January 15, 20197 yr I am seeing this when starting NodeLink 2019-01-15 18:22:10 - ISY Error: Error getting Program list - Object reference not set to an instance of an object I went through each program and cant see anything that stands out like Not Specified or reference to a Null device. Any way to figure this out easily? Jeff
January 15, 20197 yr Author not sure if this is what you are looking for but this is what I received <RestResponse succeeded="false"><status>404</status></RestResponse>
January 16, 20197 yr Author I am at work but remoted into a machine and used its browser. Put command in exact and got 404. Replaced the word ISY with the ISY address it gave me that output. Unless you have another suggestion I will try in a couple hours when I am home.
January 16, 20197 yr Author I got it to work by removing the ? at the end after the word "true". and I received this: This XML file does not appear to have any style information associated with it. The document tree is shown below. <programs> <program id="01DF" status="true" folder="true"> <name>My Programs</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00E4" parentId="0123" status="true" folder="true"> <name>12 A3 A9 1</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00E9" parentId="0123" status="true" folder="true"> <name>12 A3 BD 1</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0129" parentId="0192" status="true" folder="true"> <name>12879</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00EC" parentId="0123" status="true" folder="true"> <name>13 35 F2 1</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00EF" parentId="0123" status="true" folder="true"> <name>13 38 F5 1</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00F4" parentId="0123" status="true" folder="true"> <name>13 9C 20 1</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00F8" parentId="0123" status="true" folder="true"> <name>14 4 1A 1</name> <lastRunTime/> <lastFinishTime/> </program> <program id="012C" parentId="0192" status="true" folder="true"> <name>14486</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00FC" parentId="0123" status="true" folder="true"> <name>15 30 94 1</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0101" parentId="0123" status="true" folder="true"> <name>15 88 1C 1</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0106" parentId="0123" status="true" folder="true"> <name>15 8C A5 1</name> <lastRunTime/> <lastFinishTime/> </program> <program id="010B" parentId="0123" status="true" folder="true"> <name>15 F7 D3 1</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0110" parentId="0123" status="true" folder="true"> <name>15 F7 EA 1</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0115" parentId="0123" status="true" folder="true"> <name>15 F9 2F 1</name> <lastRunTime/> <lastFinishTime/> </program> <program id="011A" parentId="0123" status="true" folder="true"> <name>15 F9 40 1</name> <lastRunTime/> <lastFinishTime/> </program> <program id="012E" parentId="0192" status="true" folder="true"> <name>15890</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0131" parentId="0192" status="true" folder="true"> <name>15920</name> <lastRunTime/> <lastFinishTime/> </program> <program id="011D" parentId="0123" status="true" folder="true"> <name>16 C4 C3 1</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0137" parentId="0192" status="true" folder="true"> <name>1664</name> <lastRunTime/> <lastFinishTime/> </program> <program id="013A" parentId="0192" status="true" folder="true"> <name>16868</name> <lastRunTime/> <lastFinishTime/> </program> <program id="013D" parentId="0192" status="true" folder="true"> <name>17381</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0140" parentId="0192" status="true" folder="true"> <name>17964</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0142" parentId="0192" status="true" folder="true"> <name>19023</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0145" parentId="0192" status="true" folder="true"> <name>20719</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0148" parentId="0192" status="true" folder="true"> <name>2280</name> <lastRunTime/> <lastFinishTime/> </program> <program id="014B" parentId="0192" status="true" folder="true"> <name>23640</name> <lastRunTime/> <lastFinishTime/> </program> <program id="014E" parentId="0192" status="true" folder="true"> <name>2378</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0151" parentId="0192" status="true" folder="true"> <name>25320</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0153" parentId="0192" status="true" folder="true"> <name>2635</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0156" parentId="0192" status="true" folder="true"> <name>2970</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0159" parentId="0192" status="true" folder="true"> <name>34829</name> <lastRunTime/> <lastFinishTime/> </program> <program id="015C" parentId="0192" status="true" folder="true"> <name>35705</name> <lastRunTime/> <lastFinishTime/> </program> <program id="015E" parentId="0192" status="true" folder="true"> <name>35790</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0160" parentId="0192" status="true" folder="true"> <name>36241</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0163" parentId="0192" status="true" folder="true"> <name>37683</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0166" parentId="0192" status="true" folder="true"> <name>39602</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0169" parentId="0192" status="true" folder="true"> <name>41001</name> <lastRunTime/> <lastFinishTime/> </program> <program id="016C" parentId="0192" status="true" folder="true"> <name>44371</name> <lastRunTime/> <lastFinishTime/> </program> <program id="016F" parentId="0192" status="true" folder="true"> <name>45179</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0172" parentId="0192" status="true" folder="true"> <name>46</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0174" parentId="0192" status="true" folder="true"> <name>47281</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0176" parentId="0192" status="true" folder="true"> <name>4854</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0179" parentId="0192" status="true" folder="true"> <name>50347</name> <lastRunTime/> <lastFinishTime/> </program> <program id="017C" parentId="0192" status="true" folder="true"> <name>55725</name> <lastRunTime/> <lastFinishTime/> </program> <program id="017F" parentId="0192" status="true" folder="true"> <name>60188</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0182" parentId="0192" status="true" folder="true"> <name>61416</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0185" parentId="0192" status="true" folder="true"> <name>61763</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0188" parentId="0192" status="true" folder="true"> <name>62328</name> <lastRunTime/> <lastFinishTime/> </program> <program id="018A" parentId="0192" status="true" folder="true"> <name>62371</name> <lastRunTime/> <lastFinishTime/> </program> <program id="018C" parentId="0192" status="true" folder="true"> <name>65255</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0122" parentId="0123" status="true" folder="true"> <name>7 1A 2A 1</name> <lastRunTime/> <lastFinishTime/> </program> <program id="018F" parentId="0192" status="true" folder="true"> <name>753</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0191" parentId="0192" status="true" folder="true"> <name>7924</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01B2" parentId="01DF" status="true" folder="true"> <name>All Door Status</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0017" parentId="01DF" status="true" folder="true"> <name>Aquarium Timer</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0026" parentId="01DF" status="true" folder="true"> <name>Auto Off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01C6" parentId="01DE" status="true" folder="true"> <name>Away NO</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01DD" parentId="01DE" status="false" folder="true"> <name>Away YES</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01BB" parentId="01C6" status="true" folder="true"> <name>Basement Timers</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00BD" parentId="01DF" status="true" folder="true"> <name>Battery Warnings</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0041" parentId="01DF" status="true" folder="true"> <name>Chime</name> <lastRunTime/> <lastFinishTime/> </program> <program id="004B" parentId="01DF" status="true" folder="true"> <name>Closets</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0123" parentId="0193" status="true" folder="true"> <name>Devices</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00DD" parentId="01DF" status="true" folder="true"> <name>Door Status</name> <lastRunTime/> <lastFinishTime/> </program> <program id="005D" parentId="01DF" status="true" folder="true"> <name>Door Warnings</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0060" parentId="01DF" status="true" folder="true"> <name>Foyer/Hallway</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0073" parentId="01DF" status="true" folder="true"> <name>Garage</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0127" parentId="0193" status="true" folder="true"> <name>Global</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00A2" parentId="01DF" status="true" folder="true"> <name>Keypadlinc Status Programs</name> <lastRunTime/> <lastFinishTime/> </program> <program id="007B" parentId="01DF" status="true" folder="true"> <name>Leak Sensors</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0024" parentId="0025" status="true" folder="true"> <name>Nighttime</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 2:55:00 AM</nextScheduledRunTime> </program> <program id="00C8" parentId="01DF" status="true" folder="true"> <name>Office</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00CE" parentId="01DF" status="true" folder="true"> <name>Panic Program</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00DF" parentId="01DF" status="true" folder="true"> <name>Query Programs</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0025" parentId="0026" status="true" folder="true"> <name>Rain</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0193" parentId="01DF" status="true" folder="true"> <name>Resource Manager v1.0</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0192" parentId="0193" status="true" folder="true"> <name>Scenes</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0198" parentId="01DF" status="true" folder="true"> <name>Security Lights Timer</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00A1" parentId="00A2" status="true" folder="true"> <name>Status Fixer</name> <lastRunTime/> <lastFinishTime/> </program> <program id="019D" parentId="01DF" status="true" folder="true"> <name>Sunrise (Always) Timer</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01D6" parentId="01DD" status="true" folder="true"> <name>Sunrise (Away) Timers</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01C0" parentId="01C6" status="true" folder="true"> <name>Sunrise (Not Away) Timers</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01AB" parentId="01DF" status="true" folder="true"> <name>Sunset (Always) Timer</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01DC" parentId="01DD" status="true" folder="true"> <name>Sunset (Away) Timers</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01C5" parentId="01C6" status="true" folder="true"> <name>Sunset (Not Away) Timers</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0366" parentId="01DF" status="true" folder="true"> <name>Theater</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01DE" parentId="01DF" status="true" folder="true"> <name>Vacation Programs</name> <lastRunTime/> <lastFinishTime/> </program> <program