ISY Portal A/V Tab Help Requested?
rlanza1054
Hi,
I noticed the A/V tab in the ISY Portal the other day.
I never planned on using it.
But I'm trying to do something and I think it best that I learn what it's function is for and how to use it.
Does anyone have a link to a thread where we can learn how to use its functions?
Thank you!
Rob
Hi,
Thank you!
Rob
[runs off to check] Nope. Cannot see this in my portal account. Is it possible to share a screenshot?
Edit: Ahh, you mean under the Alexa spokens config. I’d hazard a guess that it enables you to expose network rules and such to Alexa as an audio device (think asking a network addressable receiver to adjust its volume). I don’t use Alexa, so not sure.
2 hours ago, rlanza1054 said:
Hi,
Thank you!
Rob
There's no real docs on this topic, but it's fairly easy once you grasp the concept.
When you add an 'A/V device', this creates an Alexa A/V device.
Of course, ISY is not an A/V device, but you can have network resources which controls A/V devices. So when you create an Alexa A/V device, you can wire the relevant Alexa functionnality to your network resources (Or State variables, or programs, if this simplifies things for you).
So, let's say you want to control a TV, and you have network resources for On, Off, Volume Up, Volume down, you just have to map those to the A/V device you created.
Once the device is created and discovered by Alexa, you can use your A/V device. To help you know how you can control, go back to your A/V device on ISY Portal, and hover the fields label. This will tell you what to say.
Alternatively, you can refer to this: https://wiki.universal-devices.com/index.php?title=ISY_Portal_Amazon_Echo_Integration_V3#A.2FV_Devices
Benoit
Where are these network resources located?
Is this a direct connection between vocals and these network resources avoiding ISY processing ?
Sent from my SM-G930W8 using Tapatalk
The network resources are on ISY. The ISY is therefore required.
So nothing is much different for the A /V Network Resources except you have created a special vocal library to handle the needed devices allowing us to map a/v vocals to NRs as if they were devices?
Almost. The ‘vocal library’ is created by Amazon. All that ISY Portal is doing is creating an Echo A/V device and maps some or all of the functions to ISY resources (network resources, state variables or programs)
      377k
