MS II "sensitivity"
I installed a new MS II in my garage, and works fine.  I think the default sensitivity was "7".  I see the numbers go up really high (I assume higher is more sensitive) and tried a much higher number but did not seem to help.   Do I have the backwards?  anyone play with this setting?
Joe
When I first got my MS II, I tried playing with the sensitivity level and it didn't seem to make much difference.  However, I was only testing the sensitivity as I walked directly toward the MS since I was trying to use one sensor to cover two long hallways that could be seen from a particular MS position.  My understanding is that detecting something coming directly at it is the most difficult case for a MS.  So it's entirely possible that changing the sensitivity level could have more impact on detecting things crossing the path of the MS.  By the way, I ended up using two MS II instead of just one.
Some other Insteon device settings only use the lower 5 bits so that value 33 is the same as 1 and 65 and 129 etc..
Sent from my SM-G930W8 using Tapatalk
