March 12, 20197 yr I had my Insteon set up working well so I decided to move the ISY99 to its permanent home on a shelf a foot away and route the cables out of the way. That included the power connector which I unplugged for a minute to route it through a hole at the back of the shelf. However, since plugging it back in I can't get the software to come back up. In fact, the OS doesn't appear to be mounting either because I can't telnet into it. I configged it with a static IP of 192.168.1.207 and I see that IP in my router and that it's marked Inactive. # telnet 192.168.1.207 Trying 192.168.1.207... telnet: Unable to connect to remote host: Connection refused I have a green light showing at the ethernet connection on the back the ISY99 but the other end is showing a yellow light at the hub. When the ISY99 boots up the Power, Tx and Rx lights are full on and the Memory light flashes a few times. Then the Rx, Tx and Memory lights go out and stay out. Only the Power light remains lit. My first thought was that I screwed up the static IP setting somehow and the ISY99 installed itself on a dynamic IP. But I can't find any unknown connections on my router.Another oddity: while I was typing this message, the router suddenly showed 192.168.1.207 as "Active". Could there have been an 'fsck' file check process running because I pulled the power plug? It's academic though because I still can't telnet into it and ISY Launcher still returns "Invalid URL" on that IP address. Should I attempt a factory reset of the ISY994? In case I didn't say it before, thanks for all your help to date. Edited March 12, 20197 yr by SteveManes
March 12, 20197 yr Have a look here. I wouldn't factory reset your ISY yet. Have a look here. https://wiki.universal-devices.com/index.php?title=Main_Page#Flow_Chart
March 12, 20197 yr Author That was it! The power supply was bolloxed. I used the 9v power supply from my spare hub and it came up fine. Thanks!
