March 1, 20197 yr Running 5.0.14, having some communication difficulty with a couple of Radio Thermostat CT32 units, I see messages like this in the event log: Thu 02/28/2019 21:42:25 : [ZW-DB /CONF/0022.CZW] sizeof(UZWCmdClassEntry) too small (4 < 108) Thu 02/28/2019 21:42:25 : [ZW-DB /CONF/0011.CZW] sizeof(UZWCmdClassEntry) too small (4 < 101) . . . Thu 02/28/2019 21:42:50 : [ZWAVE-WAKEUP 8] Force writes to ZW008_1 Thu 02/28/2019 21:42:50 : [ZW-DB /CONF/0011.CZW] sizeof(UZWCmdClassEntry) too small (4 < 101) Haven't made any recent changes to the ISY or added new devices, etc. Edited March 1, 20197 yr by KeviNH
March 1, 20197 yr @KeviNH, Thanks so very much for reporting. We are looking into it. With kind regards, Michel
March 1, 20197 yr Author Thanks for checking on this. This ISY serves my Makerspace and has a portal subscription, I can share details via private message if you need more details or the UUID.
March 1, 20197 yr @KeviNH, Thank you. It would be good to know whether or not this unit was migrated from 4.7.3 to 5.0.14. If not, when was the last time the firmware was updated and from what version to what? Also, what are the symptoms except for the error in the log? With kind regards, Michel
March 1, 20197 yr Author This ISY was received from UDI in November 2018, with 5.0 installed. We have 5 Z-Wave devices -- 4 are CT32 thermostat USNAP modules (all thermostats have "C" wires for constant power), and one Aeotec repeater 6. The errors are on the devices that are further away, reached via repeater. Thermostats showing the error message also lose their status in the Admin Console, and on the web they look like this now:
March 4, 20197 yr Hi Kevin, Can you please take a backup of your ISY and send DM it to me. It looks like the database information for that thermostat may be corrupt, or the ISY may be having trouble reading it from the SD card. You can try restarting the ISY and see if that fixes the problem. If not, delete all the ISY nodes for the thermostat (no need to exclude the thermostat), and then synchronize again.
March 5, 20197 yr Author No change after a restart. Deleted the nodes for both of the thermostats having problems. Synchronize brought one of the thermostats back to normal, but ZW_008 (Woodshop shown above) didn't come back as a Thermostat, instead it's an "Uninitialized" node named "ZW 008 0.0.0"
March 6, 20197 yr Author Never managed to get ZW_008 back to normal, but after a couple of tries I did get the "extra node" named ZW008_001_1 online, and I changed all my programs and notifications to use that node instead. So I've got things working again.
