NodeLink: Raspberry Pi Install Script
Thanks... That fix allowed me to install NodeLink on my raspberry.
Now that I have it installed, I am running into a few setup issues!
1 - I have a DSC alarm and an EnvisaLink 4 board.  In NodeLink when I set up the DSC device I entered the password I use for logging into the Eyezon.com site... is this correct? (Given that it's not the EnvisaLink 3 board I assume I can use the full password as opposed to the first 6 characters.... although I tried using the first 6 also).
2020-06-18 15:38:40 - DSC: EVL User Login - Password Incorrect [dsc1]
2020-06-18 15:38:40 - DSC: If using a 2DS or EVL3 only enter the first 6 characters of your password [dsc1]
2 - I also have 2 Venstar ColorTouch Thermostats and I am having trouble setting up both of these! I initially tried to install both together, but then I deleted them and only tried one!
I added the device and on the device's tab I entered the local address. On the raspberry I see the following error:
2020-06-18 15:50:29 - Venstar: Get Error - Invalid URI: The hostname could not be parsed. [ven1]
I then restarted NodeLink and got the following message when it restarted:
2020-06-18 15:54:06 - Venstar: Get Error - Connection refused [ven1]
Note that I am trying to do this remotely! I am using PuTTY as my raspberry terminal; a browser for NodeLink and the Admin Console for the ISY. I don't think that this should be an issue but I am throwing it in, just in case it does impact something!
You have to enable the local API on the thermostat before you can connect to it.  You can find it in the touchscreen menus.
The password for the EVL is not the same as the online account. I think the default password is ‘user’.
@Bumbershoot    Hmmm! I guess that's hard to do remotely!! I looked at the online access using Skyport Cloud and I can't see anywhere to do this... so I will have to wait until I return on site to make that change. I deleted the device from NodeLink until then.
@gzahar    Thanks... the default password worked!! After entering that  password I am no longer getting the incorrect password error.
However, on the ISY the nodes are not providing much info, other than the heartbeat! I did not delete the original nodes on the ISY and they seemed to populate properly in NodeLink in the Alarm tab when I added the DSC device. When I looked at the ISY in the DSC Alarm node the only fields with values are Heartbeat(1 or -1), Panel Trouble (0) and AC Trouble (0)! The Partition 1 node has no fields populated!
In NodeLink I clicked on "Install ISY Nodes" and interestingly this kills the NodeLink Server on my Raspberry! Yet it did nothing on the ISY! On the Raspberry, rebooting no longer restarts the NodeLink Server even though the command is still in rc.local! I have to manually enter the NodeLink command to start the server again! I had to reinstall NodeLink to get the Raspberry to start NodeLink on a reboot!
Any thoughts on how I get the DSC nodes properly set up on NodeLink? Should I delete all of the existing nodes before I set up the DSC device?
A log file wouldn't hurt, debug level on DSC tab and System Config.
I have debug set on the DSC tab and System Config.
I rebooted my raspberry and then had to manually restart NodeLink
I assume that the log file is the one in the node subdirectory... which only had these 3 lines:
2020-06-18 23:53:13 - ISY resolved to 10.0.1.19 ()
2020-06-18 23:53:13 - ISY Node Server config detected (profile 1)
2020-06-18 23:53:15 - ISY Warning: Duplicate node names exist on the ISY (Home)
Is there another log I should be running?
You didn't enable either debug.  We need to see what's coming from the DSC and what's going to the ISY.
You access the Local API from the WiFi button on the touchscreen.  There's nothing in the Skyport Cloud menu's...
@io_guy... I had set debug on the 2 tabs you asked... however, I guess I also needed to set the 'File Logging Level' on the main tab to Debug also!
I have attached the log file. Is this what you need? (attached is the original log file and a pdf version which I think is a bit more readable)
Let me know if you need something else.
logfile_2020-06-19.txt
logfile_2020-06-19.pdf
@Bumbershoot... thanks. Since I am doing the setup away from the physical thermostat, I will only be able to do this when I get back on site.
That log file shows all the zone values being written to the ISY properly.  Try deleting the nodes from the ISY and re-installing them.  If that doesn't work it's a UDI problem.
