admin console would not fire
Hello, I am using my work PC to configure my ISY and apparently some new update was pushed and I cannot get the admin console to pop up.
- ISY994i is on, and I can control stuff through Mobilink and online (ISY web access)
- v 4.6.2
- java re-installed, cache cleared.
- using portal, but I am actually home and connected to local network (isy is on it)
- find my ISY on universal device web does not yield anything
- admin console icon on my desktop does not seem to trigger anything.
I apologize for the silly question- I've been trying for 3h now and could not get anything to work. Suggestions?
Thanks !
Denis
Thanks. I don't even get there... Step 1 : Bring up the ISY Finder by using the ISY994 icon on your desktop (installed by this link)
does not work. I do get the icon, but absolutely nothing happens when I click on it. Usually it re-downloads the applet (after you have cleared the cache) and then starts the blue-background ISY console. Here: NOTHING.
Denis
The change to your system you mentioned could be in the firewall/virus software. That can cause the symptoms you are seeing.
You address that with the firewall/virus software by letting it accept the ISY as ok to run.
Before trying your step 1, look at the firewall/virus package you have and make the suggested changes, before you try to launch the finder/admin console.
Paul
Thanks. I found the root cause... went into Windows admin console and found 20+ instances of the ISY finder... For some reason:
- the windows were hidden
- there was no tab at the bottom of the screen.
Could maximize the window in the Windows admin console and take it from there.
Sorry for the firedrill....
Denis
Denis
Better you than me. :) Glad you found it. We all learned from this for next time.
