ISY Error with Nodelink and DSC
My Pi had crashed and I wasn't able to get it to communicate with Nodelink. When I log into Nodelink, I can see the DSC but none of my zones are labeled. On my ISY, it no longer shows any zone or the Partition with arm or disarm. They seem to look like lightbulbs now. This is the error I am receiving with the partition and all of the zones. Thank you
 ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_part1/add/DSCPartition?primary=n002_dsc1&name=Partition 1&nls=102DP)
Robert
Not a lot of info. What do you mean it didn't communicate?   Did you format and reinstall? Did you change any ISY config?
And send the log portion of NodeLink startup.
Sorry about that, but what seemed to happen is that I noticed that my DSC was no longer communicating to the ISY. So trying to troubleshoot it, I am not sure if I made it worse. I tried just restarting everything and this where I am at now. Log is down below
2018-11-02 20:35:04 - ISY NodeLink Server v0.6.10 started
2018-11-02 20:35:06 - Web config server started (http://1xx.1xx.x.x:8090)
2018-11-02 20:35:06 - ISY resolved to 1xx.1xx.x.xxx
2018-11-02 20:35:06 - ISY: Node Server request sent
2018-11-02 20:35:07 - ISY: <?xml version="1.0" encoding="UTF-8"?><connections all="true" max="25"><connection profile="1" type="network" enabled="true"><name>ISY Portal</name><ssl>true</ssl><port>443</port><timeout>3000</timeout><isyusernum>0</isyusernum><ip>undefined</ip><baseurl>/api/ns/00:21:b9:00:f4:5c</baseurl><nsuser>pyrorobert@verizon.net</nsuser></connection><connection profile="3" type="network" enabled="true"><name>Nest2</name><ssl>true</ssl><port>3000</port><timeout>0</timeout><isyusernum>0</isyusernum><ip>1xx.1xx.x.xx</ip><baseurl>/ns/3</baseurl><nsuser>polyglot</nsuser></connection><connection profile="2" type="network" enabled="true"><name>isylink</name><ssl>false</ssl><port>8090</port><timeout>10</timeout><isyusernum>0</isyusernum><ip>1xx.1xx.x.xx</ip><baseurl>isylink</baseurl><nsuser>user</nsuser></connection></connections> (profiles/ns/0/connection)
2018-11-02 20:35:07 - ISY Node Server config detected (profile 2)
2018-11-02 20:35:07 - ISY: Node list request sent
2018-11-02 20:35:09 - ISY: <?xml version="1.0" encoding="UTF-8"?><nodes><root></    This is where it polls all of my Insteon devices from the ISY
2018-11-02 20:35:10 - ISY Error: Duplicate node names exist on the ISY (Living Room Lamp - B)
2018-11-02 20:35:10 - ISY Error: Duplicate node names exist on the ISY (Garage Door - C)
2018-11-02 20:35:10 - ISY Error: Duplicate node names exist on the ISY (Living Room Outlet)
2018-11-02 20:35:10 - ISY Error: Duplicate node names exist on the ISY (Sophie's Nightlight)
2018-11-02 20:35:10 - ISY Error: Duplicate node names exist on the ISY (Kitchen Countertop LEDs)
2018-11-02 20:35:10 - ISY Error: The remote server returned an error: (403) OK. (profiles/family/10/profile/2/download/EDITOR/I_EDIT.XML)
2018-11-02 20:35:10 - Warning: nodesetup.zip file needs updating in ISY
2018-11-02 20:35:10 - DSC: Repeater started on port 4025 [dsc1]
2018-11-02 20:35:10 - DSC Error: Connection refused. [dsc1]
2018-11-02 20:35:10 - Auto-Update: Checking for program update...