@io_guy... Okay thanks.
I deleted all the nodes and the node server config with the ISY. I then rebooted the ISY,  and manually set up the node server. Then I started the Raspberry and NodeLink populated the nodes on the ISY... however, the Partition 1 node still has nothing in any of the fields and the DSC Alarm node only shows the heartbeat, AC Trouble and Panel Trouble both as 0!
I have an ISY at my vacation home which I upgraded yesterday to v 5.0.16C (my home one is still on v 5.0.11). I also did a fresh install of Buster on the vacation home Raspberry and installed NodeLink. I setup my DSC Alarm, my Venstar Colortouch,  the Relay Server and the Addl ISY Data nodes. It all worked smoothly!
So, when I next go home,  I'm going to reinstall  Buster on that Raspberry , using the image from my vacation home raspberry. I am also going to upgrade the ISY to v 5.0.16C and then install NodeLink. Hopefully this will resolve my issues!
As an aside... I really like the features in the Relay Server that allows me to restart NodeLink or reboot the Raspberry from the ISY!  This allows me to automatically run an ISY program to reboot the Raspberry when an automated update doesn't happen! Very cool!
The Additional ISY Data is also nice! I will have to figure out how I can best use the Ontario Time-of_Use node when we are out of this pandemic and the hydro price rates for the periods are different again. The Date Variable info is also nice and allows me to delete a bunch of programs I had calculating them or setting them up as variables.
Question:  does the Location Tracking node provide the same functionality as the Portal's Occupancy node or is there more to it?
I don't use polyglot or the portal so I don't know.
The point of the location node was to use something like locative or tasker to send an http message when they get near the house.  The node would then send the status in the ISY.  I haven't done much with it since I'm not a real fan of location tracking based automation.
Try the ISY upgrade before wiping your Pi, based on the log this looks like an ISY issue.
This morning, I reinstalled NodeLink on the Raspberry again and, interestingly, now all of the Alarm nodes on the ISY are now populating! (including Partition 1 and the DSC Alarm nodes)!
 However, the NodeLink startup command in rc.local doesn't seem to work! I have to start the server manually! So it appears that something on the Raspberry is not working right! I tried to redirect rc.local errors to a log error file but I am not getting anything and I checked other log files for issues without success! So I am still thinking that a fresh Buster install might be a good idea...
I'm back at my home for a few days so I upgraded my ISY to v 5.0.16C and I did a fresh Buster install on my Raspberry (I actually used the image from my cottage Raspberry). Then I installed NodeLink. Now the nodes all look correct with one exception... My Partition 1 node was showing the Ready field as False when it is in fact green and ready... and now it's showing the Ready field as a blank value! My cottage system shows the Ready Field as True!
On my home alarm system I have one zone always by-passed which allows the Ready to go green on the keypad... could this be causing the issue?
My 2 Venstar ColorTouch Thermostats are now reporting fine, once I enabled the Local API setting.
Edit: I should have mentioned that despite the Ready state in the Partition 1 node showing as either False or just blank, I was still able to Arm the alarm from an ISY program
Edited by GDavis01
Clarification...
I can't help if you don't post a verbose log.  I need to see what data is coming into NodeLink.
@io_guy...
Quote
You would think  that I should have figured that out by now!!
Do you prefer the log as an attachment or right into the body of the reply? I'm going to put it in the body now... Before copying the log, I rebooted NodeLink and then briefly opened our front door. The ISY is now showing the Ready status as 'False'.
I also see in the log that I am getting a number of Venstar: Get Error - Timeouts! Is this normal?