id="008C" parentId="00A2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Main Level Keypadlinc</name> <lastRunTime>2019/01/15 8:44:07 PM</lastRunTime> <lastFinishTime>2019/01/15 8:44:07 PM</lastFinishTime> </program> <program id="00F0" parentId="00F4" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>13 9C 20 1_Day</name> <lastRunTime>2019/01/15 8:44:04 PM</lastRunTime> <lastFinishTime>2019/01/15 8:44:04 PM</lastFinishTime> </program> <program id="00F2" parentId="00F4" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>13 9C 20 1_Night</name> <lastRunTime>2019/01/15 8:44:04 PM</lastRunTime> <lastFinishTime>2019/01/15 8:44:04 PM</lastFinishTime> </program> <program id="012F" parentId="0131" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15920_Day</name> <lastRunTime>2019/01/15 8:42:29 PM</lastRunTime> <lastFinishTime>2019/01/15 8:42:29 PM</lastFinishTime> </program> <program id="0130" parentId="0131" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15920_Night</name> <lastRunTime>2019/01/15 8:42:29 PM</lastRunTime> <lastFinishTime>2019/01/15 8:42:29 PM</lastFinishTime> </program> <program id="0088" parentId="00A2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Guest Bath-on</name> <lastRunTime>2019/01/15 8:42:29 PM</lastRunTime> <lastFinishTime>2019/01/15 8:42:31 PM</lastFinishTime> </program> <program id="0002" parentId="00A2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Guest Room-on</name> <lastRunTime>2019/01/15 8:42:29 PM</lastRunTime> <lastFinishTime>2019/01/15 8:42:29 PM</lastFinishTime> </program> <program id="0170" parentId="0172" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>46_Day</name> <lastRunTime>2019/01/15 8:41:31 PM</lastRunTime> <lastFinishTime>2019/01/15 8:41:31 PM</lastFinishTime> </program> <program id="0171" parentId="0172" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>46_Night</name> <lastRunTime>2019/01/15 8:41:31 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="008E" parentId="00A2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Master Bath</name> <lastRunTime>2019/01/15 8:41:30 PM</lastRunTime> <lastFinishTime>2019/01/15 8:41:30 PM</lastFinishTime> </program> <program id="008F" parentId="01DF" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Master Bath On</name> <lastRunTime>2019/01/15 8:41:30 PM</lastRunTime> <lastFinishTime>2019/01/15 8:41:30 PM</lastFinishTime> </program> <program id="0082" parentId="00A2" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Foyer/Hallway</name> <lastRunTime>2019/01/15 8:39:00 PM</lastRunTime> <lastFinishTime>2019/01/15 8:39:00 PM</lastFinishTime> </program> <program id="0084" parentId="00A2" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Game Room Lights</name> <lastRunTime>2019/01/15 8:39:00 PM</lastRunTime> <lastFinishTime>2019/01/15 8:39:00 PM</lastFinishTime> </program> <program id="008A" parentId="00A2" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Jeff's Desk</name> <lastRunTime>2019/01/15 8:39:00 PM</lastRunTime> <lastFinishTime>2019/01/15 8:39:00 PM</lastFinishTime> </program> <program id="0090" parentId="00A2" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Master Bedroom</name> <lastRunTime>2019/01/15 8:39:00 PM</lastRunTime> <lastFinishTime>2019/01/15 8:39:00 PM</lastFinishTime> </program> <program id="0092" parentId="00A2" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Office Lights</name> <lastRunTime>2019/01/15 8:39:00 PM</lastRunTime> <lastFinishTime>2019/01/15 8:39:00 PM</lastFinishTime> </program> <program id="0094" parentId="00A2" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sitting Lamps</name> <lastRunTime>2019/01/15 8:39:00 PM</lastRunTime> <lastFinishTime>2019/01/15 8:39:00 PM</lastFinishTime> </program> <program id="0097" parentId="00A2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sitting Lights Hallway</name> <lastRunTime>2019/01/15 8:39:00 PM</lastRunTime> <lastFinishTime>2019/01/15 8:39:00 PM</lastFinishTime> </program> <program id="0099" parentId="00A2" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Theater All</name> <lastRunTime>2019/01/15 8:39:00 PM</lastRunTime> <lastFinishTime>2019/01/15 8:39:00 PM</lastFinishTime> </program> <program id="00A0" parentId="00A1" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Trigger</name> <lastRunTime>2019/01/15 8:39:00 PM</lastRunTime> <lastFinishTime>2019/01/15 8:39:00 PM</lastFinishTime> <nextScheduledRunTime>2019/01/15 9:09:00 PM</nextScheduledRunTime> </program> <program id="009B" parentId="00A2" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Tucker All</name> <lastRunTime>2019/01/15 8:39:00 PM</lastRunTime> <lastFinishTime>2019/01/15 8:39:00 PM</lastFinishTime> </program> <program id="009C" parentId="00A2" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Upstairs Hallway</name> <lastRunTime>2019/01/15 8:39:00 PM</lastRunTime> <lastFinishTime>2019/01/15 8:39:00 PM</lastFinishTime> </program> <program id="009E" parentId="00A2" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Wet Bar Lights</name> <lastRunTime>2019/01/15 8:39:00 PM</lastRunTime> <lastFinishTime>2019/01/15 8:39:00 PM</lastFinishTime> </program> <program id="019E" parentId="0041" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>DRIVEWAY Alrt trigger</name> <lastRunTime>2019/01/15 8:32:10 PM</lastRunTime> <lastFinishTime>2019/01/15 8:32:10 PM</lastFinishTime> </program> <program id="01E0" parentId="01B2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>All Garage Doors</name> <lastRunTime>2019/01/15 8:30:10 PM</lastRunTime> <lastFinishTime>2019/01/15 8:30:10 PM</lastFinishTime> </program> <program id="01EA" parentId="01B2" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>All Garage Doors 2</name> <lastRunTime>2019/01/15 8:30:10 PM</lastRunTime> <lastFinishTime>2019/01/15 8:30:10 PM</lastFinishTime> </program> <program id="00DB" parentId="0073" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 3 Status</name> <lastRunTime>2019/01/15 8:30:10 PM</lastRunTime> <lastFinishTime>2019/01/15 8:30:10 PM</lastFinishTime> </program> <program id="0039" parentId="0073" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 3 keypad off</name> <lastRunTime>2019/01/15 8:30:10 PM</lastRunTime> <lastFinishTime>2019/01/15 8:30:10 PM</lastFinishTime> </program> <program id="0071" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 3 keypad on</name> <lastRunTime>2019/01/15 8:30:10 PM</lastRunTime> <lastFinishTime>2019/01/15 8:30:18 PM</lastFinishTime> </program> <program id="0008" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 3 keypad on 2</name> <lastRunTime>2019/01/15 8:30:10 PM</lastRunTime> <lastFinishTime>2019/01/15 8:30:18 PM</lastFinishTime> </program> <program id="003F" parentId="0041" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>DRIVEWAY DONG</name> <lastRunTime>2019/01/15 8:30:09 PM</lastRunTime> <lastFinishTime>2019/01/15 8:32:09 PM</lastFinishTime> </program> <program id="013B" parentId="013D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>17381_Day</name> <lastRunTime>2019/01/15 8:13:58 PM</lastRunTime> <lastFinishTime>2019/01/15 8:13:58 PM</lastFinishTime> </program> <program id="013C" parentId="013D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>17381_Night</name> <lastRunTime>2019/01/15 8:13:58 PM</lastRunTime> <lastFinishTime>2019/01/15 8:13:58 PM</lastFinishTime> </program> <program id="01EC" parentId="01B2" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>All Door Sensors</name> <lastRunTime>2019/01/15 8:05:03 PM</lastRunTime> <lastFinishTime>2019/01/15 8:05:03 PM</lastFinishTime> </program> <program id="01ED" parentId="01B2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>All Door Sensors 2</name> <lastRunTime>2019/01/15 8:05:03 PM</lastRunTime> <lastFinishTime>2019/01/15 8:05:03 PM</lastFinishTime> </program> <program id="0051" parentId="005D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Front Door Night</name> <lastRunTime>2019/01/15 8:05:03 PM</lastRunTime> <lastFinishTime>2019/01/15 8:05:03 PM</lastFinishTime> <nextScheduledRunTime>2019/01/15 10:30:30 PM</nextScheduledRunTime> </program> <program id="01AC" parentId="00DD" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Front Door Status</name> <lastRunTime>2019/01/15 8:05:03 PM</lastRunTime> <lastFinishTime>2019/01/15 8:05:03 PM</lastFinishTime> </program> <program id="0052" parentId="005D" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Front Porch Off</name> <lastRunTime>2019/01/15 8:05:03 PM</lastRunTime> <lastFinishTime>2019/01/15 8:05:03 PM</lastFinishTime> </program> <program id="007A" parentId="0041" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Driveway Set 1</name> <lastRunTime>2019/01/15 8:00:00 PM</lastRunTime> <lastFinishTime>2019/01/15 8:00:00 PM</lastFinishTime> <nextScheduledRunTime>2019/01/15 9:00:00 PM</nextScheduledRunTime> </program> <program id="018B" parentId="018C" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>65255_Day</name> <lastRunTime>2019/01/15 7:57:21 PM</lastRunTime> <lastFinishTime>2019/01/15 7:57:21 PM</lastFinishTime> </program> <program id="0049" parentId="004B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Front Porch</name> <lastRunTime>2019/01/15 7:15:55 PM</lastRunTime> <lastFinishTime>2019/01/15 7:15:55 PM</lastFinishTime> </program> <program id="001B" parentId="0026" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Front Porch Off</name> <lastRunTime>2019/01/15 7:15:55 PM</lastRunTime> <lastFinishTime>2019/01/15 7:15:55 PM</lastFinishTime> </program> <program id="0053" parentId="005D" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Front Porch On</name> <lastRunTime>2019/01/15 7:14:51 PM</lastRunTime> <lastFinishTime>2019/01/15 7:14:51 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 6:56:35 AM</nextScheduledRunTime> </program> <program id="0154" parentId="0156" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>2970_Day</name> <lastRunTime>2019/01/15 7:02:42 PM</lastRunTime> <lastFinishTime>2019/01/15 7:02:42 PM</lastFinishTime> </program> <program id="0155" parentId="0156" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>2970_Night</name> <lastRunTime>2019/01/15 7:02:42 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0183" parentId="0185" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>61763_Day</name> <lastRunTime>2019/01/15 7:02:42 PM</lastRunTime> <lastFinishTime>2019/01/15 7:02:42 PM</lastFinishTime> </program> <program id="0184" parentId="0185" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>61763_Night</name> <lastRunTime>2019/01/15 7:02:42 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="00FD" parentId="0101" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 88 1C 1_Day</name> <lastRunTime>2019/01/15 7:02:39 PM</lastRunTime> <lastFinishTime>2019/01/15 7:02:39 PM</lastFinishTime> </program> <program id="00FF" parentId="0101" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 88 1C 1_Night</name> <lastRunTime>2019/01/15 7:02:39 PM</lastRunTime> <lastFinishTime>2019/01/15 7:02:39 PM</lastFinishTime> </program> <program id="0102" parentId="0106" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 8C A5 1_Day</name> <lastRunTime>2019/01/15 7:02:39 PM</lastRunTime> <lastFinishTime>2019/01/15 7:02:39 PM</lastFinishTime> </program> <program id="0104" parentId="0106" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 8C A5 1_Night</name> <lastRunTime>2019/01/15 7:02:39 PM</lastRunTime> <lastFinishTime>2019/01/15 7:02:39 PM</lastFinishTime> </program> <program id="0161" parentId="0163" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>37683_Day</name> <lastRunTime>2019/01/15 7:02:39 PM</lastRunTime> <lastFinishTime>2019/01/15 7:02:39 PM</lastFinishTime> </program> <program id="0162" parentId="0163" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>37683_Night</name> <lastRunTime>2019/01/15 7:02:39 