Devices not responding?
Hi,
As of today, all my echos are saying "Sorry, xxx is not responding" when attempting to turn an ISY device on/off. The portal sees the ISY fine. I've tried rebooting the ISY, turning off and removing all of the ISY skills in the Alexa portal but this continues to happen. Is anyone else having this issue recently? Yesterday, everything was working and there were no changes on my end.
Edited by nathan
I'm getting the same thing too, but it all worked yesterday. Hopefully it's something temporary on the Echo end.
I'm glad you were able confirm. I can stop wasting time poking around now. Thanks!
Fixed, thanks to UDI being so fast B)
Well, not fixed here yet. MobiLinc won’t connect either, but hopefully it’ll get sorted out soon.
Definitely not fixed here either. It has been broken since at least 10AM EST.
As people are pointing out in the portal thread, it seems to be working again. Thanks all!
It’s still not working here. Here is the message I am getting: “Sorry the device that X is connected to is not responding please check it’s network connection and power supply.”
Edited by giomania
Hello all,
Sincere apologies for the inconvenience. One of our servers died and we had to replace it. Everything is back to normal.
Thanks Michel. However, it is still not working this morning here; do we need to do anything to kick start it? [emoji41]
Good thing I still have manual control to fall back on, and it really makes you appreciate the “magical” experience of voice control.
I had the same problem and was able to resolve it by disabling the skill in the Alexa App and then re-enabling it and doing a discover.
Hello giomania,
Please send your error log to support@universal-devices.com . Please include a screenshot of Help/About.
Thanks for the reply, but a power-cycle of the ISY solved the problem.
Power cycle did not work for me. ISY shows offline in the portal since 4:48pm today! Are there portal problems again?
Not here. A offline portal may require that you contact support: https://www.universal-devices.com/contact-support/
I opened a ticket! Thanks
Funny how nothing on my end changes and yet I am the one having to open a ticket! Sounds like residual issues left over from the server failure a few days ago!
A few others have also run into an extended difficulty.
