Replacing dead PLM for my 994iz - Procedure?
Want to make sure I don't screw this up - my PLM (2413s) was fried by storm - totally dead.
I've had this same PLM for about 10 years I think, been fine until now so I've never had to do this.
Have another on the way, but want to make sure I go about replacing it via the Admin Console the right way, so links to old PLM get wiped, and all those same links are properly written to the new PLM and I have no other issues.
Do I "Restore PLM" first or "Delete PLM" first?
Any guidance would be appreciated!
Have a look here.
39 minutes ago, Bumbershoot said:
Have a look here.
Thanks!!
I assume nothing has changed regarding this process in the 11 years since this was posted?  That was a concern, given I'm on the beta / 5.0 etc... ISY FW.
14 minutes ago, telljcl said:
Thanks!!
Not that I'm aware of, but admittedly, I'm still on my original PLM from 2015 so I've never swapped mine out.  I understand that you might not want to issue a "Delete PLM" command, as you'll get a new PLM with no links at all when you eventually do the "Restore PLM".
NEVER do a delete PLM.
It's also a good ideal to do an ISY backup before you replace the PLM.
Attached is the detailed PLM replacement guidelines.
Replace ISY PLM.pdf
Edited by Techman
Replace ISY PLM.pdf
Thank you - appreciate the .pdf and additional explanation.
