Nexia DB100Z Doorbell Sensor - Does not work in 5.x
I have a Nexia DBZ100Z Doorbell Sensor ... it worked well under 4.x, but after the upgrade to 5.x, it no longer has the features I used in 4.x to trigger events.
In 4.x, it had items for power monitoring, like "Over voltage" or something similar (I don't know, since I don't have 4.x installed anymore)  There was a number of them and they were all power related.  These events could be used in programs as If conditions, to which I used it to kick off Thens.  These were under a Power Management device.
In 5.x, there are 3 devices (a Notification Sensor, an Energy Meter, and Power Management).  The selections in Programs no longer have the power management options that can used used .. all I can cue off of are Status-> Responding, Battery Level, and number of watts.  None of these change when the device is triggered.
Can anyone help?
(Manual Attached)
Doorbell-Sensor-Installation-Guide.pdf
Yes, I excluded/included as part of the 5.x upgrade.
Hi Lion,
Can you please do the following and post the results:
1) In Admin Console, right+click on the device and select Z-Wave -> Show Information in Event Viewer -> Node Details
2) For each of the 3 nodes from a web browser:      http://<yourIsy>/rest/zwave/node/<isyNodeAddress>/def/get
     e.g.  http://192.168.0.11/rest/zwave/node/ZW023_1/def/get
1) Attached are screenshot since I can't cut-n-paste out of the log.
2)
/rest/zwave/node/ZW051_1/def/get
<nodeDefs><nodedef id="UZW0040" nls="185"><sts><st id="BATLVL" editor="_51_0_R_0_100"/><st id="ERR" editor="ZW_ERR" hide="T"/></sts><cmds><sends/><accepts><cmd id="QUERY"/><cmd id="WAKEOPTS"><p id="INTERVAL" editor="ZW_WAKE_INTERVAL"/></cmd><cmd id="CONFIG"><p id="NUM" editor="_107_0_R_0_255"/><p id="VAL" editor="ZW_CONFIG"/></cmd><cmd id="WDU"/></accepts></cmds><links><ctl/><rsp><link linkdef="ASSOC_MC"/><link linkdef="ASSOC_CMD"/><link linkdef="ASSOC"/></rsp></links></nodedef></nodeDefs>
/rest/zwave/node/ZW051_143/def/get
<nodeDefs><nodedef id="UZW0063" nls="143"><sts><st id="ST" editor="_73_3"/></sts><cmds><sends/><accepts><cmd id="QUERY"/></accepts></cmds><links><ctl/><rsp><link linkdef="ASSOC_MC"/><link linkdef="ASSOC_CMD"/><link linkdef="ASSOC"/></rsp></links></nodedef></nodeDefs>
/rest/zwave/node/ZW051_181/def/get
<nodeDefs><nodedef id="UZW0064" nls="181"><sts/><cmds><sends/><accepts><cmd id="QUERY"/></accepts></cmds><links><ctl/><rsp><link linkdef="ASSOC_MC"/><link linkdef="ASSOC_CMD"/><link linkdef="ASSOC"/></rsp></links></nodedef></nodeDefs>
Sorry for the XML spam.
Any update?  Requested data has been sent.
Great, thanks.  I seem to remember the way I used the device was with some kind of alarm event ... if I'm interpreting it right.
