Zwave Motion triggering
Can quite figure out how to do this.
I have 2 Zwave switches and a Aeotec motion sensor.  I have the motion program turn on both switches and turn off after 5 minutes.  The problem is if the switches are manually turned on and would like them to stay on until manually turned off, Once motion is triggering the switches and then turns off after the 5 minutes.  So what I would like is if either one or both of the switches are already on to ignore the motion activation for the switch or switches that are already on.
THANKS FOR THE HELP
Since you're using programs for your motion sensor, simply created a program that disables your motion program when you manually turn on your light and re-enables them again when you turn the light off
Lilyoyo.
Can you give me an example. Not sure how to write program for that. Here is what i have.
control 'motion sensor /zw 006 motion sensor' is switched on
and from sunset
to sunrise (next day)
then
Set 'garage lights-switch' on
set 'porch light switch' on
wait 5 minute
set 'garage lights-switch' off
set 'porch light switch' off
else
no action