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="016D" parentId="016F" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>45179_Day</name> <lastRunTime>2019/01/15 7:02:39 PM</lastRunTime> <lastFinishTime>2019/01/15 7:02:39 PM</lastFinishTime> </program> <program id="016E" parentId="016F" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>45179_Night</name> <lastRunTime>2019/01/15 7:02:39 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0146" parentId="0148" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>2280_Day</name> <lastRunTime>2019/01/15 7:02:38 PM</lastRunTime> <lastFinishTime>2019/01/15 7:02:38 PM</lastFinishTime> </program> <program id="0147" parentId="0148" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>2280_Night</name> <lastRunTime>2019/01/15 7:02:38 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="014F" parentId="0151" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>25320_Day</name> <lastRunTime>2019/01/15 7:02:38 PM</lastRunTime> <lastFinishTime>2019/01/15 7:02:38 PM</lastFinishTime> </program> <program id="0150" parentId="0151" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>25320_Night</name> <lastRunTime>2019/01/15 7:02:38 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="008B" parentId="00A2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Jeff's Desk on</name> <lastRunTime>2019/01/15 7:02:38 PM</lastRunTime> <lastFinishTime>2019/01/15 7:02:38 PM</lastFinishTime> </program> <program id="0095" parentId="00A2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sitting Lamps on</name> <lastRunTime>2019/01/15 7:02:38 PM</lastRunTime> <lastFinishTime>2019/01/15 7:02:38 PM</lastFinishTime> </program> <program id="015D" parentId="015E" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>35790_Night</name> <lastRunTime>2019/01/15 7:01:47 PM</lastRunTime> <lastFinishTime>2019/01/15 7:01:47 PM</lastFinishTime> </program> <program id="004E" parentId="005D" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Deck Off</name> <lastRunTime>2019/01/15 7:01:47 PM</lastRunTime> <lastFinishTime>2019/01/15 7:01:49 PM</lastFinishTime> </program> <program id="0056" parentId="005D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Kitchen Door Day</name> <lastRunTime>2019/01/15 7:01:47 PM</lastRunTime> <lastFinishTime>2019/01/15 7:01:47 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 2:20:00 PM</nextScheduledRunTime> </program> <program id="0057" parentId="005D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Kitchen Door Night</name> <lastRunTime>2019/01/15 7:01:47 PM</lastRunTime> <lastFinishTime>2019/01/15 7:01:47 PM</lastFinishTime> <nextScheduledRunTime>2019/01/15 10:10:00 PM</nextScheduledRunTime> </program> <program id="0133" parentId="00DD" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Kitchen Door Status</name> <lastRunTime>2019/01/15 7:01:47 PM</lastRunTime> <lastFinishTime>2019/01/15 7:01:47 PM</lastFinishTime> </program> <program id="004F" parentId="005D" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Deck On</name> <lastRunTime>2019/01/15 7:01:44 PM</lastRunTime> <lastFinishTime>2019/01/15 7:01:44 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 6:56:35 AM</nextScheduledRunTime> </program> <program id="01EE" parentId="01B2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>All Door Locks</name> <lastRunTime>2019/01/15 7:01:17 PM</lastRunTime> <lastFinishTime>2019/01/15 7:01:17 PM</lastFinishTime> </program> <program id="01EF" parentId="01B2" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>All Door Locks 2</name> <lastRunTime>2019/01/15 7:01:17 PM</lastRunTime> <lastFinishTime>2019/01/15 7:01:17 PM</lastFinishTime> </program> <program id="01B5" parentId="01C6" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Ashton Off</name> <lastRunTime>2019/01/15 6:57:21 PM</lastRunTime> <lastFinishTime>2019/01/15 7:57:21 PM</lastFinishTime> </program> <program id="0036" parentId="01DF" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage Lights Off</name> <lastRunTime>2019/01/15 6:56:28 PM</lastRunTime> <lastFinishTime>2019/01/15 7:56:28 PM</lastFinishTime> </program> <program id="000A" parentId="01DF" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Kitchen on</name> <lastRunTime>2019/01/15 6:50:57 PM</lastRunTime> <lastFinishTime>2019/01/15 6:50:57 PM</lastFinishTime> </program> <program id="00DA" parentId="0073" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 2 Status</name> <lastRunTime>2019/01/15 6:49:34 PM</lastRunTime> <lastFinishTime>2019/01/15 6:49:34 PM</lastFinishTime> </program> <program id="003C" parentId="0073" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 2 keypad off</name> <lastRunTime>2019/01/15 6:49:34 PM</lastRunTime> <lastFinishTime>2019/01/15 6:49:34 PM</lastFinishTime> </program> <program id="006A" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 2 keypad on</name> <lastRunTime>2019/01/15 6:49:34 PM</lastRunTime> <lastFinishTime>2019/01/15 6:49:42 PM</lastFinishTime> </program> <program id="0070" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 2 keypad on 2</name> <lastRunTime>2019/01/15 6:49:33 PM</lastRunTime> <lastFinishTime>2019/01/15 6:49:41 PM</lastFinishTime> </program> <program id="0001" parentId="01DF" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>6pm All on</name> <lastRunTime>2019/01/15 6:00:00 PM</lastRunTime> <lastFinishTime>2019/01/15 6:00:00 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 6:00:00 PM</nextScheduledRunTime> </program> <program id="00D1" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Leak Sensor Problem</name> <lastRunTime>2019/01/15 6:00:00 PM</lastRunTime> <lastFinishTime>2019/01/15 6:00:00 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 9:00:00 AM</nextScheduledRunTime> </program> <program id="005A" parentId="005D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Porch ON</name> <lastRunTime>2019/01/15 5:40:06 PM</lastRunTime> <lastFinishTime>2019/01/15 5:40:06 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 6:56:35 AM</nextScheduledRunTime> </program> <program id="01C2" parentId="01C5" status="true" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Sunset (Not Away) Check</name> <lastRunTime>2019/01/15 5:11:18 PM</lastRunTime> <lastFinishTime>2019/01/15 5:11:18 PM</lastFinishTime> </program> <program id="01C4" parentId="01C5" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunset (Not Away) Success Notify</name> <lastRunTime>2019/01/15 5:11:18 PM</lastRunTime> <lastFinishTime>2019/01/15 5:11:28 PM</lastFinishTime> </program> <program id="01A8" parentId="01AB" status="true" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Sunset (Always) Check</name> <lastRunTime>2019/01/15 5:10:42 PM</lastRunTime> <lastFinishTime>2019/01/15 5:10:42 PM</lastFinishTime> </program> <program id="01AA" parentId="01AB" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunset (Always) Success Notify</name> <lastRunTime>2019/01/15 5:10:42 PM</lastRunTime> <lastFinishTime>2019/01/15 5:10:52 PM</lastFinishTime> </program> <program id="0019" parentId="0026" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Disable Daytimeoff</name> <lastRunTime>2019/01/15 5:10:06 PM</lastRunTime> <lastFinishTime>2019/01/15 5:10:13 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 7:25:35 AM</nextScheduledRunTime> </program> <program id="0007" parentId="01DF" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>GARAGE DOOR RING Copy</name> <lastRunTime>2019/01/15 5:10:06 PM</lastRunTime> <lastFinishTime>2019/01/15 5:10:06 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 7:26:35 AM</nextScheduledRunTime> </program> <program id="01A7" parentId="01AB" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunset (Always)</name> <lastRunTime>2019/01/15 5:10:06 PM</lastRunTime> <lastFinishTime>2019/01/15 5:10:42 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 5:11:07 PM</nextScheduledRunTime> </program> <program id="01C1" parentId="01C5" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunset (Not Away)</name> <lastRunTime>2019/01/15 5:10:06 PM</lastRunTime> <lastFinishTime>2019/01/15 5:11:18 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 5:11:07 PM</nextScheduledRunTime> </program> <program id="001A" parentId="0026" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Enable Daytime Off</name> <lastRunTime>2019/01/15 5:09:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:09:07 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 7:26:35 AM</nextScheduledRunTime> </program> <program id="0003" parentId="01DF" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Aquarium Bar</name> <lastRunTime>2019/01/15 5:09:06 PM</lastRunTime> <lastFinishTime>2019/01/15 5:11:13 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 5:10:07 PM</nextScheduledRunTime> </program> <program id="000F" parentId="01DF" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Security Light Reset</name> <lastRunTime>2019/01/15 5:09:06 PM</lastRunTime> <lastFinishTime>2019/01/15 5:11:06 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 5:10:07 PM</nextScheduledRunTime> </program> <program id="00E0" parentId="00E4" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>12 A3 A9 1_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="00E2" parentId="00E4" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>12 A3 A9 1_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="00E5" parentId="00E9" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>12 A3 BD 1_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="00E7" parentId="00E9" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>12 A3 BD 1_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0128" parentId="0129" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>12879_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="00EA" parentId="00EC" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>13 35 F2 1_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="00ED" parentId="00EF" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>13 38 F5 1_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="00F5" parentId="00F8" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>14 4 1A 1_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="00F6" parentId="00F8" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>14 4 1A 1_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="012A" parentId="012C" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>14486_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="012B" parentId="012C" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>14486_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="00F9" parentId="00FC" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 30 94 1_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="00FA" parentId="00FC" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 30 94 1_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0107" parentId="010B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 F7 D3 1_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0109" parentId="010B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 F7 D3 1_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="010C" parentId="0110" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 F7 EA 1_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="010E" parentId="0110" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 F7 EA 1_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0111" parentId="0115" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 F9 2F 1_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0113" parentId="0115" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 F9 2F 1_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0116" parentId="011A" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 F9 40 1_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0118" parentId="011A" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 F9 40 