Unable to delete scene
I have a scene that I am unable to delete.
When I try, I get:
Error
No network connection
[[DHCP] state=RENEW]
After backing up, and through the resulting zip file, I found the description within a file named 83.UND
Is there a way to delete the scene?
When I try, I get:
Error
How are you trying to delete the scene?
What devices are in the scene?
Did you right click on the scene then click delete?
Deleting via selecting the Scene on the Main tab under the grouping titled "Network" > Right Click > Delete.
There are no devices in the scene
It does not appear to be in any folder, but rather at the "root" of "network"
The scene is the last scene in the list of 16 scenes.  Its address is "ADR0001" which seems odd compared to the other scenes which seem like random numbers
Additionally, when I click on "Network" which then shows a list of device names, states, addresses and type, I have a very odd item in the list.  I took a partial screen shot and attached it.
Might I have some corruption in the file system of my ISY 994i/IR PRO?  This problem has been with me for several upgrades of the firmware (currently at v.4.6.2)
Kind Regards,
Brad
Thank you Michel:
I've learned "You cannot delete ADR001 scene. This is a factory installed scene required for OpenADR functionality (if enabled)."
Kind Regards,
Brad