Here is the log:
2020-07-10 09:52:09 - ISY resolved to 10.0.1.19 (5.0.16C)
2020-07-10 09:52:09 - ISY Node Server config detected (profile 1)
2020-07-10 09:52:10 - ISY Warning: Duplicate node names exist on the ISY (Space Temp)
2020-07-10 09:52:10 - ISY Warning: Duplicate node names exist on the ISY (Runtime)
2020-07-10 09:52:10 - ISY Warning: Duplicate node names exist on the ISY (Home)
2020-07-10 09:52:11 - DSC: 5053CD[C][L] [dsc1]
2020-07-10 09:52:12 - DSC: 505 - Login Interaction (Password Requested) [dsc1]
2020-07-10 09:52:12 - DSC: EVL User Login - Password Sent [dsc1]
2020-07-10 09:52:12 - DSC: Connected to 10.0.1.18 [dsc1]
2020-07-10 09:52:12 - DSC: 5000052A[C][L]5051CB[C][L] [dsc1]
2020-07-10 09:52:12 - DSC: 500 - Command Acknowledge (005) [dsc1]
2020-07-10 09:52:12 - DSC: 505 - Login Interaction (Password Correct, Session Established) [dsc1]
2020-07-10 09:52:12 - DSC: Status Request Sent [dsc1]
2020-07-10 09:52:12 - DSC: Data Sent - 00191 [dsc1]
2020-07-10 09:52:12 - DSC TCP: Polling DSC [dsc1]
2020-07-10 09:52:12 - DSC: 50000126[C][L]61000128[C][L]61000229[C][L]6100032A[C][L]6100042B[C][L]6100052C[C][L]6100062D[C][L]6100072E[C][L]6100082F[C][L]61000930[C][L]61001028[C][L]61001129[C][L]6100122A[C][L]6100132B[C][L]6100142C[C][L]6100152D[C][L]6100162E[C][L]6100172F[C][L]61001830[C][L]61001931[C][L]61002029[C][L]6100212A[C][L]6100222B[C][L]6100232C[C][L] [dsc1]
2020-07-10 09:52:12 - DSC: 500 - Command Acknowledge (001) [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 001) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 1 ((Z01) Front Door)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 002) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 2 ((Z02) Door to Garage)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 003) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 3 ((Z03) Door to Upper Deck)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 004) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 4 ((Z04) Basement Door)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 005) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 5 ((Z05) Garage Door #3)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 006) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 6 ((Z06) Garage Door #2)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 007) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 7 ((Z07) Garage Door #1)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 008) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 8 ((Z08) Garage Exit Door)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 009) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 9 ((Z09) Laundry Glass Break)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 010) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 10 ((Z10) Office Glass Break)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 011) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 11 ((Z11) Kitchen Glass Break)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 012) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 12 ((Z12) Great Rm Glass Break)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 013) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 13 ((Z13) Powder Rm Glass Break)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 014) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 14 ((Z14) Basement L Glass Break)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 015) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 15 ((Z15) Basement C Glass Break)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 016) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 16 ((Z16) Basement R Glass Break)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 017) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 17 ((Z17) Motion Front Door)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 018) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 18 ((Z18) Motion Kitchen)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 019) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 19 ((Z19) Motion Great Rm)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 020) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 20 ((Z20) Motion Basement)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 021) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 21 ((Z21) Smoke D Basement L)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 022) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 22 ((Z22)Smoke D Basement R)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 023) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 23 ((Z23) Unused)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 50000025[C][L] [dsc1]