1_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="012D" parentId="012E" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15890_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="011B" parentId="011D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>16 C4 C3 1_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0135" parentId="0137" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>1664_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0136" parentId="0137" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>1664_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0138" parentId="013A" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>16868_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0139" parentId="013A" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>16868_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="013E" parentId="0140" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>17964_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="013F" parentId="0140" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>17964_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0141" parentId="0142" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>19023_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0143" parentId="0145" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>20719_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0144" parentId="0145" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>20719_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0149" parentId="014B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>23640_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="014A" parentId="014B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>23640_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="014C" parentId="014E" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>2378_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="014D" parentId="014E" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>2378_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0152" parentId="0153" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>2635_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0157" parentId="0159" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>34829_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0158" parentId="0159" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>34829_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="015A" parentId="015C" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>35705_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="015B" parentId="015C" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>35705_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 7:07:07 PM</lastFinishTime> </program> <program id="015F" parentId="0160" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>36241_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0164" parentId="0166" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>39602_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0165" parentId="0166" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>39602_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0167" parentId="0169" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>41001_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0168" parentId="0169" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>41001_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:37:07 PM</lastFinishTime> </program> <program id="016A" parentId="016C" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>44371_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="016B" parentId="016C" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>44371_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0173" parentId="0174" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>47281_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0175" parentId="0176" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>4854_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0177" parentId="0179" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>50347_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0178" parentId="0179" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>50347_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="017A" parentId="017C" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>55725_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="017B" parentId="017C" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>55725_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="017E" parentId="017F" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>60188_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0180" parentId="0182" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>61416_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0181" parentId="0182" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>61416_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0186" parentId="0188" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>62328_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0187" parentId="0188" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>62328_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0189" parentId="018A" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>62371_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="011E" parentId="0122" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>7 1A 2A 1_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0120" parentId="0122" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>7 1A 2A 1_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="018D" parentId="018F" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>753_Day</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="018E" parentId="018F" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>753_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0190" parentId="0191" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>7924_Night</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0124" parentId="0127" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Daytime</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 7:31:35 AM</nextScheduledRunTime> </program> <program id="0125" parentId="0127" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>EnableDay</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="0126" parentId="0127" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>EnableNight</name> <lastRunTime>2019/01/15 5:05:07 PM</lastRunTime> <lastFinishTime>2019/01/15 5:05:07 PM</lastFinishTime> </program> <program id="00AB" parentId="007B" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>Kitchen Fridge- Variable Control 2</name> <lastRunTime>2019/01/15 4:34:53 PM</lastRunTime> <lastFinishTime>2019/01/15 4:34:53 PM</lastFinishTime> </program> <program id="00AA" parentId="007B" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>Hot Water Heater- Variable Control 2</name> <lastRunTime>2019/01/15 4:27:48 PM</lastRunTime> <lastFinishTime>2019/01/15 4:27:48 PM</lastFinishTime> </program> <program id="00A7" parentId="007B" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>Attic HVAC- Variable Control 2</name> <lastRunTime>2019/01/15 4:26:14 PM</lastRunTime> <lastFinishTime>2019/01/15 4:26:14 PM</lastFinishTime> </program> <program id="00A8" parentId="007B" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>Game Room HVAC- Variable Control 2</name> <lastRunTime>2019/01/15 4:21:38 PM</lastRunTime> <lastFinishTime>2019/01/15 4:21:38 PM</lastFinishTime> </program> <program id="00AE" parentId="007B" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>Puffer Aqr- Variable Control 2</name> <lastRunTime>2019/01/15 4:15:55 PM</lastRunTime> <lastFinishTime>2019/01/15 4:15:55 PM</lastFinishTime> </program> <program id="00AD" parentId="007B" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>Small Aqr- Variable Control 2</name> <lastRunTime>2019/01/15 4:13:07 PM</lastRunTime> <lastFinishTime>2019/01/15 4:13:07 PM</lastFinishTime> </program> <program id="00AC" parentId="007B" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>Large Aqr- Variable Control 2</name> <lastRunTime>2019/01/15 4:12:42 PM</lastRunTime> <lastFinishTime>2019/01/15 4:12:42 PM</lastFinishTime> </program> <program id="01E1" parentId="005D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Shed Door Day</name> <lastRunTime>2019/01/15 4:00:00 PM</lastRunTime> <lastFinishTime>2019/01/15 4:00:00 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 4:00:00 PM</nextScheduledRunTime> </program> <program id="001E" parentId="0026" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Night off</name> <lastRunTime>2019/01/15 3:05:00 PM</lastRunTime> <lastFinishTime>2019/01/15 3:05:00 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 3:05:00 AM</nextScheduledRunTime> </program> <program id="004C" parentId="005D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Basement Door Day</name> <lastRunTime>2019/01/15 3:00:00 PM</lastRunTime> <lastFinishTime>2019/01/15 3:00:00 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 3:00:00 PM</nextScheduledRunTime> </program> <program id="01F3" parentId="01DF" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>RainCloud</name> <lastRunTime>2019/01/15 3:00:00 PM</lastRunTime> <lastFinishTime>2019/01/15 3:00:10 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 7:00:00 AM</nextScheduledRunTime> </program> <program id="00DE" parentId="00DF" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>QueryAll</name> <lastRunTime>2019/01/15 2:43:00 PM</lastRunTime> <lastFinishTime>2019/01/15 2:43:00 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 4:43:00 AM</nextScheduledRunTime> </program> <program id="01E2" parentId="005D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Pool Closet Door Day</name> <lastRunTime>2019/01/15 2:30:00 PM</lastRunTime> <lastFinishTime>2019/01/15 2:30:00 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 2:30:00 PM</nextScheduledRunTime> </program> <program id="005B" parentId="005D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunroom Door Day</name> <lastRunTime>2019/01/15 2:25:00 PM</lastRunTime> <lastFinishTime>2019/01/15 2:25:00 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 2:25:00 PM</nextScheduledRunTime> </program> <program id="0050" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 2 keypad off 2</name> <lastRunTime>2019/01/15 2:18:20 PM</lastRunTime> <lastFinishTime>2019/01/15 2:18:31 PM</lastFinishTime> </program> <program id="0054" parentId="005D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Great Room Door Day</name> <lastRunTime>2019/01/15 2:15:00 PM</lastRunTime> <lastFinishTime>2019/01/15 2:15:00 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 2:15:00 PM</nextScheduledRunTime> </program> <program id="007D" parentId="007B" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>Ashton Aqr- Variable Control 2</name> <lastRunTime>2019/01/15 1:44:40 PM</lastRunTime> <lastFinishTime>2019/01/15 1:44:40 PM</lastFinishTime> </program> <program id="00A9" parentId="007B" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>Guest Room Aqr- Variable Control 2</name> <lastRunTime>2019/01/15 1:02:11 PM</lastRunTime> <lastFinishTime>2019/01/15 1:02:11 PM</lastFinishTime> </program> <program id="00D9" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 1 Status</name> <lastRunTime>2019/01/15 12:39:21 PM</lastRunTime> <lastFinishTime>2019/01/15 12:39:21 PM</lastFinishTime> </program> <program id="003B" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 1 keypad off</name> <lastRunTime>2019/01/15 12:39:21 PM</lastRunTime> <lastFinishTime>2019/01/15 12:39:31 PM</lastFinishTime> </program> <program id="0064" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 1 keypad off 2</name> <lastRunTime>2019/01/15 12:39:21 PM</lastRunTime> <lastFinishTime>2019/01/15 