Program help - open = on, close = on?
Hi,
I am using an appliance link with a shade opener.  I made this program:
Shades2 - [ID 00C9][Parent 0001]
        Set 'Main House / Master Bedroom / Main: MBR Shades' Fast On
        Wait  1 minute
        Set 'Main House / Master Bedroom / Main: MBR Shades' Fast Off
How do I make this a toggle?
I want it that if you turn this program on or off, it turns itself on, waits 1 min, then shuts off.
Rich
If (disabled)
.....status is on
....turn it off
 ....turn it on
Insteon_Controller is any controller such as a KPL button or SwitchLinc or Remote button. Insteon_Device is any On/Off device. Do not use a dimmer.
        Control 'Insteon Controller' is switched On
    And Control 'Insteon Controller' is not switched Off
        Set 'Insteon_Device' On
        Wait  1 minute
        Set 'Insteon_Device' Off
        Wait  1 minute
If you use voice, then On will run Then and Off will run Else. I prefer that On closes the window covering and Off opens it. If you use routines, then you can use Open and Close instead of Off and On.
I use Amazon's Echo. The Alexa smartphone app allow you to create routines to be able to tell the Alexa device to Open or Close the curtains.
2 hours ago, stusviews said:
I am a little confused - I am only using Alexa as the 'control' - no other way to initiate the shades.  My wife is already complaining that it looks like something the father from gremlins would have made.
Can I skip the 'control' if portion?
        Wait  1 minute
        Wait  1 minute
