ISY Icon
Grizzy
53 minutes ago, Grizzy said:
Recently I did a reload on my pc ... Running Win10
How do I get the ISY icon instead of the Java Coffee Cup ?
I did see an option for that somewhere. I am guessing it was in the java control panel somewhere.
Right click on the icon, go to Properties and then click on Change Icon... If it doesn't show you may have to browse or search for whatever icon you want.
Try hiding the Java console
Assuming that you have java set to cache locally, The globe/house shortcut icon will be created the first time you run the console via java coffee cup icon.  The Globe/house points to the cached version of the admin console.
If that didn't happen, clear the java cache again and then rerun the admin console coffee cup icon from your desktop. The Globe/house should appear.
Since the globe/house icon points the newly cached version of the admin console you can simply delete the java coffee cup file, it no longer has a funciton. Since the AC can easily be downloaded, there's really no reason to keep that file. I normally delete it.
I looked for that and it does not have an option to change icon
Tnx
worked perfect ??
      37.6k
      376.3k
