Simple program question
I have a temp sensor on the output of my furnace.  When water temp goes below 120 I get text notification.  When temp restores I don't get any notification.
Furnace Temp Alert - [iD 000E][Parent 0001]
        Elk Zone 'Furnace Temp' is Violated
        Send Notification to 'AT&T Text' content 'Elk M1 Alert'
        Enable Program 'Furnace Temp Restored'
        Set Elk Speak Word 'Furnace'
        Set Elk Speak Word 'Temperature'
        Set Elk Speak Word 'Low'
Furnace Temp Restored - [iD 000F][Parent 0001][Not Enabled]
        Elk Zone 'Furnace Temp' is Normal
        Disable Program 'Furnace Temp Restored'
Elk M1 Alert = ${alert.control} ${alert.action}
On trip I get 'Furnace temp violated'
Or restoration, no text
I have to be missing something simple here.......
Thanks in advance.
John
Thanks in advance.
John
Your "Normal" program triggers are disabled.
BTW: You could place that code in the Else section of the first program unless there is a hysteresis element by time delay or by temperature difference, effectively giving three states instead of two.
Sending a network notification is asynchronous. Your program could be completing before its sent. Try adding a wait before the program disables itself to allow the network send to complete.
Ahhhh, ok, will try that.
John
Probably so (3 states), will try a delay
