e40 Posted December 13, 2017 Posted December 13, 2017 I was using my Elk M1G panel to control two thermostats via the Elk ZW + Leviton adapter. I am now controlling those two thermostats with the ISY994iZW/IR PRO - however I forgot to delete the stats from the Elk M1G before I configured it and let the ISY read it. I've since removed them from Elk-RP, however I can't get the ISY to 'forget' them, and remove them from the Thermostats view....
Thanatar Posted December 13, 2017 Posted December 13, 2017 Hi e40 and welcome to the forums. Sounds like you will need to do a refresh topology on the ISY to clear it up. On the ISY admin console go to Configuration>Elk>Configuration and click Refresh Topology.
e40 Posted December 13, 2017 Author Posted December 13, 2017 Hi Thanatar, yes, I've tried Refresh Topology already. I also get Unknown Armed State in the administrative console. I've went through all the troubleshooting in the Elk Module setup as well. I also verified I could connect with ElkRP using both secure and non secure port. (Making sure to disconnect ElkRP when done...)
e40 Posted December 13, 2017 Author Posted December 13, 2017 Getting this in my error logs: System -170001 [uDSockets] HTTP:29 error:6
e40 Posted December 13, 2017 Author Posted December 13, 2017 Changed it to use port 2101 in the ISY - seems to be working now.
