Amazon ECHO and Insteon Help
My insteon hub died and it was replaced. The old account was deleted and all devices re-added with their Insteon ID's. Schedules/scenes working as before. Skill in alexa was disabled and old devices/scenes/groups deleted. Skill enabled and devices discovered, but when I select a light switch it a "there was a problem" banner at the top of all insteon switches/lights and they do not function. When I ask alexa to perform a function it says "ok" but doesn't actually control the device. I also can't control the device within the Alexa app. It appears to turn items on/off in the device interface screen, but the actual light does not turn on/off.
Have tried to turn "switches" into "lights" but no change. Have disabled/re-enabled skill several times and re-deleted and added items from the beginning.
All worked well before hub died about 1week ago.
Any help much appreciated!!!
Are you sure you're posting in the right place?  This forum is all about the ISY controller for Insteon, not the Insteon hub...