2018-11-02 20:35:31 - Auto-Update: Error retrieving update list: Error: NameResolutionFailure
2018-11-02 20:35:31 - Relay Server: Started on port 2405
2018-11-02 20:35:40 - DSC: Reconnecting To Server [dsc1]
2018-11-02 20:35:40 - DSC: Connected to 1xx.1xx.x.xx [dsc1]
2018-11-02 20:35:41 - Web Request: /index.htm
2018-11-02 20:35:41 - Web Request: /general.css
2018-11-02 20:35:50 - Web Request: /config.htm
2018-11-02 20:35:50 - Web Request: /general.css
2018-11-02 20:35:52 - Web Request: /index.htm
2018-11-02 20:35:52 - Web Request: /general.css
2018-11-02 20:35:53 - Web Request: /dsc1.htm
2018-11-02 20:35:54 - Web Request: /general.css
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1/add/DSC?primary=n002_dsc1&name=DSC Alarm&nls=102D)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_part1/add/DSCPartition?primary=n002_dsc1&name=Partition 1&nls=102DP)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z01/add/DSCZone?primary=n002_dsc1&name=Zone 01&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z02/add/DSCZone?primary=n002_dsc1&name=Zone 02&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z03/add/DSCZone?primary=n002_dsc1&name=Zone 03&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z04/add/DSCZone?primary=n002_dsc1&name=Zone 04&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z05/add/DSCZone?primary=n002_dsc1&name=Zone 05&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z06/add/DSCZone?primary=n002_dsc1&name=Zone 06&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z07/add/DSCZone?primary=n002_dsc1&name=Zone 07&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z08/add/DSCZone?primary=n002_dsc1&name=Zone 08&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z09/add/DSCZone?primary=n002_dsc1&name=Zone 09&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z10/add/DSCZone?primary=n002_dsc1&name=Zone 10&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z11/add/DSCZone?primary=n002_dsc1&name=Zone 11&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z12/add/DSCZone?primary=n002_dsc1&name=Zone 12&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z13/add/DSCZone?primary=n002_dsc1&name=Zone 13&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z14/add/DSCZone?primary=n002_dsc1&name=Zone 14&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z15/add/DSCZone?primary=n002_dsc1&name=Zone 15&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z16/add/DSCZone?primary=n002_dsc1&name=Zone 16&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z17/add/DSCZone?primary=n002_dsc1&name=Zone 17&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z18/add/DSCZone?primary=n002_dsc1&name=Zone 18&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z19/add/DSCZone?primary=n002_dsc1&name=Zone 19&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z20/add/DSCZone?primary=n002_dsc1&name=Zone 20&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z21/add/DSCZone?primary=n002_dsc1&name=Zone 21&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z22/add/DSCZone?primary=n002_dsc1&name=Zone 22&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z23/add/DSCZone?primary=n002_dsc1&name=Zone 23&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z24/add/DSCZone?primary=n002_dsc1&name=Zone 24&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z25/add/DSCZone?primary=n002_dsc1&name=Zone 25&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z26/add/DSCZone?primary=n002_dsc1&name=Zone 26&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z27/add/DSCZone?primary=n002_dsc1&name=Zone 27&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z28/add/DSCZone?primary=n002_dsc1&name=Zone 28&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z29/add/DSCZone?primary=n002_dsc1&name=Zone 29&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z30/add/DSCZone?primary=n002_dsc1&name=Zone 30&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z31/add/DSCZone?primary=n002_dsc1&name=Zone 31&nls=102Z)
2018-11-02 20:36:00 - ISY Error: The remote server returned an error: (400) OK. (ns/2/nodes/n002_dsc1_z32/add/DSCZone?primary=n002_dsc1&name=Zone 32&nls=102Z)
2018-11-02 20:36:00 - Web Request: /general.css
Your NodeLink is 35 revisions and almost 2 years old.
Judging by the nameresolution failure your mono version is likely well dated too.
If you are running Raspbian Stretch run the install script:
Ok Thank you, I am trying to run the install script and I get this message:
curl: (6) Could not resolve host: automationshack.com
I am typing it in just as you have. Thank you again for your assistance as I really appreciate it.
Something wrong with DNS on your pie.  Same as:
Don't know what to tell you.
Ok wow, I guess I'll have to reformat and start from scratch.
Sent from my SM-N950U using Tapatalk
Might as well. Judging by the date of NodeLink your Pi is ruuning very old Raspbian anyway.
