Mobilinc Cloud Service + ISY Portal
Can I have both?
I have been using the ISY portal and like it.  I use it for remote login, Amazon Echo integration, etc.
I use Mobilinc as my mobile solution and wondering if I can add their cloud service without interfering with the ISY portal.  I specifically want the ability to use geofencing and push notification (vs sending SMS messages like the ISY does).
Any other suggestion for geofencing solutions that work well with the ISY?
Hi borne2dive,
Unfortunately not. Sorry.
Geo Fencing can be done through ISY Portal: http://wiki.universal-devices.com/index.php?title=ISY_Portal_Node_Server_Occupancy_%26_Locative_app_Instructions
Thanks Michel.  I think this may work.  All I need is to be able to set a state variable based on the geofence.  I think I can do that using the instructions in the link above, right?
Hi born2dive,
You can do much more than that. This creates "nodes" in ISY. You can have a node for home, office, yours, someone else's, etc. and then use them as you would any node in programs. In short, you don't need variables.
OK, I just tried to setup the node server on the portal and it says ISY version 5.0.9 is required.  Mine is at 4.6.2.  I am not presented with the upgrade option in the admin console as it is displayed usually.  Do I need to perform a manual upgrade?
I tried to upgrade using the portal and 5.0.9 is not even displayed as an option.  It says 4.6.2 is the current version.
Screenshots attached.
Please advise.
Edited by born2dive