2020-07-10 09:52:12 - DSC: 500 - Command Acknowledge (000) [dsc1]
2020-07-10 09:52:12 - DSC: 6100242D[C][L]6100252E[C][L]6100262F[C][L]61002730[C][L]61002831[C][L]61002932[C][L]6100302A[C][L]6100312B[C][L]6100322C[C][L]6100332D[C][L]60903436[C][L]6100352F[C][L]61003630[C][L]61003731[C][L]61003832[C][L]61003933[C][L]6100402B[C][L]6100412C[C][L]6100422D[C][L]6100432E[C][L]6100442F[C][L]61004530[C][L]61004631[C][L]61004732[C][L] [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 024) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 24 ((Z24) Unused)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 025) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 25 ((Z25) Office Windows)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 026) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 26 ((Z26) Dining Rm Windows)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 027) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 27 ((Z27) Kitchen Window)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 028) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 28 ((Z28) Laundry Rm Window)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 029) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 29 ((Z29) Powder Rm Window)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 030) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 30 ((Z30) Great Rm Windows)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 031) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 31 ((Z31) Living Rm Windows)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 032) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 32 ((Z32) Unused)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 033) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 33 ((Z33) Master Bedrm Windows)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 609 - Zone Open (Zone 034) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 34 ((Z34) Julia's Bedrm Windows)  Opened [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 035) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 35 ((Z35) Chrissy's Bedrm Windows)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 036) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 36 ((Z36) Maddy's Bedrm Window)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 037) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 37 ((Z37) Guest Rm Window)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 038) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 38 ((Z38) Shared Washrm Window)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 039) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 39 ((Z39) Master Washrm Window)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 040) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 40 ((Z40) Gym Window)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 041) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 41 ((Z41) Unused)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 042) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 42 ((Z42) Bsmnt Bar Windows)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 043) [dsc1]
2020-07-10 09:52:12 - DSC: Zone 43 ((Z43) Bsmnt Fireplace Windows)  Closed [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 044) [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 045) [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 046) [dsc1]
2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 047) [dsc1]
2020-07-10 09:52:13 - DSC: 61004833[C][L]61004934[C][L]6100502C[C][L]6100512D[C][L]6100522E[C][L]6100532F[C][L]61005430[C][L]61005531[C][L]61005632[C][L]61005733[C][L]61005834[C][L]61005935[C][L]6100602D[C][L]6100612E[C][L]6100622F[C][L]61006330[C][L]61006431[C][L]6531CF[C][L]6732D2[C][L]6733D3[C][L]6734D4[C][L]8411CE[C][L]8412CF[C][L]8413D0[C][L]8414D1[C][L]8415D2[C][L] [dsc1]