Could use a facelist.  The new install script makes it pretty easy.
io_guy,
So I reformatted the Pi and have Nodelink up and running. I am still getting some ISY errors on here.
2018-11-04 19:15:16 - ISY NodeLink Server v0.9.20 started
2018-11-04 19:15:16 - OS: Linux raspberrypi 4.14.71+ #1145 Fri Sep 21 15:06:38 BST 2018 armv6l GNU/Linux
2018-11-04 19:15:16 - Mono version: 5.16.0.179 (tarball Thu Oct  4 12:22:11 UTC 2018)
2018-11-04 19:15:18 - Web config server started (http://1xx.1xx.xx.xx:8090)
2018-11-04 19:15:19 - ISY resolved to 1xx.1xx.xx.xx
2018-11-04 19:15:25 - ISY Node Server config detected (profile 2)
2018-11-04 19:15:27 - ISY Warning: Duplicate node names exist on the ISY (Living Room Lamp - B)
2018-11-04 19:15:27 - ISY Warning: Duplicate node names exist on the ISY (Garage Door - C)
2018-11-04 19:15:27 - ISY Warning: Duplicate node names exist on the ISY (Living Room Outlet)
2018-11-04 19:15:27 - ISY Warning: Duplicate node names exist on the ISY (Sophie's Nightlight)
2018-11-04 19:15:27 - ISY Warning: Duplicate node names exist on the ISY (Kitchen Countertop LEDs)
2018-11-04 19:15:28 - DSC: Repeater started on port 4025 [dsc1]
2018-11-04 19:16:03 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1/add/DSC?primary=n002_dsc1&name=DSC Alarm&nls=102D)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_part1/add/DSCPartition?primary=n002_dsc1&name=Partition 1&nls=102DP)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z01/add/DSCZone?primary=n002_dsc1&name=Zone 01&nls=102Z)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z02/add/DSCZone?primary=n002_dsc1&name=Zone 02&nls=102Z)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z03/add/DSCZone?primary=n002_dsc1&name=Zone 03&nls=102Z)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z04/add/DSCZone?primary=n002_dsc1&name=Zone 04&nls=102Z)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z05/add/DSCZone?primary=n002_dsc1&name=Zone 05&nls=102Z)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z06/add/DSCZone?primary=n002_dsc1&name=Zone 06&nls=102Z)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z07/add/DSCZone?primary=n002_dsc1&name=Zone 07&nls=102Z)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z08/add/DSCZone?primary=n002_dsc1&name=Zone 08&nls=102Z)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z09/add/DSCZone?primary=n002_dsc1&name=Zone 09&nls=102Z)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z10/add/DSCZone?primary=n002_dsc1&name=Zone 10&nls=102Z)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z11/add/DSCZone?primary=n002_dsc1&name=Zone 11&nls=102Z)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z12/add/DSCZone?primary=n002_dsc1&name=Zone 12&nls=102Z)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z13/add/DSCZone?primary=n002_dsc1&name=Zone 13&nls=102Z)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z14/add/DSCZone?primary=n002_dsc1&name=Zone 14&nls=102Z)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z15/add/DSCZone?primary=n002_dsc1&name=Zone 15&nls=102Z)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z16/add/DSCZone?primary=n002_dsc1&name=Zone 16&nls=102Z)
2018-11-04 19:16:05 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z17/add/DSCZone?primary=n002_dsc1&name=Zone 17&nls=102Z)
2018-11-04 19:16:06 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z18/add/DSCZone?primary=n002_dsc1&name=Zone 18&nls=102Z)
2018-11-04 19:16:06 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z19/add/DSCZone?primary=n002_dsc1&name=Zone 19&nls=102Z)
2018-11-04 19:16:06 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z20/add/DSCZone?primary=n002_dsc1&name=Zone 20&nls=102Z)
2018-11-04 19:16:06 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z21/add/DSCZone?primary=n002_dsc1&name=Zone 21&nls=102Z)
2018-11-04 19:16:06 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z22/add/DSCZone?primary=n002_dsc1&name=Zone 22&nls=102Z)
2018-11-04 19:16:06 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z23/add/DSCZone?primary=n002_dsc1&name=Zone 23&nls=102Z)
2018-11-04 19:16:06 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z24/add/DSCZone?primary=n002_dsc1&name=Zone 24&nls=102Z)
2018-11-04 19:16:06 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z25/add/DSCZone?primary=n002_dsc1&name=Zone 25&nls=102Z)
2018-11-04 19:16:06 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z26/add/DSCZone?primary=n002_dsc1&name=Zone 26&nls=102Z)
2018-11-04 19:16:06 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z27/add/DSCZone?primary=n002_dsc1&name=Zone 27&nls=102Z)
