Lights on KPL switches don't come on when using isy portal.
I love using the isy portal with alexa and insteon.  I do have a question on what I might do to solve the issue with a couple of my KPL buttons not lighting up on the switch when I use Alexa.  Here is the scenario.
I have an insteon plug in that is controlled with a button on a KPL.  When I set it up in isy portal it would not work if I used the KPL choice but only with the plug in choice.  Now when I use Alexa to turn any of these on, the button does not light up.  I can live with this no problem, but I just wanted to know if I was doing something wrong.
You want to expose the scene (which contains both the switch and the light) to the Echo rather than exposing just an individual device.
