March 2, 20197 yr I'm trying to setup an ISY in my barn/workshop. I'm using a Netgear AC1900 wifi range extender to repeat the wifi into my barn. This extender has several ethernet ports, one of which I'm trying to use to connect the ISY to. I am getting the flashing error and memory lights which I believe is a network error. I have a few other devices plugged into the other ethernet ports and they have no problem connecting to my network. I did very briefly get the ISY to connect right after I factory reset the extender one time.... but it popped up with a different IP then it's MAC reservation. Am I missing something simple? Thanks!
March 2, 20197 yr Hey Adam Try plugging the ISY in one of the other ET ports that's working for other devices, does it work? Is the subnet the same on both sides of the extender eg a.b.c.z = where a, b and c are the same for addresses on both sides of the extender? Do the other plugged in devices in the extender have a dhcp reservation? If no: The DHCP discover message from the ISY may not be making it through the extender or back from the Router You might try moving it back to your house, if it works, assign the address to the ISY manually and move it back Paul Edited March 2, 20197 yr by paulbates
March 3, 20197 yr Author Hi @paulbates Thanks for taking the time to help me figure this out. I followed your steps and got it working. I ended up having to bring the ISY back in the house, setting a new MAC reservation and setting the ISY to a static IP. Now I'm up and running! Thanks again.