2018-11-04 19:16:06 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z28/add/DSCZone?primary=n002_dsc1&name=Zone 28&nls=102Z)
2018-11-04 19:16:06 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z29/add/DSCZone?primary=n002_dsc1&name=Zone 29&nls=102Z)
2018-11-04 19:16:06 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z30/add/DSCZone?primary=n002_dsc1&name=Zone 30&nls=102Z)
2018-11-04 19:16:06 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z31/add/DSCZone?primary=n002_dsc1&name=Zone 31&nls=102Z)
2018-11-04 19:16:06 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z32/add/DSCZone?primary=n002_dsc1&name=Zone 32&nls=102Z)
2018-11-04 19:18:31 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1/add/DSC?primary=n002_dsc1&name=DSC Alarm&nls=102D)
2018-11-04 19:18:31 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_part1/add/DSCPartition?primary=n002_dsc1&name=Partition 1&nls=102DP)
2018-11-04 19:18:31 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z01/add/DSCZone?primary=n002_dsc1&name=Zone 01&nls=102Z)
2018-11-04 19:18:31 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z02/add/DSCZone?primary=n002_dsc1&name=Zone 02&nls=102Z)
2018-11-04 19:18:31 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z03/add/DSCZone?primary=n002_dsc1&name=Zone 03&nls=102Z)
2018-11-04 19:18:31 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z04/add/DSCZone?primary=n002_dsc1&name=Zone 04&nls=102Z)
2018-11-04 19:18:31 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z05/add/DSCZone?primary=n002_dsc1&name=Zone 05&nls=102Z)
2018-11-04 19:18:31 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z06/add/DSCZone?primary=n002_dsc1&name=Zone 06&nls=102Z)
2018-11-04 19:18:31 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z07/add/DSCZone?primary=n002_dsc1&name=Zone 07&nls=102Z)
2018-11-04 19:18:31 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z08/add/DSCZone?primary=n002_dsc1&name=Zone 08&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z09/add/DSCZone?primary=n002_dsc1&name=Zone 09&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z10/add/DSCZone?primary=n002_dsc1&name=Zone 10&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z11/add/DSCZone?primary=n002_dsc1&name=Zone 11&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z12/add/DSCZone?primary=n002_dsc1&name=Zone 12&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z13/add/DSCZone?primary=n002_dsc1&name=Zone 13&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z14/add/DSCZone?primary=n002_dsc1&name=Zone 14&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z15/add/DSCZone?primary=n002_dsc1&name=Zone 15&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z16/add/DSCZone?primary=n002_dsc1&name=Zone 16&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z17/add/DSCZone?primary=n002_dsc1&name=Zone 17&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z18/add/DSCZone?primary=n002_dsc1&name=Zone 18&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z19/add/DSCZone?primary=n002_dsc1&name=Zone 19&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z20/add/DSCZone?primary=n002_dsc1&name=Zone 20&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z21/add/DSCZone?primary=n002_dsc1&name=Zone 21&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z22/add/DSCZone?primary=n002_dsc1&name=Zone 22&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z23/add/DSCZone?primary=n002_dsc1&name=Zone 23&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z24/add/DSCZone?primary=n002_dsc1&name=Zone 24&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z25/add/DSCZone?primary=n002_dsc1&name=Zone 25&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z26/add/DSCZone?primary=n002_dsc1&name=Zone 26&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z27/add/DSCZone?primary=n002_dsc1&name=Zone 27&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z28/add/DSCZone?primary=n002_dsc1&name=Zone 28&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z29/add/DSCZone?primary=n002_dsc1&name=Zone 29&nls=102Z)
2018-11-04 19:18:32 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z30/add/DSCZone?primary=n002_dsc1&name=Zone 30&nls=102Z)
2018-11-04 19:18:33 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z31/add/DSCZone?primary=n002_dsc1&name=Zone 31&nls=102Z)
2018-11-04 19:18:33 - ISY Error: Web Error - BadRequest (ns/2/nodes/n002_dsc1_z32/add/DSCZone?primary=n002_dsc1&name=Zone 32&nls=102Z)
Try 0.9.21 (just released).  I added the Rest reason codes UDI added to their Node Server code - it'll tell us what the actual error is.
