ISY Writing Updates to Leak Sensors Often
Hello,
I have 3 Insteon leak sensors.  I added 2 leak sensors about a month ago.
I noticed that the system seemed bogged down a bit, and I believe it is due to the leak sensors.  When I have the admin console open, the system busy message is often displayed, while the ISY Writes Updates to one leak sensor at a time.  This often happens over and over, every time a program involving an Insteon device runs.  If lights are not being turned on and off or queried, then the system doesn't seem to write updates to the leak sensors (which is normal).  The leak sensors always have the gray write updates (1011) icon.
I noticed that when I pressed a certain dimmer switch on, the ISY would write updates to all three leak sensors again.  This doesn't happen with all switches.  I have also had about one error light on the ISY a week lately, requiring a power cycle.
The only programs attached to the leak sensors, are IF leak sensor wet on, then send text and set Insteon module off.  The leak sensors seem to be working correctly.
Thank you for any help in resolving this issue.
Tyler
ISY-994I, & ELK-M1
54 minutes ago, tylervet said:
Hello,
Tyler
ISY-994I, & ELK-M1
I have had this problem with other devices when some of the new options are enabled. My ISY slowed right to a standstill almost.
Put the LDs into linking mode, one at a time, and let ISY play out what it is trying to do. Fix the options. IMHO some options  don't work properly with many devices.
Hey Thanks Larry,
I didn't realize they needed to be in linking mode to write the updates.  Looks like that solved it.
Correct me if I'm wrong.  But my leak sensors don't show any options.  At least not in ver. 4.7.3.
Regards,
Tyler
18 minutes ago, tylervet said:
Hey Thanks Larry,
Regards,
Tyler
It's been a while for me with LDs but linking cannot be done without going into linking mode first.
This applies to all battery Insteon devices as a battery saving feature. They do not repeat Insteon commands or respond to queries either.
