Update Failure
AnthemAVM
I am giving Agave a try after using Mobilelinc for many years.  I have it loaded and it pulled my stuff from the ISY.  When I try a switch it just gives me a message of a update failure.  Any thoughts would be greatly appreciated.
Did you set it up through a LAN or on an external address?
Are you using a vpn?
What version are you using?
Did you set it up through a LAN or on an external address? I am using the ISY Portal
Are you using a vpn? No
What version are you using? 5.0.11C
Thanks very much
Thanks very much
Is your trial still running?
Did you setup a preferred ISY on the portal?
Hi James,
It tells me that I have full access, let me go back and make sure it is primary.
On the ISY Login Settings, do I need to put anything?  Enable Portal Access is grayed out.
Just now, AnthemAVM said:
Hi James,
OK.   This helps a lot.  This tells me the Trial is expired and you have purchased the Extended access level.  If Portal is grayed out, then it is not enabled.  Portal is an additional addon with the Extended and basic access levels.   http://agaveha.com/packages/
Thanks, just made the purchase for the ISY access.  Thanks and sorry for missing that.
no problem.  let mew know if anything else comes up.