I suspect it's "Node Already Exists" but if that's the case I'm not sure why NodeLink would be trying to add them since it checks on startup.  Does NodeLink function ok after these errors?
Just allow NodeLink to do its auto-update
Or run the install again, I've tweaked the script to overwrite the existing exe.
Ok, so it did the update, but this is what it is doing. And you can see from the image that it is not responding correctly.
2018-11-05 12:44:50 - ISY NodeLink Server v0.9.21 started
2018-11-05 12:44:50 - OS: Linux raspberrypi 4.14.71+ #1145 Fri Sep 21 15:06:38 BST 2018 armv6l GNU/Linux
2018-11-05 12:44:50 - Mono version: 5.16.0.179 (tarball Thu Oct  4 12:22:11 UTC 2018)
2018-11-05 12:44:52 - Web config server started (http://1xx.1xx.xx.xx:8090)
2018-11-05 12:44:53 - ISY resolved to 1xx.1xx.x.xx
2018-11-05 12:44:58 - ISY Node Server config detected (profile 2)
2018-11-05 12:45:00 - ISY Warning: Duplicate node names exist on the ISY (Living Room Lamp - B)
2018-11-05 12:45:00 - ISY Warning: Duplicate node names exist on the ISY (Garage Door - C)
2018-11-05 12:45:00 - ISY Warning: Duplicate node names exist on the ISY (Living Room Outlet)
2018-11-05 12:45:00 - ISY Warning: Duplicate node names exist on the ISY (Sophie's Nightlight)
2018-11-05 12:45:00 - ISY Warning: Duplicate node names exist on the ISY (Kitchen Countertop LEDs)
2018-11-05 12:45:02 - DSC: Repeater started on port 4025 [dsc1]
2018-11-05 12:45:02 - Relay Server: Started on port 2405
2018-11-05 12:45:03 - DSC Error: Connected - Connection reset by peer [dsc1]
2018-11-05 12:45:32 - DSC: Reconnecting To Server [dsc1]
2018-11-05 12:45:32 - DSC Error: Data Arrival Init - Connection reset by peer [dsc1]
2018-11-05 12:46:02 - DSC: Reconnecting To Server [dsc1]
2018-11-05 12:46:02 - DSC Error: Data Arrival Init - Connection reset by peer [dsc1]
2018-11-05 12:46:32 - DSC: Reconnecting To Server [dsc1]
2018-11-05 12:46:32 - DSC Error: Data Arrival Init - Connection reset by peer [dsc1]
2018-11-05 12:47:02 - DSC: Reconnecting To Server [dsc1]
2018-11-05 12:47:02 - DSC Error: Data Arrival Init - Connection reset by peer [dsc1]
2018-11-05 12:47:32 - DSC: Reconnecting To Server [dsc1]
2018-11-05 12:47:32 - DSC Error: Data Arrival Init - Connection reset by peer [dsc1]
2018-11-05 12:48:02 - DSC: Reconnecting To Server [dsc1]
2018-11-05 12:48:02 - DSC Error: Data Arrival Init - Connection reset by peer [dsc1]
2018-11-05 12:48:32 - DSC: Reconnecting To Server [dsc1]
2018-11-05 12:48:32 - DSC Error: Data Arrival Init - Connection reset by peer [dsc1]
2018-11-05 12:49:02 - DSC: Reconnecting To Server [dsc1]
2018-11-05 12:49:02 - DSC Error: Data Arrival Init - Connection reset by peer [dsc1]
2018-11-05 12:49:32 - DSC: Reconnecting To Server [dsc1]
2018-11-05 12:49:32 - DSC Error: Data Arrival Init - Connection reset by peer [dsc1]
2018-11-05 12:50:02 - DSC: Reconnecting To Server [dsc1]
2018-11-05 12:50:02 - DSC Error: Data Arrival Init - Connection reset by peer [dsc1]
2018-11-05 12:50:32 - DSC: Reconnecting To Server [dsc1]
2018-11-05 12:50:32 - DSC Error: Connected - Connection reset by peer [dsc1]
2018-11-05 12:51:02 - DSC: Reconnecting To Server [dsc1]
2018-11-05 12:51:02 - DSC Error: Connected - Connection reset by peer [dsc1]
Not the same error.
