kemac Posted April 11, 2020 Share Posted April 11, 2020 Thanks @robl I was using the example (Copied below) from the "Configuration Help" for the Hue Poly which has single quotes, replacing the single quotes with double quotes around my IP address fixed the issue. bridges - this should be set to the list of Hue bridges if you have multiple you would like to be able to control, for example: ['10.0.1.1','10.0.2.1'] Link to comment Share on other sites More sharing options...
k.root Posted May 2, 2020 Share Posted May 2, 2020 Hello, I'm receiving the following message: 5/1/2020, 2:16:10 PM - info: Hue(3): Processing command: start 5/1/2020, 2:16:10 PM - info: NS: Starting Local NodeServer Hue profile number 3 :: Version 0.1.11 5/1/2020, 2:16:10 PM - error: NSChild STDERR: Hue: File "./hue.py", line 219 LOGGER.info(f"Hub {hub_idx} {data['type']} {name} {scene_data['type']} {scene_idx}:{scene_id}:{scene_data['name']}") ^ SyntaxError: invalid synta I've updated the RPi to Buster as I say you recommend to someone else. It's still not working. What else can I try? Thanks Link to comment Share on other sites More sharing options...
AnthemAVM Posted May 7, 2020 Share Posted May 7, 2020 Hello, I was trying to get this working last night, but keep getting an error saying it can not find the HUD. Configuration "Once installed - push the button on the Hue Bridge and add NodeServer into Polyglot, that will allow it to pair with the Bridge" How long should I hold the button? Wondering if I am doing something wrong? Thanks Link to comment Share on other sites More sharing options...
AnthemAVM Posted May 8, 2020 Share Posted May 8, 2020 On 5/7/2020 at 7:39 AM, AnthemAVM said: Hello, I was trying to get this working last night, but keep getting an error saying it can not find the HUD. Configuration "Once installed - push the button on the Hue Bridge and add NodeServer into Polyglot, that will allow it to pair with the Bridge" How long should I hold the button? Wondering if I am doing something wrong? Thanks I have found my issue, be sure to put your bridge address ['192.168.0.83"] in this format and you are good to go. Link to comment Share on other sites More sharing options...
k.root Posted May 8, 2020 Share Posted May 8, 2020 On 5/1/2020 at 8:20 PM, k.root said: Hello, I'm receiving the following message: 5/1/2020, 2:16:10 PM - info: Hue(3): Processing command: start 5/1/2020, 2:16:10 PM - info: NS: Starting Local NodeServer Hue profile number 3 :: Version 0.1.11 5/1/2020, 2:16:10 PM - error: NSChild STDERR: Hue: File "./hue.py", line 219 LOGGER.info(f"Hub {hub_idx} {data['type']} {name} {scene_data['type']} {scene_idx}:{scene_id}:{scene_data['name']}") ^ SyntaxError: invalid synta I've updated the RPi to Buster as I say you recommend to someone else. It's still not working. What else can I try? Thanks In my python_hue file I have what's below. I've edited out the text after username for posting here. It had been {"10.68.1.80": {"username":}} {['10.68.1.80']: {"username": }} When I start the nodeserver I receive the following. 5/8/2020, 6:32:12 PM [polyglot] info: NS: Starting Local NodeServer Hue profile number 3 :: Version 0.1.11 5/8/2020, 6:32:13 PM [polyglot] error: NSChild STDERR: Hue: File "./hue.py", line 219 LOGGER.info(f"Hub {hub_idx} {data['type']} {name} {scene_data['type']} {scene_idx}:{scene_id}:{scene_data['name']}") ^ SyntaxError: invalid syntax 5/8/2020, 6:32:13 PM [polyglot] info: Hue(3): NodeServer Disconnected. Version 2.2.10 Status: Connected Frontend Version: 2.2.9-5 ISY Version: 5.0.15A Running Raspbian Buster Thanks in advance for your assistance. Link to comment Share on other sites More sharing options...
