Time has jumped ahead a day early
Installed a new plm yesterday which should have nothing to do with this issue.  This AM found times an hour early.  If I sync with the computer the time is correct , sync to the ntp server and the time jumps 1 hour.  Time zone is correct. BTW 4.7.3
Have one 4.7.3 system, EST.  Showing correct time using ntp (pool.ntp.org). Tried 0.pool.ntp.org and it's still fine.
Are you not full of good news ?.  Just my luck to have an off the wall issue. Not a major problem, just strange. Will be interested to see what happens over night. Many thanks for the info.
Try a custom GPS location. IIRC there were some locations that didn't work properly.
Sent from my SM-G930W8 using Tapatalk
Interesting, I also saw some webcams that were reporting wrong times yesterday.  Today all is fine, will try and remember to look for it in the fall, will try a custom location if it is off then.
Could be.  When I tested yesterday I was using a custom location.
