Do something if a trigger occurred within X time?
I want my garage lights to turn off when the garage doors close, but only if the alarm was set within 10 minutes. I have devices that change state on the garage closing and alarm arming.
So:
If Alarm armed within 10 minutes
AND
Garage door closed
Garage lights off.
All I can think of is a two programs:
Program 1:
If alarm armed
Variable = 1
wait 10 minutes
Variable = 0
Program 2:
If garage closed AND variable = 1
Then garage lights off
Any way to do this in one program?
Agree. Takes two programs.
Program 1
Enable Program2
Wait 10 minutes
Disable Program2
Program 2
If GDO is triggered
Then ......
Thanks guys. Particularly larryllx, I never considered using the first to enable/disable the second. Off I go!
One caveat. The technique is very obscure from the disabled program. Looking at the program itself, there is no clue what or how it could work.
Naming become important.
When I looked at the larryllix program, I was not confident that it would meet yor stated needs. What happens, for example, if the GDO is triggered, but the alarm is set after that? IOW, What triggers program2 if the alarm is set a few minutes after the garage door is closed?
Maybe I am missing something, but I preferred the concepts of your original proposal in post 1. I guess it depends on your needs.
Good point but I think my concept fits the bill exactly to request (per my re-read) but I am not sure the OP request was worded exactly per wanted function. More detail and clarification of the wording and perhaps rethinking the exact algorithm function may be needed.
IOW: I may not  understand what the concept behind this is.
Agreed that there is some uncertainty regarding need. I took it as: if garage door is closed and, within ten minutes, the alarm is subsequently set. Perhaps I had it backwards. Perhaps you are correct that it was: if garage door is closed withing ten minites of setting the alarm prior.
We will need the OP to chime in here.
First thoughts.
If I close the garage door and turn on the alarm system then I want the garage light to turn  off.
If I close the garage door and don't turn the alarm system on then I am working in the garage, so leave the lights on.
Thanks for the discussion.
I directly need this logic:
If the alarm is armed, and then, within 10 minutes. the garage door closes, turn off some lights
If the garage door closes and the the alarm is armed after that, I don't want any action.
So, as far as I can tell, the logic of having the alarm arming enabling the second program which checks for the garage door closing is exactly what I want.
If you want to know deeper the use case here, my garage lights are on when I'm in the garage based on a bunch of sensors or just being turned on. I open and close the garage as I work on cars, etc, but I don't want the lights to cycle for this. I also don't want the lights to go off just because the alarm was armed, as I need the light in the garage to get to the car. So this logic is here to only turn the lights off when I've left the house and closed the garage door. Why for 10 minutes? Because when I come home and it's cold, I close the garage door before I'm in the house, and I don't want the lights going off because the garage door closed when I arrive home. There's probably some other logic that could work too, but this is what I used in Houselinc for 5 years and it worked great for me.
Edited by pilot
Looks like larryllix wins the prize.  Logic, in English:
alarm is armed
then
enable next program
wait ten minutes
disable next program
else
nothing
next program:
if
then
Alternative approach:
if
alarm is armed
then
wait ten minutes
run this program (else path)
else
nothing
next program
if
garage is closed
and
first program is true
then
else
nothing
ISY always requres two programs when an event is conditional upon two triggers.  While an "if" cluase may contain multiple triggers, only one trigger can create an instance of the program with the other items being conditions, but not triggers of that particular instance.  In this example, we have two triggers, the alarm arming, and the door closing.  This is different than the door closing and the alarm being in a certain state or vice versa.  If a program is running an instance, and one of the other triggerable items triggers, the program aborts and starts over with no regard to the first trigger event.
Only exception to this rule is version 5 firmware where the second trigger  can be inside a "repeat while".  The caveat: repeat while only accepts variables as the object of the repeat while.
In other words, a variable change can be trigger number two within a single instance of a program.  Or, I suppose you could layer repeat while clauses and have cascading triggers.
Edited by apostolakisl