k.root Posted May 9, 2020 Share Posted May 9, 2020 1 hour ago, k.root said: In my python_hue file I have what's below. I've edited out the text after username for posting here. It had been {"10.68.1.80": {"username":}} {['10.68.1.80']: {"username": }} When I start the nodeserver I receive the following. 5/8/2020, 6:32:12 PM [polyglot] info: NS: Starting Local NodeServer Hue profile number 3 :: Version 0.1.11 5/8/2020, 6:32:13 PM [polyglot] error: NSChild STDERR: Hue: File "./hue.py", line 219 LOGGER.info(f"Hub {hub_idx} {data['type']} {name} {scene_data['type']} {scene_idx}:{scene_id}:{scene_data['name']}") ^ SyntaxError: invalid syntax 5/8/2020, 6:32:13 PM [polyglot] info: Hue(3): NodeServer Disconnected. Version 2.2.10 Status: Connected Frontend Version: 2.2.9-5 ISY Version: 5.0.15A Running Raspbian Buster Thanks in advance for your assistance. With the help of this: https://www.gitmemory.com/issue/exking/udi-hue-poly/3/569830615 I got it working without changing the python_hue file Link to comment Share on other sites More sharing options...
jtara92101 Posted May 17, 2020 Share Posted May 17, 2020 Having no luck at all. See my comments on the "Bridge shown, no lights" thread. I don't like having to enable UPNP but I did so when I saw log messages. But doesn't help. Running on Polisy. 2020-05-16 18:41:01,964 MainThread polyinterface INFO __init__:<module>: UDI Polyglot v2 Interface 2.0.40 Starting... 2020-05-16 18:41:01,996 MainThread polyinterface DEBUG polyinterface:get_network_interface: gws: {'default': {2: ('10.0.1.1', 'igb0')}, 2: [('10.0.1.1', 'igb0', True)]} 2020-05-16 18:41:01,997 MainThread polyinterface DEBUG polyinterface:get_network_interface: gw: default=('10.0.1.1', 'igb0') 2020-05-16 18:41:01,998 MainThread polyinterface DEBUG polyinterface:get_network_interface: ifad: igb0=[{'addr': '10.0.1.4', 'netmask': '255.255.255.0', 'broadcast': '10.0.1.255'}] 2020-05-16 18:41:01,999 MainThread polyinterface INFO polyinterface:__init__: Connect: Network Interface: {'addr': '10.0.1.4', 'netmask': '255.255.255.0', 'broadcast': '10.0.1.255'} 2020-05-16 18:41:02,002 Interface polyinterface INFO polyinterface:_startMqtt: Connecting to MQTT... localhost:1883 2020-05-16 18:41:02,006 MainThread polyinterface INFO hue:__init__: Started Hue Protocol 2020-05-16 18:41:02,071 MQTT polyinterface INFO polyinterface:_connect: MQTT Connected with result code 0 (Success) 2020-05-16 18:41:02,073 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/ns/2 - MID: 1 Result: 0 2020-05-16 18:41:02,073 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2020-05-16 18:41:02,075 MQTT polyinterface INFO polyinterface:_connect: Sent Connected message to Polyglot 2020-05-16 18:41:02,080 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2020-05-16 18:41:02,083 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2020-05-16 18:41:02,192 NodeServer polyinterface INFO hue:connect: Saved bridges information is not found 2020-05-16 18:41:02,193 NodeServer polyinterface INFO hue:connect: No bridge configuration found, trying discovery... 2020-05-16 18:41:02,194 NodeServer polyinterface INFO phue:connect: Attempting to connect to the bridge... 2020-05-16 18:41:02,196 NodeServer polyinterface INFO phue:connect: Error opening config file, will attempt bridge registration 2020-05-16 18:41:11,914 NodeServer polyinterface INFO phue:get_ip_address: Connecting to meethue.com/api/nupnp 2020-05-16 18:41:12,056 NodeServer polyinterface ERROR hue:connect: Cannot find Hue Bridge 2020-05-16 18:41:12,058 NodeServer py.warnings WARNING warnings:_showwarnmsg: ./hue.py:122: ResourceWarning: unclosed <ssl.SSLSocket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('10.0.1.4', 32840), raddr=('35.201.97.239', 443)> 2020-05-16 18:41:12,058 NodeServer py.warnings WARNING warnings:_showwarnmsg: ./hue.py:122: ResourceWarning: unclosed <ssl.SSLSocket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('10.0.1.4', 32840), raddr=('35.201.97.239', 443)> It says it's connected, though. Tried ip and then bridges custom parameters. Is there a beginner's guide? ---- Got it! See Link to comment Share on other sites More sharing options...
