Low Battery
I was getting a low battery indicator on a motion sensor which didn’t surprise me since the motion sensor is outdoors and the battery is a year old. I changed the battery but I’m still getting the Low Battery alert. How do I reset that?
It will reset on its own, give it time to send a heartbeat, could be several hours.
Which MS version do you have?
The original MS doesn't have a heartbeat. and the lowBatt sgnal is only sent once.
I have seen reports to use a query of the MS in an ISY program to clear that past indication. ISY only indicates the last thing it was told by the device.
It's the original MS.  And I replaced it a couple days ago and am still getting the occasional low battery message from a program I have running that looks for the low battery indicator.
Query the low battery node, that should reset it.
From what I have heard (somewhere :) ),  the manual query doesn't do it. I don't know why there there would be (or could be) a difference between program Queries and manual queries.
The MS doesn't respond to manual queries anyway. Of course putting it into linking mode may help.
You select the Low Battery node and then query. It does not really try to query the MS, it just updates the status to OFF.
OK I just did that and it went from ON to OFF.  Hopefully that clears it up.   Thanks!
