Program Runs "Then" and then runs "Else"
Well, it looks like sometimes the trigger program runs more than once and when it does the problem occurs. The first time the trigger program runs it calls the action program's 'then'. The second time the trigger program runs it sees the outside light as on and runs the action program's 'else'.
I know wireless Insteon devices send their status (Switched on or switched off) multiple times. ISY should ignore the secondary ones as duplicates.
I’ve never thought about this, because I’ve never had this requirement on my system. Could those events be causing an issue somehow?
Can you post the level 3 log showing where the door opens?
Also, what type of device is it?
I like to think of it like this...
The device being ‘switched’ triggers the program. A test is then done, ‘Switched On’ or ‘Switched Off’ to decide if ‘Then’ or ‘Else’ should be executed.
So, testing only for ‘Switched On’ will cause ‘Then’ to run when the device is switched on, and ‘Else’ to run when the device is switched off.
If you want the program to respond ONLY to ‘On’ commands, you need to match the ‘Not Off’ as well.
Not wanting to rehash old arguments, but in an ideal event-driven program model, I would specify what events I wanted to trigger my program, and then write the program I wanted run when those events occurred, including if statements to check various conditions and statuses. However, the ISY programming model doesn't work that way. The ISY infers the triggering events from the conditions in the If clause. Unfortunately what trigger events are to be inferred is not always clear, and it can lead to some unwanted results. And, IMO, it makes the Else branch in the ISY programming model nearly useless. This is all discussed in great detail in the Wiki and a number of posts linked in the Wiki.
The way to get around these limitations in the event-driven ISY programming model is to do what the OP has done here: create a first program that has your trigger conditions in the If clause, and have it execute a second program that checks the conditions and statuses and performs the tasks. This second program is disabled, so that no trigger conditions are inferred from its If clause.
It appears the problem here has nothing to do with his model, just with the fact that the first program (the trigger or event program) is being executed multiple times. This is likely because the ISY is receiving multiple On cmds from the South Gate sensor (whatever that is). Depending on why this is happening, there are a number of options to prevent the subsequent calls to the second program:
1. Put the running status of the second program in the If clause of the first program (I believe this method best comports with the information in the Wiki)
2. Have the second program disable the first program for a time
3. Use a variable to short circuit the first program when the second program is running
Edited by kingwr
My bad on this.
When I downloaded the program as a txt file, it just so happened that the text editor opened it to the end of the doc and the second program exactly perfectly fit on the screen . ..  and I didn't realize there was another program above it.
Just an FYI, this forum software has the ability to post code directly.  It works much better that way . . use the <>.
If the second program is triggering twice, then it can only happen because ISY is seeing two events from that gate sensor which is trigger the first program twice.
The first part of both the "then" and "else" are atomic . ..  they will run to completion and can't be interupted by a re-trigger.
Once you hit the repeat, a retrigger can happen.  So you will always see the first part happen with every trigger, how much of the stuff after the repeat happens will depend on when the re-trigger occurred.
Debugging would include
1) Put a "notify" and have the first program send you an email every time it triggers.
2) Put your ISY in level 3 and watch all the com
Alternatively, flank your second program with a disable/enable of the first program.  In other words, first line of the "then" and "else" clause disables program 1, and the last line of each re-enables program 1.  In this event, the second program would always finish to completion and would never run twice unless a second trigger happened AFTER the second program was completely finished.
Replying to above comments/suggestions:
This is done, I'm watching results. So far the trigger program runs twice about 1/2 the time.
There are so many things happening (due to the complexity of the 'then/else' statements) and I'm afraid it is beyond my current understanding to make total sense of it.
2421 trigger-link v.40. It is set to only notify on an open event. It routinely reached 2 hops, sometimes 3 due to distance, but it seems to "work" 100% of the time. I see how this RF communication may cause multiple triggers to be received.
