Mobilinc for multiple homes
I have an ISY in one of my homes - used very regularly.  I also use Google Home (connected through my.isy.io) and Mobilinc.  Somewhat related, I also have BlueIris setup for video surveillance (this will be important in a second).
I want to have a second ISY setup in a second home.  Google Home can support this setup, but I don't see how I can do that with Mobilinc.
It would be lovely if Mobilinc could support multiple ISY devices.
With Blue Iris, I can utilize multiple video surveillance systems.  Basically, there is a "server list" with a default.  When you open the app, it can automatically connect to a primary server, but you can also log out of that server and select a different server to log into.  This would be a seemingly easy update to make to the app.  If desired, I'd be happy to provide screen shots of what's done with the BlueIris app (in my development background, standing on the shoulders of giants enables developers to make their product even better).
I use Mobilinc for two locations, just not thru the portal. All you need to do is create a second profile by long pressing My Profile under Settings.
Mobilinc can be for two locations with my.isy.io.
1. Click on "Settings".
2. Long press "Selected Profile" for "Profile Options".
3. Select "Create new profile".
Hi @SteveKlos
Open MobiLinc and go to Settings and long press the selected profile to add in a new profile. From here you can configure a direct IP connection or log into your MobiLinc Connect account to link to your second ISY.
Wes