12:39:31 PM</lastFinishTime> </program> <program id="0065" parentId="0073" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 1 keypad on</name> <lastRunTime>2019/01/15 12:39:21 PM</lastRunTime> <lastFinishTime>2019/01/15 12:39:21 PM</lastFinishTime> </program> <program id="0013" parentId="0017" status="true" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Aquarium Check</name> <lastRunTime>2019/01/15 12:27:59 PM</lastRunTime> <lastFinishTime>2019/01/15 12:27:59 PM</lastFinishTime> </program> <program id="0015" parentId="0017" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Aquarium Success Notify</name> <lastRunTime>2019/01/15 12:27:59 PM</lastRunTime> <lastFinishTime>2019/01/15 12:28:09 PM</lastFinishTime> </program> <program id="0016" parentId="0017" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Aquariums</name> <lastRunTime>2019/01/15 12:26:54 PM</lastRunTime> <lastFinishTime>2019/01/15 12:27:59 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 12:26:35 PM</nextScheduledRunTime> </program> <program id="003A" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 3 keypad off 2</name> <lastRunTime>2019/01/15 10:51:57 AM</lastRunTime> <lastFinishTime>2019/01/15 10:52:09 AM</lastFinishTime> </program> <program id="0005" parentId="01DF" status="false" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Daytime Off</name> <lastRunTime>2019/01/15 10:47:39 AM</lastRunTime> <lastFinishTime>2019/01/15 10:47:39 AM</lastFinishTime> </program> <program id="00AF" parentId="007B" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>Utility Sink- Variable Control 2</name> <lastRunTime>2019/01/15 10:23:27 AM</lastRunTime> <lastFinishTime>2019/01/15 10:23:27 AM</lastFinishTime> </program> <program id="004D" parentId="005D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Basement Door Night</name> <lastRunTime>2019/01/15 10:08:25 AM</lastRunTime> <lastFinishTime>2019/01/15 10:08:25 AM</lastFinishTime> <nextScheduledRunTime>2019/01/15 10:00:00 PM</nextScheduledRunTime> </program> <program id="00DC" parentId="00DD" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Basement Door Status</name> <lastRunTime>2019/01/15 10:08:25 AM</lastRunTime> <lastFinishTime>2019/01/15 10:08:25 AM</lastFinishTime> </program> <program id="0059" parentId="005D" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Porch OFF</name> <lastRunTime>2019/01/15 10:08:24 AM</lastRunTime> <lastFinishTime>2019/01/15 10:08:24 AM</lastFinishTime> </program> <program id="0132" parentId="00DD" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunroom Door Status</name> <lastRunTime>2019/01/15 10:06:54 AM</lastRunTime> <lastFinishTime>2019/01/15 10:06:54 AM</lastFinishTime> </program> <program id="005C" parentId="005D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunroon Door Night</name> <lastRunTime>2019/01/15 10:06:54 AM</lastRunTime> <lastFinishTime>2019/01/15 10:06:54 AM</lastFinishTime> <nextScheduledRunTime>2019/01/15 10:20:00 PM</nextScheduledRunTime> </program> <program id="006B" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 1 keypad on 2</name> <lastRunTime>2019/01/15 9:58:40 AM</lastRunTime> <lastFinishTime>2019/01/15 9:58:48 AM</lastFinishTime> </program> <program id="0047" parentId="004B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Closet-Jeff</name> <lastRunTime>2019/01/15 9:15:34 AM</lastRunTime> <lastFinishTime>2019/01/15 9:15:34 AM</lastFinishTime> </program> <program id="0091" parentId="00A2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Master Bedroom on</name> <lastRunTime>2019/01/15 9:00:04 AM</lastRunTime> <lastFinishTime>2019/01/15 9:00:04 AM</lastFinishTime> </program> <program id="0012" parentId="01DF" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Vanity Status</name> <lastRunTime>2019/01/15 8:04:01 AM</lastRunTime> <lastFinishTime>2019/01/15 8:04:01 AM</lastFinishTime> </program> <program id="0096" parentId="00A2" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Vanity status</name> <lastRunTime>2019/01/15 8:04:01 AM</lastRunTime> <lastFinishTime>2019/01/15 8:04:01 AM</lastFinishTime> </program> <program id="000D" parentId="00A2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Guest Bath-off</name> <lastRunTime>2019/01/15 8:02:58 AM</lastRunTime> <lastFinishTime>2019/01/15 8:02:58 AM</lastFinishTime> </program> <program id="0098" parentId="00A2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sitting Lights Hallway on</name> <lastRunTime>2019/01/15 7:55:15 AM</lastRunTime> <lastFinishTime>2019/01/15 7:55:15 AM</lastFinishTime> </program> <program id="01BD" parentId="01C0" status="true" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Sunrise (Not Away) Check</name> <lastRunTime>2019/01/15 7:27:59 AM</lastRunTime> <lastFinishTime>2019/01/15 7:27:59 AM</lastFinishTime> </program> <program id="01BF" parentId="01C0" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunrise(Not Away) Success Notify</name> <lastRunTime>2019/01/15 7:27:59 AM</lastRunTime> <lastFinishTime>2019/01/15 7:28:09 AM</lastFinishTime> </program> <program id="019A" parentId="019D" status="true" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Sunrise (Always) Check</name> <lastRunTime>2019/01/15 7:27:19 AM</lastRunTime> <lastFinishTime>2019/01/15 7:27:19 AM</lastFinishTime> </program> <program id="019C" parentId="019D" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunrise (Always) Success Notify</name> <lastRunTime>2019/01/15 7:27:19 AM</lastRunTime> <lastFinishTime>2019/01/15 7:27:29 AM</lastFinishTime> </program> <program id="0199" parentId="019D" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunrise (Always)</name> <lastRunTime>2019/01/15 7:26:54 AM</lastRunTime> <lastFinishTime>2019/01/15 7:27:19 AM</lastFinishTime> <nextScheduledRunTime>2019/01/16 7:26:35 AM</nextScheduledRunTime> </program> <program id="01BC" parentId="01C0" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunrise (Not Away)</name> <lastRunTime>2019/01/15 7:26:54 AM</lastRunTime> <lastFinishTime>2019/01/15 7:27:59 AM</lastFinishTime> <nextScheduledRunTime>2019/01/16 7:26:35 AM</nextScheduledRunTime> </program> <program id="0020" parentId="01DF" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Tucker TV off</name> <lastRunTime>2019/01/15 6:00:01 AM</lastRunTime> <lastFinishTime>2019/01/15 6:00:01 AM</lastFinishTime> <nextScheduledRunTime>2019/01/16 12:00:00 AM</nextScheduledRunTime> </program> <program id="01D1" parentId="01DF" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Camera Reboots</name> <lastRunTime>2019/01/15 6:00:00 AM</lastRunTime> <lastFinishTime>2019/01/15 6:03:16 AM</lastFinishTime> <nextScheduledRunTime>2019/01/16 6:00:00 AM</nextScheduledRunTime> </program> <program id="01F1" parentId="01DF" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Keen Vent Restart</name> <lastRunTime>2019/01/15 6:00:00 AM</lastRunTime> <lastFinishTime>2019/01/15 6:00:15 AM</lastFinishTime> <nextScheduledRunTime>2019/01/16 6:00:00 AM</nextScheduledRunTime> </program> <program id="00D5" parentId="007B" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>Kitchen Sink- Variable Control 2</name> <lastRunTime>2019/01/15 5:02:24 AM</lastRunTime> <lastFinishTime>2019/01/15 5:02:24 AM</lastFinishTime> </program> <program id="00D4" parentId="007B" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>Sump Pump- Variable Control 2</name> <lastRunTime>2019/01/15 4:57:28 AM</lastRunTime> <lastFinishTime>2019/01/15 4:57:28 AM</lastFinishTime> </program> <program id="0194" parentId="0198" status="true" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Security Check</name> <lastRunTime>2019/01/15 3:01:26 AM</lastRunTime> <lastFinishTime>2019/01/15 3:01:26 AM</lastFinishTime> </program> <program id="0197" parentId="0198" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Security Success Notify</name> <lastRunTime>2019/01/15 3:01:26 AM</lastRunTime> <lastFinishTime>2019/01/15 3:01:36 AM</lastFinishTime> </program> <program id="0034" parentId="01DF" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Lock All Doors</name> <lastRunTime>2019/01/15 3:00:00 AM</lastRunTime> <lastFinishTime>2019/01/15 3:00:21 AM</lastFinishTime> <nextScheduledRunTime>2019/01/16 3:00:00 AM</nextScheduledRunTime> </program> <program id="0196" parentId="0198" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Security Lights</name> <lastRunTime>2019/01/15 3:00:00 AM</lastRunTime> <lastFinishTime>2019/01/15 3:01:26 AM</lastFinishTime> <nextScheduledRunTime>2019/01/16 3:00:00 AM</nextScheduledRunTime> </program> <program id="0068" parentId="0073" status="true" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Garage 2 Check</name> <lastRunTime>2019/01/15 1:00:05 AM</lastRunTime> <lastFinishTime>2019/01/15 1:00:05 AM</lastFinishTime> <nextScheduledRunTime>2019/01/15 11:59:00 PM</nextScheduledRunTime> </program> <program id="006C" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 2 Success Notify</name> <lastRunTime>2019/01/15 1:00:05 AM</lastRunTime> <lastFinishTime>2019/01/15 1:00:15 AM</lastFinishTime> </program> <program id="0067" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 2</name> <lastRunTime>2019/01/15 12:59:30 AM</lastRunTime> <lastFinishTime>2019/01/15 1:00:05 AM</lastFinishTime> <nextScheduledRunTime>2019/01/15 11:59:30 PM</nextScheduledRunTime> </program> <program id="01B9" parentId="01BB" status="true" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Basement Night Check</name> <lastRunTime>2019/01/15 12:01:05 AM</lastRunTime> <lastFinishTime>2019/01/15 12:01:05 AM</lastFinishTime> </program> <program id="01BA" parentId="01BB" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Basement Success Notify</name> <lastRunTime>2019/01/15 12:01:05 AM</lastRunTime> <lastFinishTime>2019/01/15 12:01:16 AM</lastFinishTime> </program> <program id="0062" parentId="0073" status="true" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Garage 1 Check</name> <lastRunTime>2019/01/15 12:00:05 AM</lastRunTime> <lastFinishTime>2019/01/15 12:00:05 AM</lastFinishTime> <nextScheduledRunTime>2019/01/15 11:59:00 PM</nextScheduledRunTime> </program> <program id="0066" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 1 Success Notify</name> <lastRunTime>2019/01/15 12:00:05 AM</lastRunTime> <lastFinishTime>2019/01/15 12:00:15 AM</lastFinishTime> </program> <program id="006E" parentId="0073" status="true" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Garage 3 Check</name> <lastRunTime>2019/01/15 12:00:05 AM</lastRunTime> <lastFinishTime>2019/01/15 12:00:05 AM</lastFinishTime> <nextScheduledRunTime>2019/01/15 11:59:00 PM</nextScheduledRunTime> </program> <program id="0072" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 3 Success Notify</name> <lastRunTime>2019/01/15 12:00:05 AM</lastRunTime> <lastFinishTime>2019/01/15 12:00:15 AM</lastFinishTime> </program> <program id="01B8" parentId="01BB" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Basement Night</name> <lastRunTime>2019/01/15 12:00:00 AM</lastRunTime> <lastFinishTime>2019/01/15 12:01:05 AM</lastFinishTime> <nextScheduledRunTime>2019/01/16 12:00:00 AM</nextScheduledRunTime> </program> <program id="0018" parentId="0026" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Christmas Tree</name> <lastRunTime>2019/01/15 12:00:00 AM</lastRunTime> <lastFinishTime>2019/01/15 12:00:00 AM</lastFinishTime> <nextScheduledRunTime>2019/01/16 12:00:00 AM</nextScheduledRunTime> </program> <program id="0061" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 1</name> <lastRunTime>2019/01/14 11:59:30 PM</lastRunTime> <lastFinishTime>2019/01/15 12:00:05 AM</lastFinishTime> <nextScheduledRunTime>2019/01/15 11:59:30 PM</nextScheduledRunTime> </program> <program id="006D" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 3</name> <lastRunTime>2019/01/14 11:59:30 PM</lastRunTime> <lastFinishTime>2019/01/15 12:00:05 AM</lastFinishTime> <nextScheduledRunTime>2019/01/15 