JESonger Posted June 20, 2020 Share Posted June 20, 2020 I used to have the Hue Nodeserver working, and I had suggestions, but those will have to wait, because it started having problems with staying connected. I reverted to exclusively using Network Resources for quite a while, but decided to give the Nodeserver another go. But it wouldn't start. I have deleted it completely and successfully re-installed the latest version, and re-added it to slot 1. But it still will not start. Or restart. There's nothing in the logs. I'm very novice in the RPi environment. What can I do to get this working again? It's been so long, I don't even remember what to do once the server successfully starts, so help there is also appreciated. Link to comment Share on other sites More sharing options...
k.root Posted June 20, 2020 Share Posted June 20, 2020 @JESongerAcross the top of Polyglot is a Log look there and try: https://www.gitmemory.com/issue/exking/udi-hue-poly/3/569830615 Link to comment Share on other sites More sharing options...
JESonger Posted June 24, 2020 Share Posted June 24, 2020 Thanks, @k.root ... that helped... partially. I had to delete the system log, since it hadn't updated since Sept. '18. Once working, I saw the same problem as in that link. I deleted the node, verified it's directory was gone, redownloaded fresh from the store, and edited out the errant "f", and 5 others, from hue.py, as well as 2 more in node_types.py. I finally got the nodeserver started and registered! ...but only the hub showed up as a node. The Node logs showed: 2020-06-24 05:40:38,820 NodeServer polyinterface INFO phue:connect: Using username: c08l2aorQXbT7O585WtafyLRDKqbXEtk0IJllGr0 2020-06-24 05:40:38,876 NodeServer polyinterface INFO hue:connect: Connection OK 2020-06-24 05:40:38,878 NodeServer polyinterface INFO hue:_discover: Hub 192.168.23.11 Starting Hue discovery... 2020-06-24 05:40:38,890 NodeServer polyinterface INFO hue:_discover: Hub 192.168.23.11 1 bulbs found. Checking status and adding to ISY if necessary. 2020-06-24 05:40:38,895 NodeServer polyinterface ERROR polyinterface:write: Exception in thread NodeServer: Traceback (most recent call last): File "/usr/lib/python3.5/threading.py", line "/usr/lib/python3.5/threading.py", line 862, in run self._target(*self._args, **self._kwargs) File "./hue.py", line 45, in start self.discover() File "./hue.py", line 150, in discover self._discover(idx) File "./hue.py", line 167, in _discover for lamp_id, data in self.lights[hub_idx].items(): AttributeError: 'list' object has no attribute 'items' So 0.1.11 arrived with 8 errors I could fix to get the server started, and another 5 that I can't so it works. What say you, @xKing? is there a problem with this version? Can I fix this, or do I have to wait for an update? Link to comment Share on other sites More sharing options...
xKing Posted June 28, 2020 Author Share Posted June 28, 2020 there are no problems with Hue, it just requires python >= 3.6 and you have 3.5. Upgrade your Pi OS. I won't support older python for any of my node servers. Link to comment Share on other sites More sharing options...
