IF Statement based on amount of time
I want to make an if statement that goes like this
if doorlock is open more than 5 mins then do something.
How do I do the 5 mins part?
Add a "Wait" to your first line in the "Then"
Sent from my XT1650 using Tapatalk
Use Wait, as dbuss suggests. You can also combine that with a repeat statement to keep the reminder coming at regular intervals. It will stop once the door is closed
if
   door is on
then
   wait 5 minutes
   repeat every 5 minutes
         send notification 'xxxxx"
As per Paul's sample program above....
When the door is first switched ON, run the Then section until it finishes.
However if the door lock ever becomes NOT ON, then quit running Then at the next Wait or Repeat, and start running Else, code or not.
if
   door is on
then
   wait 5 minutes
This is what I want.  I think.  So if I forget to lock my door and its open for more than 5 mins then send me a notifications.
With the "repeat" statement, what exactly is it repeating.  Is it looping the whole if statement?
Just the indented line underneath it. If more lines followed they would all be indented and repeated  until another "repeat 1 times" is found.
Got it.  Thanks.
