Ecolink DWZWAVE2.5-ECO Switch Issues
Greetings,
New user to the ISY, having purchased an ISY994i/IR Pro. I have integrated this with my Alarm.com IQ Panel 2 with the ISY as the primary controller. Since owning this I have integrated a Schlage Door Lock, Alarm.com thermostat, 2 GE Dimmable Switches, a Leviton Outlet and a Aeotec Multisensor 6. All of these integrations have worked without much issue and the pairings were painless. After after a little difficulty I was able to get the Ecolink switch paired and it shows up as Binary Sensor, Notify Sensor and Tamper Alarm.
However I am unable to get this switch to respond to any inputs, no matter whether the contacts are closed or open it doesn't change the state. Both the Tamper and Binary Sensor are reporting an 'On' state. I have deleted and added it to the DB multiple times with the same results. I searched previous threads here and saw there was some conversation about an issue others were having, but their issue appeared to be resolved. Any ideas on how to fix this?
Michel,
I am using version 4.6.2, see attached screenshot.
Matt
OK..Looks like no one has been able to get these to work, or hasn't tried. Can someone suggest another door/window sensor that works?
