Current Version of nodesetup.zip may cause IllegalArgumentException killing programs tab load
Looks like the current, and possibly the last few versions of nodesetup.zip is causing an unhandled exception in ISY when you click on the programs tab and the programs initially load in 5.0.12+.  I reverted back to an old version I had laying around from 2017 to resolve locally after a complete reinstall did not solve the problem.  After reverting to an old version I was able to edit programs normally.  The only device I have configured is a Honeywell Alarm Panel:
Installed Devices
Ademco     hwalrm1    Honeywell Alarm Panel
When I updated back to the current the problem reappeared:
2018-12-02 00:11:37 - ISY Receive: ISY node profile editor/I_EDIT.XML updated successfully
2018-12-02 00:11:38 - ISY Receive: ISY node profile nodedef/I_NDEFS.XML updated successfully
I am attaching a screenshot of the stack dump from x,13D, also seeing it from x14.  IllegalArgumentException  I_STAT_VENHCS...  VenstartC
Versions:
2018-12-01 22:55:42 - ISY NodeLink Server v0.9.23 started
2018-12-01 22:55:42 - OS: Linux cairo 4.14.79+ #1159 Sun Nov 4 17:28:08 GMT 2018 armv6l GNU/Linux
2018-12-01 22:55:42 - Mono version: 5.16.0.220 (tarball Mon Nov 26 17:53:18 UTC 2018)
ISY994:
5.0.12, x.13D, x.14   (5.0.11B and earlier versions seems unaffected)
Edited by BillB66
That's something for UDI/Java to fix.
I can fix the broken link but it shouldn't break the ISY.
I agree with that. I reported the unhanded exception in another thread for them to resolve on the main code base.  Thanks for getting a fix pushed out.
I'll release a new version tonight.
It's kind of odd you're seeing this.  No one has reported this (including me) and you don't even have a Venstar node.
It is puzzling.  Something about my ISY configuration is exposing it.  However, I would rather not have to wipe ISY and restart so I do appreciate you putting out a fix while I wait for the next x.15.
If I start seeing other issues with isy, that will be my only path.
Bill B.
Were you able to release a new version of the nodesetup?   I just did a force update and didn't see one.
Bill B.
Nope, I've added some more hue code and other stuff and needed to test.  Will release tonight.
