Updated Nodelink on server - now get "Warning: Nodesetup.zip needs updating on ISY"
As stated, getting "Warning: Nodesetup.zip needs updating on the ISY" appearing at Nodelink startup (all other startup messages look normal).
Replaced "Nodelink.exe" with the newer version of same I just downloaded, restarted ISY (twice), restarted Nodelink a time or two, still says this in the DOS Nodelink window at nodelink startup.
Where do I find the updated "Nodesetup.zip", and how do I update it?
ISY seems to be reading Venstar and Rainmachine data normally though (?)
10 minutes ago, io_guy said:
Hit the button on NodeLink's Devices page.
Well that was easy... Should have looked a little harder.
Thank you!
By the way - thank you for adding the dehumidification parameters. Big help in my situation.
