Error 'Not Implemented' after upgrade
After almost 10 years of using the ISY994i and recently upgraded to the isy994i ZW/IR Pro. To get it going, I simply restored my backup from the ISY994i to the new ISY994i ZW.  .  Seems to have worked. Devices and program are there and seems to work except that I keep getting an error pop-up saying 'Not Implemented'. I also seem to get an error when the main programs folder is opened from the programs screen. Programs within the folder seem to be working be working without the error.
Searching the forum I read that the UI version and ISY version need to match however the latest versions seem to be out of sync and do not match.
At a loss and hoping someone can provide some direction.
Thx
Thx
What is the ISY firmware and UI versions?
Are you using the new ISY launcher?
Hi,
UI version is UD 944 v 4.7.3
Firmware is v5.0.13
Also, turns out my programs are not actually working.
Hi,
Firmware is v5.0.13
You are going to need to fix the version mismatch. It’s very important to use a matched UI and Firmware.
