Replaced PLM - All good except MorningLinc Lock control ?
Replaced PLM via advice posted here - thanks.
Did RF devices one at a time, and though seems like It took 2-3 tries for a number of them, they all finally worked.
But I still have the green "II00" symbol over the MorningLinc lock control in the Admin Console. Clicking the "Write updates" the progress bar shows up for about 30 seconds but nothing ever happens, status of "II00" symbol doesn't change.
I have the old MorningLinc unit, if that matters.
I know the MorningLinc unit is linked to the lock itself, but that hasn't changed - only a new PLM, which I assume only communicates with the Morninglinc module itself, and not the actual lock.
Any ideas?
I remember having the same issue. I think even though mine still had the I0I0 symbol in front of it, it would still work if I were to control it via the console.
But I believe I had to remove it from the scene and then remove it from the ISY and then re-link for it to get to work. I don't know if you tried "restore device" yet and whether that produced results? If not, remove and then re-add to ISY and that should clear up the issue.