2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 048) [dsc1]
2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 049) [dsc1]
2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 050) [dsc1]
2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 051) [dsc1]
2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 052) [dsc1]
2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 053) [dsc1]
2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 054) [dsc1]
2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 055) [dsc1]
2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 056) [dsc1]
2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 057) [dsc1]
2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 058) [dsc1]
2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 059) [dsc1]
2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 060) [dsc1]
2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 061) [dsc1]
2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 062) [dsc1]
2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 063) [dsc1]
2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 064) [dsc1]
2020-07-10 09:52:13 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2020-07-10 09:52:13 - DSC: 673 - Partition Busy (Partition 2) [dsc1]
2020-07-10 09:52:13 - DSC: 673 - Partition Busy (Partition 3) [dsc1]
2020-07-10 09:52:13 - DSC: 673 - Partition Busy (Partition 4) [dsc1]
2020-07-10 09:52:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 1) [dsc1]
2020-07-10 09:52:13 - DSC: Panel OK [dsc1]
2020-07-10 09:52:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 2) [dsc1]
2020-07-10 09:52:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 3) [dsc1]
2020-07-10 09:52:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 4) [dsc1]
2020-07-10 09:52:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 5) [dsc1]
2020-07-10 09:52:14 - DSC: 8416D3[C][L]8417D4[C][L]8418D5[C][L]51081FF[C][L] [dsc1]
2020-07-10 09:52:14 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 6) [dsc1]
2020-07-10 09:52:14 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 7) [dsc1]
2020-07-10 09:52:14 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 8) [dsc1]
2020-07-10 09:52:14 - DSC: 510 - Full LED Status Update [dsc1]
2020-07-10 09:52:15 - Relay Server: Started on port 2405
2020-07-10 09:52:21 - Venstar: Get Error - Timeout [ven1]
2020-07-10 09:52:21 - Venstar: Get Error - Timeout [ven2]
2020-07-10 09:52:41 - DSC: 60901838[C][L] [dsc1]
2020-07-10 09:52:41 - DSC: 609 - Zone Open (Zone 018) [dsc1]
2020-07-10 09:52:41 - DSC: Zone 18 ((Z18) Motion Kitchen)  Opened [dsc1]
2020-07-10 09:52:46 - DSC: 61001830[C][L] [dsc1]
2020-07-10 09:52:46 - DSC: 610 - Zone Restored (Zone 018) [dsc1]
2020-07-10 09:52:46 - DSC: Zone 18 ((Z18) Motion Kitchen)  Closed [dsc1]
2020-07-10 09:52:50 - DSC: 60901838[C][L] [dsc1]
2020-07-10 09:52:50 - DSC: 609 - Zone Open (Zone 018) [dsc1]
2020-07-10 09:52:50 - DSC: Zone 18 ((Z18) Motion Kitchen)  Opened [dsc1]
2020-07-10 09:52:52 - DSC: 61001830[C][L] [dsc1]
2020-07-10 09:52:52 - DSC: 610 - Zone Restored (Zone 018) [dsc1]
2020-07-10 09:52:52 - DSC: Zone 18 ((Z18) Motion Kitchen)  Closed [dsc1]
2020-07-10 09:52:52 - DSC: 60901838[C][L] [dsc1]
2020-07-10 09:52:52 - DSC: 609 - Zone Open (Zone 018) [dsc1]
2020-07-10 09:52:52 - DSC: Zone 18 ((Z18) Motion Kitchen)  Opened [dsc1]
2020-07-10 09:52:53 - DSC: 61001830[C][L] [dsc1]
2020-07-10 09:52:53 - DSC: 610 - Zone Restored (Zone 018) [dsc1]
2020-07-10 09:52:53 - DSC: Zone 18 ((Z18) Motion Kitchen)  Closed [dsc1]
2020-07-10 09:52:54 - DSC: 60901737[C][L] [dsc1]
2020-07-10 09:52:54 - DSC: 609 - Zone Open (Zone 017) [dsc1]
2020-07-10 09:52:54 - DSC: Zone 17 ((Z17) Motion Front Door)  Opened [dsc1]
2020-07-10 09:52:58 - DSC: 60900130[C][L] [dsc1]
2020-07-10 09:52:58 - DSC: 609 - Zone Open (Zone 001) [dsc1]
2020-07-10 09:52:58 - DSC: Zone 1 ((Z01) Front Door)  Opened [dsc1]
2020-07-10 09:52:58 - DSC: 51080FE[C][L] [dsc1]
2020-07-10 09:52:58 - DSC: 510 - Full LED Status Update [dsc1]
2020-07-10 09:52:58 - DSC: 6511CD[C][L] [dsc1]
2020-07-10 09:52:58 - DSC: 651 - Partition Not Ready (Partition 1) [dsc1]
