GoControl GC-TBZ48 Z-Wave Thermostat - Not adding properly
I bought a GoControl GC-TBZ48 Z-Wave thermostat.  I tried adding it and it keeps adding as a lightbulb, not a thermostat.  I'm going to attach my event viewer of the Add process.  I'm about 10 feet away from the ISY, so distance shouldn't be an issue.  I did a factory reset on the thermostat just to be sure.  No help.
ISY Firmware: v.4.7.3
ISY UI: v5.0.4
Z-Wave module installed (Z-wave color LED lights work fine)
Any thoughts?
ISY-Events-Log.v4.7.3__Sun 2018.09.23 05.09.05 PM.txt
With your firmware and UI both being different, that may be playing a part in things. Remove the thermostat from your Isy, clear the Java cache on your computer and then re-add the thermostat to your Isy. Make sure you are using the UI for 4.7.3.
That did the trick. I had completely forgotten that the UI was supposed to match the firmware.  Thanks for the help!