JESonger Posted June 30, 2020 Share Posted June 30, 2020 I just did an update, then a full upgrade. Python still shows 3.5.3. I've done an apt-get install python3, but it's telling me 3.5.3 is the latest version. What am I missing? How do I actually accomplish that? Link to comment Share on other sites More sharing options...
xKing Posted June 30, 2020 Author Share Posted June 30, 2020 was discussed earlier in this topic Link to comment Share on other sites More sharing options...
JESonger Posted June 30, 2020 Share Posted June 30, 2020 I found some directions, manually built 3.6.5, and then saw your reply & link. I followed it, and your instructions, including running Hue's install.sh. But I'm back to the original problem: Hue nodeserver won't start because: 6/30/2020, 6:42:38 PM - error: NSChild STDERR: Hue: File "./hue.py", line 219 LOGGER.info(f"Hub {hub_idx} {data['type']} {name} {scene_data['type']} {scene_idx}:{scene_id}:{scene_data['name']}") The "f" is back. Why the "f"? I had edited a lot of them out before, and inferred they were there because of the wrong Python version. But now the script has put at least one back. Should I be editing those files again, or is there a proper solution? Link to comment Share on other sites More sharing options...
xKing Posted June 30, 2020 Author Share Posted June 30, 2020 https://realpython.com/python-f-strings/#f-strings-a-new-and-improved-way-to-format-strings-in-python if you python complains - you have an old python still Link to comment Share on other sites More sharing options...
HABit Posted November 18, 2020 Share Posted November 18, 2020 Just wanted to say thanks @xKingfor another useful NS. I had a little difficulty getting this setup, which in no way had anything to do with the NS. My Hue hub is located in the utility room, but my office is down two long halls and upstairs. The notice banner says to hit the hub (authorization) button and then restart the NS within 30 seconds. This I tried and tried again and again, even timing my excursion from utility room to office to ensure it was within the allotted time. Then of course I started over-thinking this failure, first going through the router, its firewall, the NS code and how the Hue module you used did the authorization. I hard wired the hub IP into the code, with no success. I even accessed the Hue hub directly, creating an authorized user using the POST api, then interrogating it and could see all of the lights. I then knew it was most-likely a race condition (in the truest sense of the words). My solution: (Only for future users who have a Hue hub located semi-distantly) 1. Setup the Hue NS until the banner/message appears instructing the button press and restart. 2. STOP the NS (this turned out to be the difference in getting the authorization within the allotted 30 secs) 3. Put on jogging shorts for a sprint to the finish line. 4. Press hub button. 5. Race back to Poly server and START the Hue NS again. Link to comment Share on other sites More sharing options...
lilyoyo1 Posted November 18, 2020 Share Posted November 18, 2020 11 minutes ago, HABit said: Just wanted to say thanks @xKingfor another useful NS. I had a little difficulty getting this setup, which in no way had anything to do with the NS. My Hue hub is located in the utility room, but my office is down two long halls and upstairs. The notice banner says to hit the hub (authorization) button and then restart the NS within 30 seconds. This I tried and tried again and again, even timing my excursion from utility room to office to ensure it was within the allotted time. Then of course I started over-thinking this failure, first going through the router, its firewall, the NS code and how the Hue module you used did the authorization. I hard wired the hub IP into the code, with no success. I even accessed the Hue hub directly, creating an authorized user using the POST api, then interrogating it and could see all of the lights. I then knew it was most-likely a race condition (in the truest sense of the words). My solution: (Only for future users who have a Hue hub located semi-distantly) 1. Setup the Hue NS until the banner/message appears instructing the button press and restart. 2. STOP the NS (this turned out to be the difference in getting the authorization within the allotted 30 secs) 3. Put on jogging shorts for a sprint to the finish line. 4. Press hub button. 5. Race back to Poly server and START the Hue NS again. Why couldn’t you take your laptop to the utility room or temporarily hook up the hub in your office? Link to comment Share on other sites More sharing options...
