Help with program at sunset to sunrise W/ Open Close
Hi Guys, Gals
I have a simple program that turns my hall light on from sunset to sunrise when either my front or basement door opens and will shut it off after 2 minutes.
 Everything works as I would like except if I have my front door open (for light or fresh air) when it hits sunset the light comes on. Although it's not a big deal I would prefer to make it somehow that if the door is actually open at that time to not come on unless it were closed & open again. I don't see the basement door being open at times but the front is very likely especially with fall being here.
Any thoughts if there is a creative way to make this happen? I can see this being useful for my rear outside light also with my sliders. Program is very similar.
Hallway Auto Light - [ID 0021][Parent 0001]
        From    Sunset  +  1 minute
        To      Sunrise -  1 minute (next day)
    And (
             Status  'Front-Door / Front Door-Opened' is On
          Or Status  'Basement Stairs Door-Opened' is On
        Set Scene 'Hallway Auto Light' On
        Wait  2 minutes
        Set Scene 'Hallway' Off
Stan
Edited by sdynak
1 hour ago, sdynak said:
Hi Guys, Gals
    And (
        Wait  2 minutes
Stan
When the time frame triggers Then or Else (it triggers both) the door logic is also true causing Then to run.
Time frame logic is a combination of status and edge trigger, making it a dual purpose logic condition. It can act like a status condition for another  trigger (passive) , as well as trigger on both nodes (active).
Use Control/switched logic instead of status logic. Then the If sensing logic can be true only when the sensors are initially switched On . Sensor status would be true during the whole time the door is open.
    And (
             Control  'Front-Door / Front Door-Opened' is Switched On
          Or Control  'Basement Stairs Door-Opened' is Switched On
        Wait  2 minutes
Thank you Larry! I was thinking it was more than that... glad overall it would be simple although for me I wasn’t sure but thought there had to be a way..
 You just made a few of my programs feel a ton better
Thanks again
Stan
Not trying to hijack the thread, but wondering Larry if you or someone else knows if there’s a similarly elegant way to do this if using Elk zones as triggers? I have a similar problem that I haven’t tackled (nor attempted in earnest) since I assumed it would require extra programs and what I have works and is complicated enough for now. As I understand the Elk zones essentially are evaluated as Insteon “status” rather than “control”
Use two programs. The "control" triggers wanted are installed in the first program. It's "Then" calls the second program.
The second program must be "disabled". Here is where you put your elements you do NOT want to cause any triggering that could cause restarting, stopping or running Else.
Note: Program Disable only disables triggers in the program and doesn't stop it running. The program becomes similar to  linear program coding.
Thanks. So then I figure I’d have the Elk zone in the first program and have the then section call the IF of the 2nd (disabled) program that would have the time condition? I can probably handle that [emoji851]
So although this change in program would resolve the initial issue it seems it introduces another.. Now with the control being set as the trigger, after set time in wait in else statement the lights do not shut off. Actually, I do not even see the program turn red as it has before when in countdown. It seems to skip over the else now.
 Any thoughts?
Stan
 Any thoughts?
Stan
Sorry. An update was missed fixing the other part. :)
    And (
        Wait  2 minutes
Else        <---- still need this for the end of the time frame. ie: Sunrise - 1 min
      Wait  2 minutes
Thanks again Larry! I'll update it and see how it goes.. How do you know all this stuff :)??
Edited by sdynak
It started out in 1964 with two 12 foot long 2 x 4s and a logarithm chart trying to build a slide rule that would yeild four digit accuracy (felt pens are not fine enough). Then in 1971 when the 8 bit CPU, expandable to  of 384 bytes, was released, and digital computers for the average person became possible, many addictions started :)
FWIW you can make a folder in the programs area and have it run everything inside during a specific time - sunset to sunrise. So the folder can have outside patio lights turn on off etc too.
Edit: Or as Larry would say in Canadian “it helps keep things organised” [emoji23]
Thanks.. I do have a lot of folders organizing rooms itself with the milti devices in each. Don't use times with them yet but good to know.
I think @Scott was referring to folders for programs. His American accent can be hard to read sometimes. :)  Both (not Scott and me) can have folders. I organise my device folders by rooms and my program folders by function.
Sorry. Too much HA in my life and I get crazy.....or so Scott would have you believe.
10 minutes ago, paulbates said:
See that's another difference: You organise your folders, and Scott organizes them
I don't understand the last part of the sentence so I don't know what it was all aboot.