You likely have two instances of NodeLink running.  The EVL will only accept a single connection.
That image points to your nodedef files not updated correctly.
io_guy, what else could I look for to fix this? I do not have Nodelink programmed anywhere else. I reformatted my Rasp Pi and reinstalled everything as your directions explain. Not sure what else I can do. At a loss at this point.
018-11-10 02:26:16 - ISY NodeLink Server v0.9.21 started
2018-11-10 02:26:17 - OS: Linux raspberrypi 4.14.71+ #1145 Fri Sep 21 15:06:38 BST 2018 armv6l GNU/Linux
2018-11-10 02:26:17 - Mono version: 5.16.0.179 (tarball Thu Oct  4 12:22:11 UTC 2018)
2018-11-10 02:26:19 - Web config server started (http://1xx.1xx.xx.xx:8090)
2018-11-10 02:26:19 - ISY resolved to 1xx.1xx.xx.xx
2018-11-10 02:26:24 - ISY Error: Login failure (verify ISY user/password on the system config page)
2018-11-10 02:26:24 - ISY Error: Error getting Node Server list - Root element is missing.
2018-11-10 02:26:24 - ISY Node Server profile set to 2
2018-11-10 02:26:24 - DSC: Repeater started on port 4025 [dsc1]
2018-11-10 02:26:25 - Relay Server: Started on port 2405
2018-11-10 02:26:25 - DSC Error: Connected - Connection reset by peer [dsc1]
2018-11-10 02:26:36 - ISY Warning: Duplicate node names exist on the ISY (Living Room Lamp - B)
2018-11-10 02:26:36 - ISY Warning: Duplicate node names exist on the ISY (Garage Door - C)
2018-11-10 02:26:37 - ISY Warning: Duplicate node names exist on the ISY (Living Room Outlet)
2018-11-10 02:26:37 - ISY Warning: Duplicate node names exist on the ISY (Sophie's Nightlight)
2018-11-10 02:26:37 - ISY Warning: Duplicate node names exist on the ISY (Kitchen Countertop LEDs)
2018-11-10 02:26:50 - ISY Receive: ISY node profile nls/EN_US.TXT updated successfully
2018-11-10 02:26:51 - ISY Receive: ISY node profile editor/I_EDIT.XML updated successfully
2018-11-10 02:26:52 - ISY Receive: ISY node profile nodedef/I_NDEFS.XML updated successfully
2018-11-10 02:26:55 - DSC: Reconnecting To Server [dsc1]
2018-11-10 02:26:55 - DSC Error: Data Arrival Init - Connection reset by peer [dsc1]
2018-11-10 02:27:25 - DSC: Reconnecting To Server [dsc1]
2018-11-10 02:27:25 - DSC Error: Data Arrival Init - Connection reset by peer [dsc1]
2018-11-10 02:27:55 - DSC: Reconnecting To Server [dsc1]
2018-11-10 02:27:55 - DSC Error: Data Arrival Init - Connection reset by peer [dsc1]
2018-11-10 02:28:05 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1/add/DSC?primary=n002_dsc1&name=DSC Alarm&nls=102D)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_part1/add/DSCPartition?primary=n002_dsc1&name=Partition 1&nls=102DP)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z01/add/DSCZone?primary=n002_dsc1&name=Zone 01&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z02/add/DSCZone?primary=n002_dsc1&name=Zone 02&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z03/add/DSCZone?primary=n002_dsc1&name=Zone 03&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z04/add/DSCZone?primary=n002_dsc1&name=Zone 04&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z05/add/DSCZone?primary=n002_dsc1&name=Zone 05&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z06/add/DSCZone?primary=n002_dsc1&name=Zone 06&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z07/add/DSCZone?primary=n002_dsc1&name=Zone 07&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z08/add/DSCZone?primary=n002_dsc1&name=Zone 08&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z09/add/DSCZone?primary=n002_dsc1&name=Zone 09&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z10/add/DSCZone?primary=n002_dsc1&name=Zone 