Repeater Recommendations
Appears I need a zwave repeater to communicate between the basement and family room located a floor above/across.  What are you folks recommending that works with 5.0.12?
Thanks in advance.
Thanks guys appreciate the recommendation.  Has anyone had experience with the Aeotec Range Extender 6, Z-Wave Plus repeater?
Using the search tool at the top right you’ll find numerous discussion on why the siren is preferred over the range extender
You will find some people found the range extender you mention to be equal in performance to the siren. A repeater that also functions as another device gives you the possibility of using the same device for two tasks. Without a doubt the Aeotec siren has performed well for many on this forum, including me.
Sent from my XT1650 using Tapatalk
I do know the (original) Aeotec repeater did nothing for me, while the siren worked wonders.
I cannot speak for the newer repeater.
Personally, I’d go with the proven device that also has a siren capability rather than the device that serves no other purpose.
