wingman1487 Posted February 6, 2019 Posted February 6, 2019 I am using the Venstar thermostats (2 of them) with the Insteon module plugged into them. Whenever I go to the module in Agave and try to change the mode or fan I have to select it several times, it rarely takes it the first, or even third, forth,... time I select it. Is this maybe an issue related to the Venstar thermostats or are others using the Insteon thermostats seeing the same?
James Peterson Posted February 6, 2019 Posted February 6, 2019 3 minutes ago, wingman1487 said: I am using the Venstar thermostats (2 of them) with the Insteon module plugged into them. Whenever I go to the module in Agave and try to change the mode or fan I have to select it several times, it rarely takes it the first, or even third, forth,... time I select it. Is this maybe an issue related to the Venstar thermostats or are others using the Insteon thermostats seeing the same? I am personally using the 1800 and the plugin module and not seeing any issues. Can you put Agave in debug mode and send me a log when you try this and experience the same issue.
wingman1487 Posted April 20, 2019 Author Posted April 20, 2019 Ah, I hadn't seen that you had replied to my thread, this is what I get for forgetting to subscribe to my own threads. It appears that in your recent update (1.7.124) where you made some changes to the thermostat seems to have fixed it, I haven't seen the issue since. Thanks for taking a look and if I see it again I'll be sure to send a debug log your way (now that I realize that's a thing ?)
