Elk-ERR
I am 100% Insteon but recently ran a log report and find many errors, each saying: [ELK-ERR}]    Get Topology. They pop up 3 at a time every 6 minutes consistently.   I don't have any ELK products.   Any ideas what's going on?
Michel:
Thanks for the reply.   I checked  "Disable..." in the Elk config as you suggested.  (It was clear before)   But I was  unable to save it.   I did close the program and restarted it and continue to get the error messages.  I've attached a screen shot of the ELK page.
-Jack
  • 4 months later...
I have the same issue as described above and don't have ELK enabled.
I find these errors are hanging the system several times a day and yes it only last 10 or so seconds each time. I concerned
something else is running that is slowing the system or worse.
ES1400.
  • 1 year later...
I found this old post when I was experiencing the same errors in the event log. In my case, it turned out that I had external services (HomeBridge and a custom script that I wrote) that I migrated from my old house (and old ISY that had an Elk) that had 'elkEnabled' set to true in their config, so they kept querying /rest/elk/get/topology, which causes this error if Elk is not enabled on the ISY. Turning this off solved the issue for me.