2020-07-10 09:52:58 - DSC: System Status - Not Ready (Partition 1) [dsc1]
2020-07-10 09:52:58 - DSC: System Status - Disarmed (Set By Status Request - Partition 1) [dsc1]
2020-07-10 09:53:00 - DSC: 6100172F[C][L] [dsc1]
2020-07-10 09:53:00 - DSC: 610 - Zone Restored (Zone 017) [dsc1]
2020-07-10 09:53:00 - DSC: Zone 17 ((Z17) Motion Front Door)  Closed [dsc1]
2020-07-10 09:53:11 - DSC TCP: Polling DSC [dsc1]
2020-07-10 09:53:11 - DSC: 50000025[C][L] [dsc1]
2020-07-10 09:53:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2020-07-10 09:53:16 - DSC: 61000128[C][L] [dsc1]
2020-07-10 09:53:16 - DSC: 610 - Zone Restored (Zone 001) [dsc1]
2020-07-10 09:53:16 - DSC: Zone 1 ((Z01) Front Door)  Closed [dsc1]
2020-07-10 09:53:16 - DSC: 51081FF[C][L] [dsc1]
2020-07-10 09:53:16 - DSC: 510 - Full LED Status Update [dsc1]
2020-07-10 09:53:16 - DSC: 6531CF[C][L] [dsc1]
2020-07-10 09:53:16 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2020-07-10 09:53:19 - DSC: 60901737[C][L] [dsc1]
2020-07-10 09:53:19 - DSC: 609 - Zone Open (Zone 017) [dsc1]
2020-07-10 09:53:19 - DSC: Zone 17 ((Z17) Motion Front Door)  Opened [dsc1]
2020-07-10 09:53:20 - DSC: 6100172F[C][L] [dsc1]
2020-07-10 09:53:20 - DSC: 610 - Zone Restored (Zone 017) [dsc1]
2020-07-10 09:53:20 - DSC: Zone 17 ((Z17) Motion Front Door)  Closed [dsc1]
2020-07-10 09:53:21 - DSC: 60901737[C][L] [dsc1]
2020-07-10 09:53:21 - DSC: 609 - Zone Open (Zone 017) [dsc1]
2020-07-10 09:53:21 - DSC: Zone 17 ((Z17) Motion Front Door)  Opened [dsc1]
2020-07-10 09:53:24 - DSC: 6100172F[C][L] [dsc1]
2020-07-10 09:53:24 - DSC: 610 - Zone Restored (Zone 017) [dsc1]
2020-07-10 09:53:24 - DSC: Zone 17 ((Z17) Motion Front Door)  Closed [dsc1]
2020-07-10 09:53:26 - DSC: 60901737[C][L] [dsc1]
2020-07-10 09:53:26 - DSC: 609 - Zone Open (Zone 017) [dsc1]
2020-07-10 09:53:26 - DSC: Zone 17 ((Z17) Motion Front Door)  Opened [dsc1]
2020-07-10 09:53:28 - DSC: 6100172F[C][L] [dsc1]
2020-07-10 09:53:28 - DSC: 610 - Zone Restored (Zone 017) [dsc1]
2020-07-10 09:53:28 - DSC: Zone 17 ((Z17) Motion Front Door)  Closed [dsc1]
2020-07-10 09:53:41 - DSC: 60901737[C][L] [dsc1]
2020-07-10 09:53:41 - DSC: 609 - Zone Open (Zone 017) [dsc1]
2020-07-10 09:53:41 - DSC: Zone 17 ((Z17) Motion Front Door)  Opened [dsc1]
2020-07-10 09:53:45 - DSC: 60901838[C][L] [dsc1]
2020-07-10 09:53:45 - DSC: 609 - Zone Open (Zone 018) [dsc1]
2020-07-10 09:53:45 - DSC: Zone 18 ((Z18) Motion Kitchen)  Opened [dsc1]
2020-07-10 09:53:46 - DSC: 6100172F[C][L] [dsc1]
2020-07-10 09:53:46 - DSC: 610 - Zone Restored (Zone 017) [dsc1]
2020-07-10 09:53:46 - DSC: Zone 17 ((Z17) Motion Front Door)  Closed [dsc1]
2020-07-10 09:53:52 - DSC: 61001830[C][L] [dsc1]
2020-07-10 09:53:52 - DSC: 610 - Zone Restored (Zone 018) [dsc1]
2020-07-10 09:53:52 - DSC: Zone 18 ((Z18) Motion Kitchen)  Closed [dsc1]
2020-07-10 09:53:57 - Venstar: Get Error - Timeout [ven1]
2020-07-10 09:53:57 - Venstar: Get Error - Timeout [ven2]
2020-07-10 09:54:11 - DSC TCP: Polling DSC [dsc1]
2020-07-10 09:54:11 - DSC: 50000025[C][L] [dsc1]
2020-07-10 09:54:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
You need to enable the option "Include 653 (Ready to Force Arm) in 650 (Ready)"
As for the Venstar timeout, it's common.  Increase the timeout in the Venstar NodeLink tab.
Thanks... that fixed it! I wondered what that option was for! I did not need to enable that option on my cottage DSC alarm system!
I have increased the Venstar timeout and I will watch to see if I need to increase it more.
Another question related to the Venstar thermostats... I have 2 of them in my home and 1 at the cottage. I noticed that the 2 at my home, on the ISY, have the Fahrenheit node whereas I want the Celsius node! The 1 at the cottage is correct. I don't remember seeing the option to select F or C when setting up the nodes!
Can I simply delete the F nodes on the ISY and manually install C nodes? If so, what do I enter for the Node Address and Primary Node Address values in the Add Node dialog box? If not, how do I correct this?
The Nodes match the thermostat, can't be changed later.  Delete the nodes and let them redo in the ISY.
I'd love to change all the devices to support dynamic switching of units but it'd break everyone's current setups.
