Feature Request for Autumn Development: Elk Thermostat Support
giesen
I know you're looking for feature requests now that summer is over, so I'd like to submit a request for Elk-attached thermostat support. Elk supports several thermostats directly, including Aprilaire, RCS, HAI and Z-Wave thermostats. As far as I know, they are all exposed by the ISY (certainly my Aprilaire thermostat is)
The API is here:
https://wiki.universal-devices.com/index.php?title=ISY_Developers:API:REST_Interface#Thermostat_Commands
Relevant section from
/rest/elk/get/topology:
<topology>
  <tstats>
    <tstat id="1" name="Main Floor"/>
  </tstats>
</topology>
Instruct ELK to query the thermostat:
/rest/elk/tstat/1/query
<RestResponse succeeded="true">
  <status>200</status>
</RestResponse>
Retrieve the status of the given thermostat:
/rest/elk/tstat/1/get/status
<status>
  <te type="191" tstat="1" val="1"/>
  <te type="192" tstat="1" val="0"/>
  <te type="193" tstat="1" val="0"/>
  <te type="194" tstat="1" val="19"/>
  <te type="195" tstat="1" val="22"/>
  <te type="196" tstat="1" val="22"/>
</status>
Set the heat/cool mode to auto:
/rest/elk/tstat/1/cmd/1?value=3
</RestResponse>
Set hold temperature to on:
/rest/elk/tstat/1/cmd/2?value=3
</RestResponse>
Set fan to on:
/rest/elk/tstat/1/cmd/3?value=3
</RestResponse>
Set the cool setpoint to 23C:
/rest/elk/tstat/1/cmd/5?value=23
</RestResponse>
Set the heat setpoint to 20C:
/rest/elk/tstat/1/cmd/6?value=20
</RestResponse>200
Let me know if there's anything else you require, or if you need access to my system for testing.
The API is here:
<topology>
  <tstats>
  </tstats>
</topology>
</RestResponse>
<status>
</status>
</RestResponse>
</RestResponse>
Set fan to on:
</RestResponse>
</RestResponse>
</RestResponse>200
Great info.  I've been wanting to do this for a while.  I'll see if I can get this added to the schedule.