Javi Posted January 22, 2021 Share Posted January 22, 2021 Hi Guys, Can someone with this node server run a quick test? From the admin console command "Set XY Color" change the Transition time, then press "Set XY Color". Is the transition time updated? Thanks! Link to comment Share on other sites More sharing options...
andrew67 Posted March 16, 2021 Share Posted March 16, 2021 Can someone please explain how to use ColorLoop? or perhaps, how to reset the hue and or apply/use multiple settings in a scene? I turned on color loop by pressing the set effect "button" after selecting ColorLoop, I then activated my scene which goes to 2700K and brightness 254. The lights got brighter, but the setting of 2700 didn't take. The lights are now locked in their colorloop, and until I overwrite "Set Effect" the color temp setting is ignored. Seems like a bug since you then can't use the effect ever, and if youre lights ever get into a weird mode, you can't get out. Link to comment Share on other sites More sharing options...
mserrar Posted May 9, 2021 Share Posted May 9, 2021 Guys, I have installed this node server version 0.1.11 , I integrated some Hue devices in my ISY scenes. It works fine, but I need every 24h to restart the nodeserver. It's like if it disconnect from the bridge. Any idea what is causing this and how to fix it? Link to comment Share on other sites More sharing options...
MrBill Posted May 9, 2021 Share Posted May 9, 2021 52 minutes ago, mserrar said: Guys, I have installed this node server version 0.1.11 , I integrated some Hue devices in my ISY scenes. It works fine, but I need every 24h to restart the nodeserver. It's like if it disconnect from the bridge. Any idea what is causing this and how to fix it? Any clues in the log? Link to comment Share on other sites More sharing options...
mserrar Posted May 9, 2021 Share Posted May 9, 2021 5 minutes ago, MrBill said: Any clues in the log? This time I didn't look at the log, I just restarted it and it worked. Probably tonight it will be down again, I will post the log here. Link to comment Share on other sites More sharing options...
mserrar Posted May 10, 2021 Share Posted May 10, 2021 18 hours ago, MrBill said: Any clues in the log? Here is part of what I see in the log: 5/10/2021, 00:01:14 [polyglot] info: Hue(1): Processing command: status 5/10/2021, 00:01:14 [polyglot] info: Hue(1): n001_880106d58a970b GV6 set sucessfully to 1 : UOM 2 5/10/2021, 00:01:14 [polyglot] info: Hue(1): n001_huegrp3 ST set sucessfully to 0 : UOM 51 5/10/2021, 00:01:14 [polyglot] info: Hue(1): n001_huegrp3 GV1 set sucessfully to 0.3129 : UOM 56 5/10/2021, 00:01:14 [polyglot] info: Hue(1): n001_huegrp3 GV2 set sucessfully to 0.3291 : UOM 56 5/10/2021, 00:01:14 [polyglot] info: Hue(1): n001_huegrp3 GV4 set sucessfully to 77 : UOM 100 5/10/2021, 00:01:14 [polyglot] info: Hue(1): n001_huegrp3 GV5 set sucessfully to 5 : UOM 100 5/10/2021, 00:01:14 [polyglot] info: Hue(1): n001_huegrp3 GV3 set sucessfully to 41437 : UOM 56 5/10/2021, 00:01:14 [polyglot] info: Hue(1): n001_huegrp3 GV6 set sucessfully to 3 : UOM 56 5/10/2021, 00:01:14 [polyglot] info: Hue(1): n001_huegrp3 RR set sucessfully to 400 : UOM 42 5/10/2021, 00:01:14 [polyglot] info: Hue(1): n001_huegrp3 CLITEMP set sucessfully to 6536 : UOM 26 5/10/2021, 00:07:53 [polyglot] error: MQTTS: keepaliveTimeout: polyglot_frontend-fy3FF 5/10/2021, 00:07:53 [polyglot] error: MQTTS: clientError: polyglot_frontend-fy3FF keep alive timeout 5/10/2021, 00:07:53 [polyglot] info: MQTTS: Client Disconnected: 5/10/2021, 00:07:55 [polyglot] info: MQTTS: polyglot_frontend-fy3FF authenticated successfully. 