devices.com.
Sorry, wasn't taking my Excel file.
ZIP attached now.
Also sent you the email - thank you.
Michel fixed me!!!
In playing with some SSL settings, I ended up with VERIFY checked.
Once UNCHECKED everything worked.
Thanks Michel!