10&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z11/add/DSCZone?primary=n002_dsc1&name=Zone 11&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z12/add/DSCZone?primary=n002_dsc1&name=Zone 12&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z13/add/DSCZone?primary=n002_dsc1&name=Zone 13&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z14/add/DSCZone?primary=n002_dsc1&name=Zone 14&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z15/add/DSCZone?primary=n002_dsc1&name=Zone 15&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z16/add/DSCZone?primary=n002_dsc1&name=Zone 16&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z17/add/DSCZone?primary=n002_dsc1&name=Zone 17&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z18/add/DSCZone?primary=n002_dsc1&name=Zone 18&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z19/add/DSCZone?primary=n002_dsc1&name=Zone 19&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z20/add/DSCZone?primary=n002_dsc1&name=Zone 20&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z21/add/DSCZone?primary=n002_dsc1&name=Zone 21&nls=102Z)
2018-11-10 02:28:06 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z22/add/DSCZone?primary=n002_dsc1&name=Zone 22&nls=102Z)
2018-11-10 02:28:07 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z23/add/DSCZone?primary=n002_dsc1&name=Zone 23&nls=102Z)
2018-11-10 02:28:07 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z24/add/DSCZone?primary=n002_dsc1&name=Zone 24&nls=102Z)
2018-11-10 02:28:07 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z25/add/DSCZone?primary=n002_dsc1&name=Zone 25&nls=102Z)
2018-11-10 02:28:07 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z26/add/DSCZone?primary=n002_dsc1&name=Zone 26&nls=102Z)
2018-11-10 02:28:07 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z27/add/DSCZone?primary=n002_dsc1&name=Zone 27&nls=102Z)
2018-11-10 02:28:07 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z28/add/DSCZone?primary=n002_dsc1&name=Zone 28&nls=102Z)
2018-11-10 02:28:07 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z29/add/DSCZone?primary=n002_dsc1&name=Zone 29&nls=102Z)
2018-11-10 02:28:07 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z30/add/DSCZone?primary=n002_dsc1&name=Zone 30&nls=102Z)
2018-11-10 02:28:07 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z31/add/DSCZone?primary=n002_dsc1&name=Zone 31&nls=102Z)
2018-11-10 02:28:07 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/2/nodes/n002_dsc1_z32/add/DSCZone?primary=n002_dsc1&name=Zone 32&nls=102Z)
2018-11-10 02:28:25 - DSC: Reconnecting To Server [dsc1]
2018-11-10 02:28:25 - DSC Error: Data Arrival Init - Connection reset by peer [dsc1]
You have two sets of errors.  I can't tell you why NodeLink can't connect to your DSC.  What happens when you try to connect with something like Hercules to port 4025?
https://www.hw-group.com/product-version/hercules
The ISY has a login error (that's why you're seeing the NODE_ALREADY_EXISTS because it can't download your node list).  What ISY software version are you running?
My ISY is version 5.13d. I will try to see if I can use that Hercules to connect to it. Thanks.
With Hercules, it is communicating to Nodelink through port 4025. Verifying my ISY version is 5.0.13D.
Also when I login directly to the Envisalink, it shows the TPI status is online to the Nodelink IP address.
I meant to connect Hercules directly to the EVL. That's the part that's disconnecting.
Also, enable debug in NodeLink main and DSC pages to see if there's any issue showing up for the timeout.
And if you can route your Pi to the internet I can take a look.