5/10/2021, 00:07:55 [polyglot] info: MQTTS: Client Connected: 5/10/2021, 00:07:55 [polyglot] info: MQTTP: Frontend Websockets interface Connected. 5/10/2021, 00:16:53 [polyglot] error: MQTTS: keepaliveTimeout: polyglot_frontend-fy3FF 5/10/2021, 00:16:53 [polyglot] error: MQTTS: clientError: polyglot_frontend-fy3FF keep alive timeout 5/10/2021, 00:16:53 [polyglot] info: MQTTS: Client Disconnected: 5/10/2021, 00:16:55 [polyglot] info: MQTTS: polyglot_frontend-fy3FF authenticated successfully. 5/10/2021, 00:16:55 [polyglot] info: MQTTS: Client Connected: 5/10/2021, 00:16:55 [polyglot] info: MQTTP: Frontend Websockets interface Connected. 5/10/2021, 00:24:53 [polyglot] error: MQTTS: keepaliveTimeout: polyglot_frontend-fy3FF 5/10/2021, 00:24:53 [polyglot] error: MQTTS: clientError: polyglot_frontend-fy3FF keep alive timeout 5/10/2021, 00:24:53 [polyglot] info: MQTTS: Client Disconnected: 5/10/2021, 00:24:55 [polyglot] info: MQTTS: polyglot_frontend-fy3FF authenticated successfully. 5/10/2021, 00:24:55 [polyglot] info: MQTTS: Client Connected: 5/10/2021, 00:24:55 [polyglot] info: MQTTP: Frontend Websockets interface Connected. 5/10/2021, 00:31:53 [polyglot] error: MQTTS: keepaliveTimeout: polyglot_frontend-fy3FF 5/10/2021, 00:31:53 [polyglot] error: MQTTS: clientError: polyglot_frontend-fy3FF keep alive timeout 5/10/2021, 00:31:53 [polyglot] info: MQTTS: Client Disconnected: 5/10/2021, 00:31:55 [polyglot] info: MQTTS: polyglot_frontend-fy3FF authenticated successfully. 5/10/2021, 00:31:55 [polyglot] info: MQTTS: Client Connected: 5/10/2021, 00:31:55 [polyglot] info: MQTTP: Frontend Websockets interface Connected. 5/10/2021, 00:39:53 [polyglot] error: MQTTS: keepaliveTimeout: polyglot_frontend-fy3FF 5/10/2021, 00:39:53 [polyglot] error: MQTTS: clientError: polyglot_frontend-fy3FF keep alive timeout 5/10/2021, 00:39:53 [polyglot] info: MQTTS: Client Disconnected: 5/10/2021, 00:39:55 [polyglot] info: MQTTS: polyglot_frontend-fy3FF authenticated successfully. 5/10/2021, 00:39:55 [polyglot] info: MQTTS: Client Connected: 5/10/2021, 00:39:55 [polyglot] info: MQTTP: Frontend Websockets interface Connected. 5/10/2021, 00:46:53 [polyglot] error: MQTTS: keepaliveTimeout: polyglot_frontend-fy3FF 5/10/2021, 00:46:53 [polyglot] error: MQTTS: clientError: polyglot_frontend-fy3FF keep alive timeout 5/10/2021, 00:46:53 [polyglot] info: MQTTS: Client Disconnected: 5/10/2021, 00:46:55 [polyglot] info: MQTTS: polyglot_frontend-fy3FF authenticated successfully. 5/10/2021, 00:46:55 [polyglot] info: MQTTS: Client Connected: 5/10/2021, 00:46:55 [polyglot] info: MQTTP: Frontend Websockets interface Connected. 