Scene vs device dimming voice control through Alexa
So normally if I have a single device, I just leave it as a scene and give it a voice name.
However when you have multiple switches in a scene (a 3 way setup) how would you then also go about dimming?
You can't dim a scene so then you have to create a different name for the specific device/switch and dim it specifically, but then the other switches/status is not in sync (don't reflect the on/dimmed status)
What is the best way to handle this?
I am using the mobilinc portal but it seems the same thing applies there. I have always been trying percentages not just set to dim (I don't know what that would result in) so I'll try it later.
It works out to 9% change per dim/brighten call to a scene through the UDI portal.  I'm not sure if that triple pulse also works with mobilinc - it may just be 3% each.
