Time based event
I would like to get my bathroom lights to turn on at 90% during the day (i.e. 7am to 10:30pm) and after that I would like the lights to turn on at 40% on a push of the switch or a KPL on my nightstand.
Help
Josh
Hi Josh,
What you need to do is to make a program with and use From To in the condition. You will find this link very useful:
https://www.universal-devices.com/mwiki ... _a_Program
Help
Josh
Here is what I came up with. The light will only
come on at 30%. What am I doing wrong?
From 11:00:00PM
For 8 hours
And Control 'Master Bath' is switched On
Or Control 'Master Bath' is switched On
Set 'Master Bath' 30%
Set 'Master Bath' 90%
Josh
Hi Josh,
The main issue is that you are trying to control something that is already being controlled by the switch itself. So, at best, you will have a flicker and at worst it won't work.
Also, you only need "And Control Master Bath is switched on" ... get rid of the Or.
From 11:00:00PM
For 8 hours
Josh
