Scene does not complete all elements with Echo
I have an Isy scene that triggers 6 different dimmers. That scene works fine with my Echo except for one Insteon dimmer. That specific dimmer won't turn on or turn off even if I repeat the Alexa command.  I have double checked (in the administrative console) that that dimmer is part of the scene, and that scene works fine with dimmers that act as a controller for that scene. Is there some kind of limits on how the Echo or the Isy Portal handles elements of a scene? Suggestions would be appreciated.
Try to turn on/turn off the scene from the admin console. This is essentially what the echo does when turning on or off a scene.
Benoit
That was a great suggestion as the same dimmer did not fire. I rebuilt the link in the scene and now everything works as it supposed to. Thank You