5/10/2021, 00:53:53 [polyglot] error: MQTTS: keepaliveTimeout: polyglot_frontend-fy3FF 5/10/2021, 00:53:53 [polyglot] error: MQTTS: clientError: polyglot_frontend-fy3FF keep alive timeout 5/10/2021, 00:53:53 [polyglot] info: MQTTS: Client Disconnected: 5/10/2021, 00:53:55 [polyglot] info: MQTTS: polyglot_frontend-fy3FF authenticated successfully. 5/10/2021, 00:53:55 [polyglot] info: MQTTS: Client Connected: 5/10/2021, 00:53:55 [polyglot] info: MQTTP: Frontend Websockets interface Connected. 5/10/2021, 01:01:53 [polyglot] error: MQTTS: keepaliveTimeout: polyglot_frontend-fy3FF 5/10/2021, 01:01:53 [polyglot] error: MQTTS: clientError: polyglot_frontend-fy3FF keep alive timeout 5/10/2021, 01:01:53 [polyglot] info: MQTTS: Client Disconnected: 5/10/2021, 01:01:55 [polyglot] info: MQTTS: polyglot_frontend-fy3FF authenticated successfully. 5/10/2021, 01:01:55 [polyglot] info: MQTTS: Client Connected: 5/10/2021, 01:01:55 [polyglot] info: MQTTP: Frontend Websockets interface Connected. 5/10/2021, 01:10:53 [polyglot] error: MQTTS: keepaliveTimeout: polyglot_frontend-fy3FF 5/10/2021, 01:10:53 [polyglot] error: MQTTS: clientError: polyglot_frontend-fy3FF keep alive timeout Link to comment Share on other sites More sharing options...
mserrar Posted May 10, 2021 Share Posted May 10, 2021 This was from the polisy log, and this is from the hue node log: 2021-05-10 00:01:14,757 Controller polyinterface ERROR polyinterface:write: Exception in thread Controller: Traceback (most recent call last): File "/usr/local/lib/python3.7/threading.py", line 926, in _bootstrap_inner self.run() File "/usr/local/lib/python3.7/threading.py", line 870, in run self._target(*self._args, **self._kwargs) File "/var/polyglot/.local/lib/python3.7/site-packages/polyinterface/polyinterface.py", line 857, in _parseInput self.nodes[input[key]['address']].query() File "/var/polyglot/nodeservers/Hue/node_types.py", line 442, in query self._updateInfo() File "/var/polyglot/nodeservers/Hue/node_types.py", line 469, in _updateInfo self.brightness = self.data['action']['bri'] KeyError: 'bri' Link to comment Share on other sites More sharing options...
Adolfo Posted May 11, 2021 Share Posted May 11, 2021 Polisy updated I get this and no nodes for lights: Please help. BTW, this is by far the most useful node. 2021-05-11 10:36:33,080 NodeServer polyinterface INFO hue:connect: Connection OK 2021-05-11 10:36:33,086 NodeServer polyinterface INFO hue:_discover: Hub 192.168.1.97 Starting Hue discovery... 2021-05-11 10:36:33,115 NodeServer polyinterface INFO hue:_discover: Hub 192.168.1.97 1 bulbs found. Checking status and adding to ISY if necessary. 2021-05-11 10:36:33,126 NodeServer polyinterface ERROR polyinterface:write: Exception in thread NodeServer: Traceback (most recent call last): File "/usr/local/lib/python3.7/threading.py", line 926, in _bootstrap_inner self.run() File "/usr/local/lib/python3.7/threading.py", line 870, in run self._target(*self._args, **self._kwargs) File "./hue.py", line 45, in start self.discover() File "./hue.py", line 150, in discover self._discover(idx) File "./hue.py", line 167, in _discover for lamp_id, data in self.lights[hub_idx].items(): AttributeError: 'list' object has no attribute 'items' Link to comment Share on other sites More sharing options...