I will do this when I get home at end of day
All this said, I'm interested in fulfilling the original requirements as simply as possible and thank you both for suggestions on how to do that. Sounds like current suggestions are:
  • use a variable set in the second program to short circuit the trigger event in the first program and then reset the variable after the second program was finished
  • flank your second program with a disable/enable of the first program
  • put the running status of the second program in the If clause of the first program
Is there a consensus on the "best" solution, or any other solutions come to mind?
Thanks again for input.
:MIke
<snipped>
:MIke
Whoa!!! Everybody will have a different method that feels best to them butt....
I would set a State variable to True  = 1 in the first program
In the Second program I would monitor the Stat variable for True = 1 and then run whatever depending on your logic  and condition.
At the end of each section clear the State variable to False = 0
Programs that disable others can get locked out when a power failure or ISY reboot occurs. Looping programs can get stopped on the same problems but also when you edit them. Now you need another bank of programs to monitor the monitor program etc.. Variables automatically set themselve to the Init to value on ISY reboot.
I know how to do most of what is required, I'll give it a shot.
Edit: This is what I came-up with, can't test until later. Open to suggestions.
____________________________________________
South Door (Door) - [iD 001C][Parent 0031]
        Control 'Main House / Motion-Door Sensors / South Gate Sensor-Opened' is switched On
    And $Door_Prog_Running is 0
        Send Notification to 'Text' content '!South Door - Door (if)'
        Run Program '_South Door (Door)' (If)
_South Door (Door) - [iD 0033][Parent 0035][Not Enabled]
        Status  'Outside / South Lights' is Off
    And From    Sunset  - 30 minutes
        To      Sunrise + 30 minutes (next day)
        $Door_Prog_Running Init To 1
        Send Notification to 'Text' content '!South Door - Door (then)'
        Set 'Outside / South Lights' Fast On
        Set 'Outside / North Lights' Fast On
        Set 'Outside / West Lights' Fast On
        Set 'Outside / Front Porch Shed' Fast On
        Set 'Outside / Back Porch Shed' Fast On
        Set 'Main House / Keypads / Front Door' Fast On
        Set 'Main House / Keypads / Back Door' Fast On
        Repeat 15 times
           Set 'Main House / Kitchen Accents' 250 (Beep Duration)
           Set 'Main House / Kitchen Island Cans' 250 (Beep Duration)
           Set 'Main House / Keypads / Bedroom' 250 (Beep Duration)
        Repeat 1 times
           Wait  30 seconds
           Set 'Outside / South Lights' 25%
           Set 'Outside / North Lights' 25%
           Set 'Outside / West Lights' 25%
           Set 'Outside / Front Porch Shed' 25%
           Set 'Outside / Back Porch Shed' 25%
           Set 'Main House / Keypads / Front Door' 25%
           Set 'Main House / Keypads / Back Door' 25%
           Wait  60 seconds
           Set 'Outside / South Lights' Off
           Set 'Outside / North Lights' Off
           Set 'Outside / West Lights' Off
           Set 'Outside / Front Porch Shed' Off
           Set 'Outside / Back Porch Shed' Off
           Set 'Main House / Keypads / Front Door' Off
           Set 'Main House / Keypads / Back Door' Off
           $Door_Prog_Running Init To 0
        Send Notification to 'Text' content '!South Door - Door (else)'
        Repeat 15 times
        Repeat 1 times
           Wait  30 seconds
           Wait  60 seconds
Edited by walkman9999
That is true.  Though we are only talking about a ~100 second window in which a power failure would be able to create a problem.  A good question to answer is whether clicking "run at startup" would over ride the program being disabled.  If so, you can use that to circumvent any risk of the program being 'trapped" in the disabled state.  Either way, I wouldn't be too concerned since it is not a life or death program.
On the other hand, the variable solution is more likely to create confusion when, say 3 years from now, when you go to edit it or whatever and your have totally forgotten all of this stuff.
Personally, I keep my ISY on a UPS so power outages are never an issue.  I recommend that for lots more reasons than just this example.
