My systems been in for years working fine except losing the smarthome device and having to replace. But for the last month or so i notice motions not running and check the Isy and find the red led blinking. reset power to it and everything works again for a day maybe up to a week then happens again. Is that a sign of the memory  card going bad? What should i look for? Can i just change it? or is there certain steps to follow? searching i found it to be memory but it doesn't do it all the time.
Jay
Edited by jaycanter
Hi Michel,
It was just the memory light the last time i reset it. I don't remember times before that.
Just when my bathroom or laundry motions don't work i was just unplugging it to reset. Didn't pay attention to the lights thought maybe a fluke.
Yesterday my blinds didn't close and outdoor lighting didn't execute. blinds 1/2 hr before sunset and lights at sunset. I checked there was no error lights. but i used the mobile linc app and run the programs and everything worked.
i just found the error log, Not sure what it means but the date starts around Christmas.
everything is just run together in a text file is there a way to sort it?
also heres some of there errors the last few days
Sat 2018/03/10 02:54:26 PM    System    -170001    [Network-DNS][Task=22]
Failed DNS 1346/rc=6
Sat 2018/03/10 02:54:26 PM    System    -140000    my.isy.io
Sat 2018/03/10 02:54:30 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:54:35 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:54:40 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:54:45 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:54:50 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:54:55 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:55:00 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:55:01 PM    System    -170001    [Network-DNS][Task=22] Failed DNS 1347/rc=6
Sat 2018/03/10 02:55:01 PM    System    -140000    my.isy.io
Sat 2018/03/10 02:55:05 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:55:10 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:55:15 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:55:20 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:55:25 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:55:30 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:55:35 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:55:36 PM    System    -170001    [Network-DNS][Task=22] Failed DNS 1348/rc=6
Sat 2018/03/10 02:55:36 PM    System    -140000    my.isy.io
at 2018/03/10 02:55:40 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:55:45 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:55:50 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:55:55 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:56:00 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:56:05 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:56:10 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:56:11 PM    System    -170001    [Network-DNS][Task=22] Failed DNS 1349/rc=6
Sat 2018/03/10 02:56:11 PM    System    -140000    my.isy.io
Sat 2018/03/10 02:56:15 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:56:20 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:56:25 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:56:30 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:56:35 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:56:40 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:56:45 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:56:46 PM    System    -170001    [Network-DNS][Task=22] Failed DNS 1350/rc=6
Sat 2018/03/10 02:56:46 PM    System    -140000    my.isy.io
Sat 2018/03/10 02:56:50 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:56:55 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:57:00 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:57:05 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:57:10 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:57:15 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:57:20 PM    System    -100    [DHCP] state=RENEW
Sat 2018/03/10 02:57:21 PM    System    -170001    [Network-DNS][Task=22] Failed DNS 1351/rc=6