11:59:30 PM</nextScheduledRunTime> </program> <program id="00B0" parentId="007B" status="true" folder="false" enabled="true" runAtStartup="false" running="then"> <name>Water Treat- Variable Control 2</name> <lastRunTime>2019/01/14 11:46:24 PM</lastRunTime> <lastFinishTime>2019/01/14 11:46:24 PM</lastFinishTime> </program> <program id="01E3" parentId="005D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Shed Door Night</name> <lastRunTime>2019/01/14 11:30:00 PM</lastRunTime> <lastFinishTime>2019/01/14 11:30:00 PM</lastFinishTime> <nextScheduledRunTime>2019/01/15 11:30:00 PM</nextScheduledRunTime> </program> <program id="01E4" parentId="005D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Pool Closet Door Night</name> <lastRunTime>2019/01/14 11:15:00 PM</lastRunTime> <lastFinishTime>2019/01/14 11:15:00 PM</lastFinishTime> <nextScheduledRunTime>2019/01/15 11:15:00 PM</nextScheduledRunTime> </program> <program id="0058" parentId="005D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Laundry Room Door</name> <lastRunTime>2019/01/14 11:01:00 PM</lastRunTime> <lastFinishTime>2019/01/14 11:01:00 PM</lastFinishTime> <nextScheduledRunTime>2019/01/15 11:01:00 PM</nextScheduledRunTime> </program> <program id="0055" parentId="005D" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Great Room Door Night</name> <lastRunTime>2019/01/14 10:05:00 PM</lastRunTime> <lastFinishTime>2019/01/14 10:05:00 PM</lastFinishTime> <nextScheduledRunTime>2019/01/15 10:05:00 PM</nextScheduledRunTime> </program> <program id="001C" parentId="0026" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garbage Disposal</name> <lastRunTime>2019/01/14 3:03:40 PM</lastRunTime> <lastFinishTime>2019/01/14 3:03:40 PM</lastFinishTime> </program> <program id="0044" parentId="004B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Closet-Cassie</name> <lastRunTime>2019/01/14 10:50:26 AM</lastRunTime> <lastFinishTime>2019/01/14 10:50:26 AM</lastFinishTime> </program> <program id="0083" parentId="00A2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Foyer/Hallway switch on</name> <lastRunTime>2019/01/13 9:02:06 PM</lastRunTime> <lastFinishTime>2019/01/13 9:02:06 PM</lastFinishTime> </program> <program id="009D" parentId="00A2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Upstairs Hallway on</name> <lastRunTime>2019/01/13 8:11:50 PM</lastRunTime> <lastFinishTime>2019/01/13 8:11:50 PM</lastFinishTime> </program> <program id="001F" parentId="0026" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Relays Off</name> <lastRunTime>2019/01/13 4:13:04 PM</lastRunTime> <lastFinishTime>2019/01/13 4:13:04 PM</lastFinishTime> </program> <program id="0045" parentId="004B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Closet-Guest</name> <lastRunTime>2019/01/13 10:43:15 AM</lastRunTime> <lastFinishTime>2019/01/13 10:43:15 AM</lastFinishTime> </program> <program id="0043" parentId="004B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Closet-Ashton</name> <lastRunTime>2019/01/13 10:39:21 AM</lastRunTime> <lastFinishTime>2019/01/13 10:39:21 AM</lastFinishTime> </program> <program id="0078" parentId="0026" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Master Bath Fan Off</name> <lastRunTime>2019/01/13 9:36:16 AM</lastRunTime> <lastFinishTime>2019/01/13 9:54:16 AM</lastFinishTime> </program> <program id="0004" parentId="01DF" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Cable Modem Cycle 2017</name> <lastRunTime>2019/01/13 4:00:00 AM</lastRunTime> <lastFinishTime>2019/01/13 4:11:00 AM</lastFinishTime> <nextScheduledRunTime>2019/01/20 4:00:00 AM</nextScheduledRunTime> </program> <program id="0046" parentId="004B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Closet-hotTub</name> <lastRunTime>2019/01/12 8:36:13 PM</lastRunTime> <lastFinishTime>2019/01/12 8:36:13 PM</lastFinishTime> </program> <program id="01AF" parentId="00DD" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Pool Closet Door Status</name> <lastRunTime>2019/01/12 8:36:12 PM</lastRunTime> <lastFinishTime>2019/01/12 8:36:12 PM</lastFinishTime> </program> <program id="01E8" parentId="005D" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Pool Closet Off</name> <lastRunTime>2019/01/12 8:36:12 PM</lastRunTime> <lastFinishTime>2019/01/12 8:36:12 PM</lastFinishTime> </program> <program id="01E7" parentId="005D" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Pool Closet On</name> <lastRunTime>2019/01/12 8:36:00 PM</lastRunTime> <lastFinishTime>2019/01/12 8:36:00 PM</lastFinishTime> </program> <program id="011C" parentId="011D" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>16 C4 C3 1_NightMacro</name> <lastRunTime>2019/01/12 8:29:14 PM</lastRunTime> <lastFinishTime>2019/01/12 8:45:02 PM</lastFinishTime> </program> <program id="00E3" parentId="00E4" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>12 A3 A9 1_NightMacro</name> <lastRunTime>2019/01/12 8:28:32 PM</lastRunTime> <lastFinishTime>2019/01/12 8:28:47 PM</lastFinishTime> </program> <program id="0009" parentId="01DF" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Kitchen off</name> <lastRunTime>2019/01/12 3:06:09 PM</lastRunTime> <lastFinishTime>2019/01/12 3:06:09 PM</lastFinishTime> </program> <program id="01E6" parentId="005D" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Shed Off</name> <lastRunTime>2019/01/12 2:35:03 PM</lastRunTime> <lastFinishTime>2019/01/12 2:35:03 PM</lastFinishTime> </program> <program id="004A" parentId="004B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Shed Off</name> <lastRunTime>2019/01/12 2:35:03 PM</lastRunTime> <lastFinishTime>2019/01/12 2:35:03 PM</lastFinishTime> </program> <program id="01AE" parentId="00DD" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Shed Door Status</name> <lastRunTime>2019/01/12 2:35:01 PM</lastRunTime> <lastFinishTime>2019/01/12 2:35:01 PM</lastFinishTime> </program> <program id="01E5" parentId="005D" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Shed On</name> <lastRunTime>2019/01/12 2:34:23 PM</lastRunTime> <lastFinishTime>2019/01/12 2:34:23 PM</lastFinishTime> </program> <program id="0134" parentId="00DD" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Great Room Door Status</name> <lastRunTime>2019/01/12 9:30:46 AM</lastRunTime> <lastFinishTime>2019/01/12 9:30:46 AM</lastFinishTime> </program> <program id="0048" parentId="004B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Closet-Tucker</name> <lastRunTime>2019/01/10 8:37:38 PM</lastRunTime> <lastFinishTime>2019/01/10 8:37:38 PM</lastFinishTime> </program> <program id="007E" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Ashton Aqr- Variable Control 3</name> <lastRunTime>2019/01/10 2:34:01 PM</lastRunTime> <lastFinishTime>2019/01/10 2:34:01 PM</lastFinishTime> <nextScheduledRunTime>2019/01/16 3:44:40 PM</nextScheduledRunTime> </program> <program id="00D0" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Leak Sensor Activation</name> <lastRunTime>2019/01/10 2:34:01 PM</lastRunTime> <lastFinishTime>2019/01/10 2:34:01 PM</lastFinishTime> </program> <program id="0075" parentId="0026" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Half Bath Fan Off</name> <lastRunTime>2019/01/09 8:03:43 PM</lastRunTime> <lastFinishTime>2019/01/09 8:21:43 PM</lastFinishTime> </program> <program id="000B" parentId="01DF" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Main Level Off</name> <lastRunTime>2019/01/09 6:29:33 PM</lastRunTime> <lastFinishTime>2019/01/09 6:29:33 PM</lastFinishTime> </program> <program id="0027" parentId="00A2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Main Level Run Off</name> <lastRunTime>2019/01/09 6:29:33 PM</lastRunTime> <lastFinishTime>2019/01/09 6:29:33 PM</lastFinishTime> </program> <program id="008D" parentId="00A2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Main Level Run On</name> <lastRunTime>2019/01/09 6:29:27 PM</lastRunTime> <lastFinishTime>2019/01/09 6:29:27 PM</lastFinishTime> </program> <program id="01B0" parentId="0073" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 2 Fail Notify</name> <lastRunTime>2019/01/09 12:06:20 AM</lastRunTime> <lastFinishTime>2019/01/09 12:06:31 AM</lastFinishTime> </program> <program id="0085" parentId="00A2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Game Room switch on</name> <lastRunTime>2019/01/08 7:15:36 AM</lastRunTime> <lastFinishTime>2019/01/08 7:15:36 AM</lastFinishTime> </program> <program id="0112" parentId="0115" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 F9 2F 1_DayMacro</name> <lastRunTime>2019/01/06 4:08:57 PM</lastRunTime> <lastFinishTime>2019/01/06 4:09:17 PM</lastFinishTime> </program> <program id="00E1" parentId="00E4" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>12 A3 A9 1_DayMacro</name> <lastRunTime>2019/01/06 3:58:47 PM</lastRunTime> <lastFinishTime>2019/01/06 4:11:53 PM</lastFinishTime> </program> <program id="0114" parentId="0115" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 F9 2F 1_NightMacro</name> <lastRunTime>2019/01/05 7:35:22 PM</lastRunTime> <lastFinishTime>2019/01/05 7:35:37 PM</lastFinishTime> </program> <program id="01B6" parentId="01C6" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Great Room Off</name> <lastRunTime>2019/01/05 6:42:05 PM</lastRunTime> <lastFinishTime>2019/01/05 10:42:05 PM</lastFinishTime> </program> <program id="0093" parentId="00A2" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Office Lights on</name> <lastRunTime>2019/01/05 6:01:49 PM</lastRunTime> <lastFinishTime>2019/01/05 6:01:49 PM</lastFinishTime> </program> <program id="00EE" parentId="00EF" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>13 38 F5 1_NightMacro</name> <lastRunTime>2019/01/05 6:01:47 PM</lastRunTime> <lastFinishTime>2019/01/05 7:03:50 PM</lastFinishTime> </program> <program id="0042" parentId="004B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Attic Off</name> <lastRunTime>2019/01/03 3:58:13 PM</lastRunTime> <lastFinishTime>2019/01/03 3:58:13 PM</lastFinishTime> </program> <program id="0108" parentId="010B" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 F7 D3 1_DayMacro</name> <lastRunTime>2019/01/03 3:43:13 PM</lastRunTime> <lastFinishTime>2019/01/03 3:58:13 PM</lastFinishTime> </program> <program id="01D9" parentId="0026" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Grill Light Off</name> <lastRunTime>2019/01/02 7:03:37 PM</lastRunTime> <lastFinishTime>2019/01/02 7:03:37 PM</lastFinishTime> </program> <program id="0195" parentId="0198" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Security Fail Notify</name> <lastRunTime>2019/01/01 3:07:12 AM</lastRunTime> <lastFinishTime>2019/01/01 3:07:22 AM</lastFinishTime> </program> <program id="0364" parentId="0366" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Theater Fade-Down</name> <lastRunTime>2018/12/30 5:22:38 PM</lastRunTime> <lastFinishTime>2018/12/30 5:22:50 PM</lastFinishTime> </program> <program id="0076" parentId="0026" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Kids Bath Fan Off</name> <lastRunTime>2018/12/29 9:25:08 AM</lastRunTime> <lastFinishTime>2018/12/29 9:43:08 AM</lastFinishTime> </program> <program id="019B" parentId="019D" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunrise (Always) Fail Notify</name> <lastRunTime>2018/12/29 7:27:35 AM</lastRunTime> <lastFinishTime>2018/12/29 7:27:35 AM</lastFinishTime> </program> <program id="010F" parentId="0110" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 F7 EA 1_NightMacro</name> <lastRunTime>2018/12/26 11:43:51 PM</lastRunTime> <lastFinishTime>2018/12/26 11:49:45 PM</lastFinishTime> </program> <program id="0087" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Kitchen Fridge- Variable Control 1</name> <lastRunTime>2018/12/22 8:31:50 PM</lastRunTime> <lastFinishTime>2018/12/22 8:32:00 PM</lastFinishTime> </program> <program id="0086" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Hot Water Heater- Variable