Finally, how quick are the two triggers comming?  Are they like 1 or 2 seconds apart?  If they are bang/bang, then you only need to disable program 1 for a few seconds, not the entire ~100 seconds of the then/else clause.  That may also have other advantages .. .say you actually open that gate on purspose a second time and want it to re-trigger.
        Repeat 15 times
        Repeat 1 times
           Wait  30 seconds
           Wait  60 seconds
        Repeat 15 times
        Repeat 1 times
           Wait  30 seconds
           Wait  60 seconds
You are "init" -ing the variable.  You don't want to init it, you want to set it.  init is what the variable is set to at boot, not the current value currently in use.
Happens with almost every project I do, home or work. Can't seem to learn to notate and use comments
>> how quick are the two triggers coming?
They come (according to notifications) between 10-25 seconds apart. A valid concern, but I don't mind forgoing the two quick door event notifications for the stability.
UPS for the Win! I am a network guy so lots of UPS in my "technology closet". They are priceless.
Thank you. I made the change. I am assuming you set the variable with the '=' operator? Please let me know if not correct.
Yes.
=-  means new value is old value minus whatever you entered
=+ means new value is old value plus . . .
=/  means new value is the old value divided by  . . .
Then using a variable offers no advantage as compared to just disabling the program directly.
That is very odd.  Unless it is a delay in ISY sending emails (very possible) I can't imagine any sort of Insteon glitch would have such long delay between two triggers which should have been just one.
If you learn to use the log, you'll be able to see the actual times that the program triggered.
I agree with your logic, not clear to me why it runs twice either. For now, I am going to try the plan of using a variable to keep track of whether the program is running or not with the goal being making it work. When I get home I will take a look at logging and figure out when it gets triggered. Thank you (and everyone) for your input and help.
>> I think it may because the program I'm checking variable status in is not disabled (it is the original trigger program). IS there a better/cleaner/simpler way to use the variable that I'm missing?
This works fine so don't change it.
But you could have skipped the variable and started your "then/else clause" (on the big program) with "disable program south door (door)" and ended your "then/else" clause with "enable program south door (door)".  You would put it those commands in the same place you put the variable = 1 and variable = 0
I see what you're saying. Tonight will be the test of the variable system. Hoping for the best, other wise will collect some logs and post problems. Thank you.
Is this not working?
To be clear, you used the post above, or a different implementation of a variable from that?
The reason I ask is I question whether, if you run program B (disabled) from program A (enabled), and then program A is triggered again, will that stop the running program B, even if A does not call B on the second trigger?
I am using the above implementation.  I'm not sure I can answer your question though. Program A (the enabled program) is no longer triggered again (unexpectedly) because the 'if' statement is not met (since the variable is set to '1'). Is this what you're asking?
When you say "program a is not triggering", I know what you mean, but this is incorrect.  The program still triggers and in fact executes the "else" clause.  It is just that your else clause is blank.
With ISY and "event" based programs, you must always keep straight the concept of a trigger.  A trigger is anything that causes the "if" clause to evaluate.  The outcome of the evaluation should not be confused with the evaluation process itself.
That makes perfect sense, and an important piece to keep in mind. Still wrapping my head around the functionality.
Just to add a little more to your plate. I define many Integer variables with permanent values for usage like this.
I try to keep them origanised up into the 200+ range by defining spares up to 199 for programming use. Some are grouped with other user value ones by function grouping too.
set $Variable = $cTRUE
....$Variable is $cFALSE
  • set ecobee.stat temperature = $cHVAC.SETPOINT.DAY
  • set $HueLamp.colour = $cHUE.RED
  • set $MiLight.colour = $cML.SEAFOAM
In the style of some programming languages I use all CAPS and the "c" prefix to define it is a constant. The "c" prefix also helps identify and sort the massive pulldown list of variables when programming with them.
If it works then that answered my question. Yes Program A is being triggered again but Program B continues to run, i.e. is not preempted.  That is the way it is supposed to work, but I was afraid that Program A running Program B may have been interpreted by the ISY as just an extension of the "thread" of Program A.
Edited by kingwr