Sat 2018/03/10 02:57:21 PM    System    -140000    my.isy.io
Sat 2018/03/10 02:57:45 PM    System    -5    Start
Sat 2018/03/10 02:57:50 PM    System    -110022    /DEF/F6/I1/NLS/EN_US.TXT
Sat 2018/03/10 02:57:51 PM    System    -110022    /CONF/UXT.BIN
Sat 2018/03/10 02:57:51 PM    System    -110012    /CONF/UXT.BIN
Sat 2018/03/10 02:57:52 PM    System    -7153    ID 0002 :err=0, tag='/group', num=20, nest=5, o
Sat 2018/03/10 02:57:52 PM    System    -7123    ID 0013 :err=0, tag='control', num=6, nest=4, o
Sat 2018/03/10 02:57:54 PM    System    -170001    [Network] Established
Sat 2018/03/10 02:57:52 PM    System    -80004    n/a
Sat 2018/03/10 02:58:53 PM    System    -5012    26
Sat 2018/03/10 02:58:54 PM    System    -5006    uuid:26
Sat 2018/03/10 02:58:57 PM    System    -5006    uuid:26
Sun 2018/03/11 03:00:03 AM    System    -7153    ID 0002 :err=0, tag='/group', num=20, nest=5, o
Sun 2018/03/11 03:00:04 AM    System    -7123    ID 0013 :err=0, tag='control', num=6, nest=4, o
Sun 2018/03/11 03:57:51 AM    System    -100    [DHCP] state=RENEW
Sun 2018/03/11 10:00:50 AM    System    -170001    [UDSockets] RSub:42 error:6
Sun 2018/03/11 10:07:12 AM    System    -5012    29
Sun 2018/03/11 10:07:15 AM    System    -5006    uuid:29
Sun 2018/03/11 10:07:17 AM    System    -5006    uuid:29
Sun 2018/03/11 03:57:54 PM    System    -100    [DHCP] state=RENEW
Sun 2018/03/11 03:58:29 PM    System    -7153    ID 0002 :err=0, tag='/group', num=20, nest=5, o
Sun 2018/03/11 03:58:29 PM    System    -7123    ID 0013 :err=0, tag='control', num=6, nest=4, o
Mon 2018/03/12 03:57:59 AM    System    -100    [DHCP] state=RENEW
Mon 2018/03/12 01:53:03 PM    System    -170001    [UDSockets] RSub:42 error:6
Mon 2018/03/12 01:53:08 PM    System    -170001    [UDSockets] RSub:42 error:6
Mon 2018/03/12 01:53:13 PM    System    -170001    [UDSockets] RSub:42 error:6
Mon 2018/03/12 01:53:14 PM    System    -5012    31
Mon 2018/03/12 01:53:25 PM    System    -5006    uuid:31
Mon 2018/03/12 01:53:27 PM    System    -5006    uuid:31
Mon 2018/03/12 02:01:42 PM    System    -5    Start
Mon 2018/03/12 02:01:47 PM    System    -110022    /DEF/F6/I1/NLS/EN_US.TXT
Mon 2018/03/12 02:01:47 PM    System    -110022    /CONF/UXT.BIN
Mon 2018/03/12 02:01:47 PM    System    -110012    /CONF/UXT.BIN
Mon 2018/03/12 02:01:48 PM    System    -7153    ID 0002 :err=0, tag='/group', num=20, nest=5, o
Mon 2018/03/12 02:01:48 PM    System    -7123    ID 0013 :err=0, tag='control', num=6, nest=4, o
Mon 2018/03/12 02:01:50 PM    System    -170001    [Network] Established
Mon 2018/03/12 02:01:49 PM    System    -80004    n/a
Mon 2018/03/12 08:40:37 PM    System    -170001    [UDSockets] RSub:42 error:6
Tue 2018/03/13 02:01:46 AM    System    -100    [DHCP] state=RENEW
Tue 2018/03/13 12:55:49 PM    System    -170001    [TCP-Conn] -1/-140002, Portal-Dispatch
Tue 2018/03/13 12:56:29 PM    System    -170001    [TCP-Conn] -1/-140002, Portal-Dispatch
Tue 2018/03/13 05:47:05 PM    System    -5    Start
Tue 2018/03/13 05:47:10 PM    System    -110022    /DEF/F6/I1/NLS/EN_US.TXT
Tue 2018/03/13 05:47:10 PM    System    -110022    /CONF/UXT.BIN
Tue 2018/03/13 05:47:10 PM    System    -110012    /CONF/UXT.BIN
Tue 2018/03/13 05:47:11 PM    System    -7153    ID 0002 :err=0, tag='/group', num=20, nest=5, o
Tue 2018/03/13 05:47:11 PM    System    -7123    ID 0013 :err=0, tag='control', num=6, nest=4, o
Tue 2018/03/13 05:47:13 PM    System    -170001    [Network] Established
Tue 2018/03/13 05:47:12 PM    System    -80004    n/a
Tue 2018/03/13 08:08:58 PM    System    -5    Start
Tue 2018/03/13 08:09:03 PM    System    -110022    /DEF/F6/I1/NLS/EN_US.TXT
Tue 2018/03/13 08:09:03 PM    System    -110022    /CONF/UXT.BIN
Tue 2018/03/13 08:09:03 PM    System    -110012    /CONF/UXT.BIN
Tue 2018/03/13 08:09:04 PM    System    -7153    ID 0002 :err=0, tag='/group', num=20, nest=5, o
Tue 2018/03/13 08:09:05 PM    System    -7123    ID 0013 :err=0, tag='control', num=6, nest=4, o
Tue 2018/03/13 08:09:06 PM    System    -170001    [Network] Established
not sure if i have a recent backup i usually don't think about the isy since it just runs. might have 1 from when plm was replaced 6 months ago. Can i just do a backup and replace the card?