Control 1</name> <lastRunTime>2018/12/22 8:26:48 PM</lastRunTime> <lastFinishTime>2018/12/22 8:26:58 PM</lastFinishTime> </program> <program id="0080" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Attic HVAC- Variable Control 1</name> <lastRunTime>2018/12/22 8:22:24 PM</lastRunTime> <lastFinishTime>2018/12/22 8:22:34 PM</lastFinishTime> </program> <program id="0081" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Game Room HVAC- Variable Control 1</name> <lastRunTime>2018/12/22 8:20:03 PM</lastRunTime> <lastFinishTime>2018/12/22 8:20:13 PM</lastFinishTime> </program> <program id="00A4" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Puffer Aqr- Variable Control 1</name> <lastRunTime>2018/12/22 8:13:19 PM</lastRunTime> <lastFinishTime>2018/12/22 8:13:29 PM</lastFinishTime> </program> <program id="00A3" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Small Aqr- Variable Control 1</name> <lastRunTime>2018/12/22 8:10:30 PM</lastRunTime> <lastFinishTime>2018/12/22 8:10:40 PM</lastFinishTime> </program> <program id="0089" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Large Aqr- Variable Control 1</name> <lastRunTime>2018/12/22 8:09:43 PM</lastRunTime> <lastFinishTime>2018/12/22 8:09:53 PM</lastFinishTime> </program> <program id="007C" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Ashton Aqr- Variable Control 1</name> <lastRunTime>2018/12/22 5:41:29 PM</lastRunTime> <lastFinishTime>2018/12/22 5:41:39 PM</lastFinishTime> </program> <program id="007F" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Guest Room Aqr- Variable Control 1</name> <lastRunTime>2018/12/22 5:00:49 PM</lastRunTime> <lastFinishTime>2018/12/22 5:00:59 PM</lastFinishTime> </program> <program id="00A5" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Utility Sink- Variable Control 1</name> <lastRunTime>2018/12/22 2:21:00 PM</lastRunTime> <lastFinishTime>2018/12/22 2:21:10 PM</lastFinishTime> </program> <program id="00D3" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Kitchen Sink- Variable Control 1</name> <lastRunTime>2018/12/22 8:58:55 AM</lastRunTime> <lastFinishTime>2018/12/22 8:59:05 AM</lastFinishTime> </program> <program id="00D2" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sump Pump- Variable Control 1</name> <lastRunTime>2018/12/22 8:55:19 AM</lastRunTime> <lastFinishTime>2018/12/22 8:55:29 AM</lastFinishTime> </program> <program id="00A6" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Water Treat- Variable Control 1</name> <lastRunTime>2018/12/22 3:42:30 AM</lastRunTime> <lastFinishTime>2018/12/22 3:42:40 AM</lastFinishTime> </program> <program id="003E" parentId="0041" status="true" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Button 3 Dong</name> <lastRunTime>2018/12/21 10:31:12 PM</lastRunTime> <lastFinishTime>2018/12/21 10:31:22 PM</lastFinishTime> </program> <program id="00CF" parentId="007B" status="true" folder="false" enabled="true" runAtStartup="true" running="idle"> <name>Leak Startup</name> <lastRunTime>2018/12/21 10:31:06 PM</lastRunTime> <lastFinishTime>2018/12/21 10:31:12 PM</lastFinishTime> </program> <program id="01B3" parentId="01DE" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Vacation No Message</name> <lastRunTime>2018/12/21 10:29:51 PM</lastRunTime> <lastFinishTime>2018/12/21 10:31:22 PM</lastFinishTime> </program> <program id="01B4" parentId="01DE" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Vacation Yes Message</name> <lastRunTime>2018/12/21 10:29:51 PM</lastRunTime> <lastFinishTime>2018/12/21 10:29:51 PM</lastFinishTime> </program> <program id="00E6" parentId="00E9" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>12 A3 BD 1_DayMacro</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00E8" parentId="00E9" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>12 A3 BD 1_NightMacro</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00EB" parentId="00EC" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>13 35 F2 1_NightMacro</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00F1" parentId="00F4" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>13 9C 20 1_DayMacro</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00F3" parentId="00F4" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>13 9C 20 1_NightMacro</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00F7" parentId="00F8" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>14 4 1A 1_RelayStop</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00FB" parentId="00FC" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 30 94 1_RelayStop</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00FE" parentId="0101" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 88 1C 1_DayMacro</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0100" parentId="0101" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 88 1C 1_NightMacro</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0103" parentId="0106" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 8C A5 1_DayMacro</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0105" parentId="0106" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 8C A5 1_NightMacro</name> <lastRunTime/> <lastFinishTime/> </program> <program id="010A" parentId="010B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 F7 D3 1_NightMacro</name> <lastRunTime/> <lastFinishTime/> </program> <program id="010D" parentId="0110" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 F7 EA 1_DayMacro</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0117" parentId="011A" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 F9 40 1_DayMacro</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0119" parentId="011A" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>15 F9 40 1_NightMacro</name> <lastRunTime/> <lastFinishTime/> </program> <program id="011F" parentId="0122" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>7 1A 2A 1_DayMacro</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0121" parentId="0122" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>7 1A 2A 1_NightMacro</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0035" parentId="01DF" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Alarm Away</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0037" parentId="01DF" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Alarm Disarm</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0038" parentId="01DF" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Alarm No Entry</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0033" parentId="01DF" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Alarm Stay</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0361" parentId="0366" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>All Lights Off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0031" parentId="0366" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>All Lights On</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0014" parentId="0017" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Aquarium Fail Notify</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00B1" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Attic HVAC- Variable Control 3</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 6:26:14 PM</nextScheduledRunTime> </program> <program id="0074" parentId="0026" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Basement Bath Fan Off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0029" parentId="00BD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Basement Door Sensor Battery</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01B7" parentId="01BB" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Basement Fail Notify</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01C7" parentId="01DD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Basement Off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01F4" parentId="01DF" status="false" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Camera Reboots 2</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/15 9:00:00 PM</nextScheduledRunTime> </program> <program id="000C" parentId="01DF" status="false" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Camera Reboots 2 Copy</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/15 9:00:00 PM</nextScheduledRunTime> </program> <program id="00BA" parentId="00BD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Deck Motion Battery</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00BE" parentId="00C8" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Fan High off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00BF" parentId="00C8" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Fan High on</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00C0" parentId="00C8" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Fan Low Off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00C1" parentId="00C8" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Fan Low On</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00C2" parentId="00C8" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Fan Medium Off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00C3" parentId="00C8" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Fan Medium On</name> <lastRunTime/> <lastFinishTime/> </program> <program id="005E" parentId="0060" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Foyer/Hallway off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="005F" parentId="0060" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Foyer/Hallway on</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00C9" parentId="0041" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Freezer Open</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01C8" parentId="01DD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Front Desk Off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="002A" parentId="00BD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Front Door Sensor Battery</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0006" parentId="01DF" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>GARAGE DOOR RING</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00B3" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Game Room HVAC- Variable Control 3</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 6:21:38 PM</nextScheduledRunTime> </program> <program id="0063" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 1 Fail Notify</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0069" parentId="0073" status="true" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Garage 2 Fail Notify old</name> <lastRunTime/> <lastFinishTime/> </program> <program id="006F" parentId="0073" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Garage 3 Fail Notify</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01B1" parentId="0073" status="true" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Garage 3 Fail Notify old</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0040" parentId="0041" status="false" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Garage Dong</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01C9" parentId="01DD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Great Room Off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01F2" parentId="01DF" status="false" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Great Room WIFI</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 7:15:00 AM</nextScheduledRunTime> </program> <program id="002D" parentId="00BD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>GreatRoom Door Sensor Battery</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0077" parentId="0026" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Guest Bath Fan Off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01CA" parentId="01DD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Guest