NodeLink and CAI WebControl 8 small issue
Can you enable verbose on the log windows and in the System Config tab and try the command?  Want to see what the ISY is sending.
Hello @io_guy, I found the issue.
First I needed to understand what was "verbose". In the older version , there was a nodelink selection option to enable verbose mode. Very easy to find. Now this option no longer exists. Or I can't found.
In the past I used nodelink in Windows 10. However, after version 0.9.13, it was not possible to use it anymore. There was a message that the http server could not be opened. For this reason I use a Raspberry Pi.
I realized that I only had the signal from RP2 to ISY, but there was no answer in the opposite side. The IP address on the Node Server configuration was wrong. Now everything is working perfectly.
Thank you,
Ronison
The Windows 10 issue was likely caused by changes in 0.9.11:
