Motion Sensor II, connects to insteon hub, not ISY
jmilt13
Have a new Motion Sensor II, it will connect to the insteon hub (used it to verify address was correct), will also link to a switch manually. I cannot get ISY to find it. Used the add motion sensor ii menu, nothing happens. Any ideas?
What version of firmware is in your ISY994i?
Full support for the Motion Sensor II was added in the Beta version 5 series of firmware. I have seen some report minimum support with 4.7.3 and calling it a Motion Sensor. Then using a HUB to adjust some of the options.
You are waking it up before trying to add it. By holding the set button?
Thanks for the replies. I gave up for an hour, came back to laptop and it was magically added. I did update to the newest alpha firmware, and the last thing I did was try adding it with Agave. No clue which method finally worked.
      37.5k
      375k
