taskman Posted April 18, 2009 Share Posted April 18, 2009 Hi, Exporting the ISY data and importing into ELK there is an "OPT" Flag. Access is through their Ethernet. It says it eliminates built in delays between multiple lighting commands on serial port 0. NOt on x10 interfaces or M1XSP. Not really sure what to do on this one? Thanks for any insight.... Link to comment Share on other sites More sharing options...
Michel Kohanim Posted April 19, 2009 Share Posted April 19, 2009 Hi taskman, Please check all the Opt flags for all your INSTEON imported devices. This is done in ELK RP|Lighting panel. If you do not have these flags set, you will experience lights intermittently turning on/off by themselves. With kind regards, Michel Hi, Exporting the ISY data and importing into ELK there is an "OPT" Flag. Access is through their Ethernet. It says it eliminates built in delays between multiple lighting commands on serial port 0. NOt on x10 interfaces or M1XSP. Not really sure what to do on this one? Thanks for any insight.... Link to comment Share on other sites More sharing options...
taskman Posted April 19, 2009 Author Share Posted April 19, 2009 Hi, Ok, that's what I have. Thanks Link to comment Share on other sites More sharing options...