Fan Off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01CB" parentId="01DD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Guest Lights</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01CC" parentId="01DD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Guest Room All</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00B4" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Guest Room Aqr- Variable Control 3</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 3:02:11 PM</nextScheduledRunTime> </program> <program id="00B5" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Hot Water Heater- Variable Control 3</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 6:27:48 PM</nextScheduledRunTime> </program> <program id="00CB" parentId="00CE" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>KeyPad1Success</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00CD" parentId="00CE" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>KeyPad2Success</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00CA" parentId="00CE" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Keypad1Code</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00CC" parentId="00CE" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Keypad2Code</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0030" parentId="00BD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Kitchen Door Sensor Battery</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00B6" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Kitchen Fridge- Variable Control 3</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 6:34:53 PM</nextScheduledRunTime> </program> <program id="00D7" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Kitchen Sink- Variable Control 3</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 7:02:24 AM</nextScheduledRunTime> </program> <program id="00B7" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Large Aqr- Variable Control 3</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 6:12:42 PM</nextScheduledRunTime> </program> <program id="002C" parentId="00BD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Laundry Door Sensor Battery</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01AD" parentId="00DD" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Laundry Door Status</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0028" parentId="01DF" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Main Level On</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01CD" parentId="01DD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Master Fan Lights Off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01CE" parentId="01DD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Master Off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="001D" parentId="0026" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Night Mode</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01CF" parentId="01DD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Night On</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 2:47:00 AM</nextScheduledRunTime> </program> <program id="0022" parentId="0024" status="true" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>No Rain</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 2:50:00 AM</nextScheduledRunTime> </program> <program id="00C4" parentId="00C8" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Office Ceiling off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00C5" parentId="00C8" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Office Ceiling on</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00C6" parentId="00C8" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Office Lamp off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00C7" parentId="00C8" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Office Lamp on</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01D0" parentId="01DD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Pet Fountains Off</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 7:31:35 AM</nextScheduledRunTime> </program> <program id="01E9" parentId="0026" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Pool Closet light off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="002F" parentId="00BD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Pool Door Sensor Battery</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00BB" parentId="00BD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Porch Motion Battery</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00B9" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Puffer Aqr- Variable Control 3</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 6:15:55 PM</nextScheduledRunTime> </program> <program id="0023" parentId="0024" status="false" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Rain</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 2:50:00 AM</nextScheduledRunTime> </program> <program id="000E" parentId="01DF" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Reboot Theater DVR</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0079" parentId="01DF" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Screenlogic</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01EB" parentId="01DF" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Security DVR Reboot</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0032" parentId="005D" status="false" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Segway Closet</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/15 11:01:00 PM</nextScheduledRunTime> </program> <program id="002E" parentId="00BD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Shed Door Sensor Battery</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00B8" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Small Aqr- Variable Control 3</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 6:13:07 PM</nextScheduledRunTime> </program> <program id="00D6" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sump Pump- Variable Control 3</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 6:57:28 AM</nextScheduledRunTime> </program> <program id="01D2" parentId="01D6" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunrise (Away)</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 7:26:35 AM</nextScheduledRunTime> </program> <program id="01D3" parentId="01D6" status="false" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Sunrise (Away) Check</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01D4" parentId="01D6" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunrise (Away) Fail Notify</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01D5" parentId="01D6" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunrise (Away) Success Notify</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01BE" parentId="01C0" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunrise (Not Away) Fail Notify</name> <lastRunTime/> <lastFinishTime/> </program> <program id="002B" parentId="00BD" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunroom Door Sensor Battery</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01A9" parentId="01AB" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunset (Always) Fail Notify</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01D7" parentId="01DC" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunset (Away)</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 5:11:07 PM</nextScheduledRunTime> </program> <program id="01D8" parentId="01DC" status="false" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Sunset (Away) Check</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01DA" parentId="01DC" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunset (Away) Fail Notify</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01DB" parentId="01DC" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunset (Away) Success Notify</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01C3" parentId="01C5" status="true" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Sunset (Not Away) Fail Notify</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00D8" parentId="0073" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>TEST</name> <lastRunTime/> <lastFinishTime/> </program> <program id="009A" parentId="00A2" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Theater All on</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0365" parentId="0366" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Theater Fade-Up</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00BC" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Utility Sink- Variable Control 3</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 12:23:27 PM</nextScheduledRunTime> </program> <program id="0010" parentId="01DF" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Vanity Off</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0011" parentId="01DF" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Vanity On</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0021" parentId="0025" status="false" folder="false" enabled="false" runAtStartup="false" running="idle"> <name>Wait to change Stairs</name> <lastRunTime/> <lastFinishTime/> </program> <program id="00B2" parentId="007B" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Water Treat- Variable Control 3</name> <lastRunTime/> <lastFinishTime/> <nextScheduledRunTime>2019/01/16 1:46:24 AM</nextScheduledRunTime> </program> <program id="009F" parentId="00A2" status="false" folder="false" enabled="true" runAtStartup="false" running="idle"> <name>Wet Bar Lights on</name> <lastRunTime/> <lastFinishTime/> </program> </programs>
March 13, 20196 yr I find I am having the same error and was wondering if there was ever a resolution? ISY Error: Error getting Program list - Object reference not set to an instance of an object. When I type in http://192.168.0.10/rest/programs?subfolders=true I get: <?xml version="1.0" encoding="ISO-8859-1"?> <programs> <program id="0254" folder="true" status="true"> <name>My Programs</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0132" folder="true" status="true" parentId="0254"> <name>A_O</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01DD" folder="true" status="true" parentId="0132"> <name>Alexa</name> <lastRunTime/> <lastFinishTime/> </program> <program id="000E" folder="true" status="true" parentId="0132"> <name>Attic Fans</name> <lastRunTime/> <lastFinishTime/> </program> <program id="000D" folder="true" status="true" parentId="000E"> <name>Attic Fans New</name> <lastRunTime/> <lastFinishTime/> </program> <program id="000C" folder="true" status="false" parentId="01CB"> <name>Audio Alarm_Armed Home</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01CB" folder="true" status="true" parentId="0132"> <name>Audio Alerts</name> <lastRunTime/> <lastFinishTime/> </program> <program id="025C" folder="true" status="false" parentId="01CB"> <name>Audio Alerts Home</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0038" folder="true" status="false" parentId="025C"> <name>Audio HVAC</name> <lastRunTime/> <lastFinishTime/> </program> <program id="0142" folder="true" status="true" parentId="0132"> <name>Away</name> <lastRunTime/> <lastFinishTime/> </program> <program id="01CA" folder="true" status="false" parentId="0142"> <name>Away Active Prgms</name> <lastRunTime/> <lastFinishTime/> I shortened the list by a lot due to its length. I notice that every once in a while when I reboot the pi3 or restart Nodelink the error wont show up but it seems like 99% of the time the error is there. Running v0.9.27 on rpi3 with OS: Linux AutoMationPi 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l GNU/Linux Mono version: 5.18.0.240 (tarball Wed Jan 16 09:28:29 UTC 2019) Any ideas? Thanks, Tim
