Added new scene to ISY - Not Discovered in Alexa App
It's been a while since I've done more than replace a device.  I just installed a new Insteon 2477d.  Created device in ISY (v4.2.6).  Created scene and added device as Controller.  Device responds to OrchMobilLinc v4.16.  Running Alexa Portal V.2.  Tried Discover Devices from both iPhone Alexa app and online Alexa interface.  Device/Scene does not show up.  Did I miss a step?  Thanks, Gary
Did you add the new device to the Amazon echo device list in the Isy portal?
No.  I don't remember how to do that.  Where do I find that?  Via what interface?  Thanks for your quick response!
1. Log into your Isy Portal
2. In the "Select Tool" drop-down menu select "Connectivity".
3. Then select "Amazon Echo".
4. Then click on the 'Device" tab in the "Add" ribbon.
5. Select the devise you want to add from the drop-down menu.
